    accelerometer not found DUET WIFI V1.2
    • anderundefined
      ander
      Hi there!
      I have installed an accelerometer LIS3DSH on my duet wifi V1.2.
      I was using an ethernet wiring to do the conection but the console was telling me that the accelerometer wasn´t found. I read in this forum that the wiring could be important so i changed the wire with a usb 3.0 cable.
      The problem persists.
      Sending the M955 P0 : Error: M955: Accelerometer not found
      Here is my config.g:
      config(5).g
      Also, this is my wiring:
      Can someone give me a hand please?
      This is my M122:
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917Q9-GLMS8-6JTD2-3SD6P-9YD0B
      Used output buffers: 1 of 26 (22 max)
      Static ram: 23896
      Dynamic ram: 75136 of which 44 recycled
      Never used RAM 13004, free system stack 184 words
      Tasks: NETWORK(ready,11.4%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,83.4%,436) IDLE(ready,5.1%,30), total 100.0%
      Owned mutexes:
      Last reset 00:00:17 ago, cause: software
      Last software reset at 2024-01-17 16:42, reason: User, GCodes spinning, available RAM 12800, slot 0
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 36.2, current 36.8, max 37.2
      Supply voltage: min 23.4, current 23.4, max 23.5, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2024-01-17 16:42:38
      Cache data hit count 663459077
      Slowest loop: 12.20ms; fastest: 0.18ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.7ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 25.59ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      anderundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • anderundefined
        ander @ander
        I forgot to mention, the screen is telling : "accelerometer not found in specified port" when starting
          droftarts administrators @ander
          @ander Your accelerometer configuration command is:
          M955 P0 C"spi.cs2+spi.cs1"
          Wiring instructions are here: https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_Accelerometer#wiring
          Your wiring order looks incorrect, I think you have SDA and SCL wrong. It should be:
          Duet 2 WiFi LIS3DSH
          +3V3 VCC
          GND GND
          SPI_SCK SCL
          SPI_MOSI SDA
          SPI_MISO SDO
          SPI.CS2 CS
          SPI.CS1 INT1
          anderundefined 1 Reply Last reply Reply Quote 0
          • anderundefined
            ander @droftarts
            @droftarts
            Thanks for the help, it worked beautifly!!
