    Data Collection and Reporting for DWC
    Duet Web Control
    • ErlerPrint3Dundefined
      ErlerPrint3D
      Hello everyone,
      I was at Formnext 2023 in November and took the flyer for data collection and reporting from the Duet3D stand (see the image below). I am currently building an axis system with a measuring system (Duet 3 Expansion 1HCL) and would like to use the visualization of the encoder data, but I can't find anything about it anywhere.
      Has anyone already used this or will it only be available in the future?
      • T3P3Tonyundefined
        T3P3Tony administrators @ErlerPrint3D
        @ErlerPrint3D it was a demo of how it is possible to get information out of the object model. Initial users will probably already have a data collection system for other machines, which could also hook into Duet controlled machines. We have a blog post in draft about how we did the demo and are considering how to expand this for people who don't already have a collection system but want to start doing this.
        www.duet3d.com
        ErlerPrint3Dundefined 1 Reply Last reply Reply Quote 0
          ErlerPrint3D @T3P3Tony
          @T3P3Tony
          Thank you for your quick reply. I find the visualization of the data very exciting, but I have no idea how to implement it. Can you please send me the link to the blog post.
          Has anyone from the community already implemented this?
          T3P3Tonyundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
          • T3P3Tonyundefined
            @ErlerPrint3D will do when it's published
            www.duet3d.com
              jay_s_uk @ErlerPrint3D
              @ErlerPrint3D you can use Node-Red with @MintyTrebor fantastic set of nodes. https://flows.nodered.org/node/node-red-contrib-dsfnode
              The data can then be fed into influxdb and visualised with grafana. This can also easily be ran on a raspberry pi on the network.
              If you are going to run node-red on a pi, I suggest using this script to install it https://tech.scargill.net/the-script/ It'll also handle the install of grafana and influxdb
