    Imputshap8ng stops when collecting data
    imput shaping accelerometer
    • Milan Rundefined
      Milan R
      Hello everyone,
      I just installed my accelerometer, after some tries the sensor was found by the duet with the m955 command.
      When I start the data collection, the print head makes a move from the center along the x axis. But the nothing happens anymore.
      Do you have an idea what the problem might be?
      Kind regards
      Milan
      • oliofundefined
        oliof @Milan R
        @Milan-R Inputshaping sampling on RRF is based on a single move. That's different to Klipper where the frequency spectrum is walked.
        Are you using the input shaping plugin ? Do you see data collection happening?
        Milan Rundefined 1 Reply Last reply Reply Quote 0
        • Milan Rundefined
          Milan R @oliof
          @oliof
          Thanks for the answer.
          I use the plug in and I don't see any data that was collected.
          Or at least I don't know where to find it.
          It is possible to do a x and a y move or a combined move.
          When I say I want a x and a y move. It does only the x move but does not start the y move, even though it is in the queue. I think I have seen a picture, where there is a check mark in front of the move before it starts the next move.
          I just see the playbutton for the first move and a sun or a clock in the line of the second move,but it never changes
          Best regards Milan
          • Milan Rundefined
            Milan R @Milan R
            @Milan-R
            so today i had some time and tried it again. It worked at the first try and i can see data now.
            I changed nothing. But now it just works.
