    MAX31856 duet2 wifi board pin number
    474
    • gorf32undefined
      gorf32
      looking to see if i can find the pin values for duet MAX31856 connected to the duet2 wifi v1.03
      pin referring to:
      sensor_pin: PB14 -- I think this is correct
      spi_speed
      spi_bus ?
      sclk_pin ?
      mosi_pin ?
      smiso_pin ?
      any help would be great
      Thanks gary
      zaptaundefined droftartsundefined o_lampeundefined 3 Replies Last reply Reply Quote 0
      • zaptaundefined
        zapta @gorf32
        @gorf32 said in MAX31856 duet2 wifi board pin number:
        MAX31856
        If it helps, this is the schematic of 1.04.
        https://github.com/Duet3D/Duet-2-Hardware/blob/master/Duet2/Duet2v1.04/DuetWifi_Schematic_v1.04.pdf
        gorf32undefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @gorf32
          @gorf32 Here's the schematic for the Duet3D thermocouple board: https://github.com/Duet3D/TempDaughterboards/blob/master/MAXTempTC/MAXTempTCv1.1.pdf
          Wiki page: https://docs.duet3d.com/Duet3D_hardware/Accessories/Thermocouple_Daughterboard
          • o_lampeundefined
            o_lampe @gorf32
            @gorf32 This is a pinmap I often use as reference.
            • gorf32undefined
              gorf32 @zapta
              @zapta Thanks I got it working sort of, it reading the temp but it seems to be about 20c to high when cold i am getting a value 43c cold it should read around 23 to 25c
              thamks
                dc42 administrators @gorf32
                @gorf32 if the reference resistor on your MAX31865 board has a value other than 400 ohms then you need to tell RRF what value it is using the R parameter of the M308 command.
                • gorf32undefined
                  gorf32 @dc42
                  @dc42 I don't know much about circuits, but i think this is the layoutpt100.png
                    @gorf32 looks like your reference resistor is 430 ohms.
                    • gorf32undefined
                      gorf32 @dc42
                      @dc42 Thanks i did get it to work was a value of 400
                      • dc42undefined dc42 marked this topic as a question
