    Strateo IDEX 420 usb detection error
    • armisundefined
      armis
      Hello, i have encountered error, where i cannot access usb flash drive or x/y offset cameras on my IDEX420. It is using Duet 3 MB6HC 3.4.0. I have to adjust x and y offset with onboard camera, but it is not possible, because i cannot access onboard camera.20240122_152317.jpg
        droftarts administrators @armis
        @armis I think you will need to contact the manufacturer to resolve this: https://en.emotion-tech.com/strateo3d-idex420-3d-printer
        armisundefined 1 Reply Last reply Reply Quote 0
        • armisundefined
          armis @droftarts
          @droftarts this sucks, because they are nonresponsive. I still havent received any information about onboard cameras
          • oliofundefined
            oliof
            USB error -32 seems to be related to unstable or low power situation, other sites recommend adding a powered hub. If one is built into your printer, check that it still is powered.
            USB error -71 is likely an initialisation error as a result of the power fluctuation.
            Another suggestion I found elsewhere was to completely depower the system, remove the USB devices, reboot and try plugging them in one by one.
            I hope that helps.
