    Need help to configure Heaters and Temperature sensors PT100
    435
    • imartinezundefined
      imartinez
      Good morning:
      I would need help to configure the heaters on my Duet 3 Mainboard 6HC, I have a print head with a heater and a material dispenser that also has a heater, the temperature sensors are PT100 type. I have a max31865 board for the PT 100 sensors (RTD1 and RTD2), which are 2, the temperatures are displayed well on the screen but it seems that it is not able to control the temperature of the heaters with the sensors, it does not relate them well.
      I manage to heat the head and the dispenser but not control the temperature, even though they heat up and up ...., they exceed the limit that I set in the software,
      my config.g ....
      M550 P"ROBO" ; set printer name
      M552 P192.168.1.20 S1 ; enable network and set IP address
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.1.254 ; set gateway
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.0 S0 ; physical drive 0.0 goes forwards
      M569 P0.1 S0 ; physical drive 0.1 goes forwards
      M569 P0.2 S0 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes forwards
      M569 P0.5 S0 ; physical drive 0.5 goes forwards
      M584 X0.0:0.3 Y0.1 Z0.2 E0.5 ; set drive mapping
      ;M584 0.3 Y0.1 Z0.2 E0.5 ; set drive mapping
      M350 X2 Y2 Z2 E4 I1 ; configure microstepping with interpolation
      ;M350 X4 Y4 Z4 E16 I1 ; configure microstepping with interpolation
      ;M92 X80.00 Y80.00 Z80.00 E420.00 ; set steps per mm
      ;M92 X1626.68 Y1626.68 Z1626.68 E420.00 ; set steps per mm
      ;M92 X200.00 Y200.00 Z200.00 E420.00 ; set steps per mm
      M92 X196.00 Y205.80 Z196.14 E420.00 ; set steps per mm
      M566 X100.00 Y100.00 Z20.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      ;M203 X1200.00 Y1200.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
      ;M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
      ;M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M203 X600.00 Y600.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X50.00 Y50.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
      M906 X3360 Y3360 Z3360 E2987 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; PanelDue 7i
      M575 P1 S1 B115200
      M208 X100 Y400 Z200 S0 ; set axis maxima
      M574 X1 S1 P"^io1.in"
      M574 Y1 S1 P"^io2.in"
      ;M574 Z2 S1 P"^io3.in"
      M574 Z1 S1 P"^io3.in"
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:99 Y15:399 S200 ; define mesh grid
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      M563 P0 D0 F0 H1:2 ; define tool 0
      G10 P0 R50 S60 ; set initial tool 0 active and standby temperatures to 50C
      T0
      M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs0
      M950 H1 C"out1" T1 ; create nozzle heater output on !out1 and map it to sensor 1
      M307 H1 B0 S1.00 V24.0 ; disable bang-bang mode for heater and set PWM limit
      M303 H1 P1 S40 ; Heater 1 power 100% Temp limit 40º
      M143 H1 P0 S50 A2 ; set temperature limit for heater 1 to 50C
      M308 S2 P"spi.cs1" Y"rtd-max31865" ; configure sensor 2 as PT100 on pin spi.cs1
      M950 H2 C"out2" T2 ; create nozzle heater output on !out2 and map it to sensor 2
      M307 H2 B0 S1.00 V24.0 ; disable bang-bang mode for heater and set PWM limit
      M303 H2 P1 S40 ; Heater 2 power 100% Temp limit 40º
      M143 H2 P0 S50 A2 ; set temperature limit for heater 2 to 50C
      Thanks
        jay_s_uk @imartinez
        @imartinez have you tuned your heaters using M303?
        imartinezundefined 1 Reply Last reply Reply Quote 0
          imartinez @jay_s_uk
          @jay_s_uk said in Need help to configure Heaters and Temperature sensors PT100:
          M303
          No... I don´t know how to use M303 comand.....
          jay_s_ukundefined imartinezundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @imartinez
            @imartinez https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m303-run-heater-tuning
              imartinez @imartinez
              @imartinez
              I use this line in my config.g...
              But i don´t know this is correct or not.....
                jay_s_uk @imartinez
                @imartinez thats not correct. M303 tuning is not done as part of your config. its a command you send separately
                  imartinez @jay_s_uk
                  @jay_s_uk
                  Ok, I think i must remove this line from mi config.g and execute it like a comand in mi control panel , correct???
                  is this the execute form i must tu use ????
                  M303 H1 P1 S40
                  Thank you very much.....
                    jay_s_uk @imartinez
                    @imartinez correct.
                    maybe this gives a bit more info https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_tuning
                      imartinez @jay_s_uk
                      @jay_s_uk
                      And after execute that????...
                      Thank you again....
                        jay_s_uk @imartinez
                        @imartinez see here https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_tuning#making-new-heater-parameters-persistent
                          imartinez @jay_s_uk
                          @jay_s_uk
                          Ok... Thank You very much....
                          should i remove all this lines from my config.g???
                            jay_s_uk @imartinez
                            @imartinez no, you need all those. either replace the M307 lines or use M500 and config-override.g
                              @imartinez
                              ok
                              Thaks a LOT
                              jay_s_ukundefined droftartsundefined imartinezundefined 3 Replies Last reply Reply Quote 0
                                jay_s_uk @imartinez
                                @imartinez you may want to revisit your wiring as all of your crimping looks very dodgy!
                                There are wires that are bare and almost coming into contact which will cause a short and could lead to board damage.
                                You also have bare wires in terminals that should be crimped with bootlace ferrules.
                                And I'm not sure what's going on with your heater wires. It looks like you've crimped the JST VH pins onto existing ferrules. Thats also a very bad idea
                                imartinezundefined 1 Reply Last reply Reply Quote 1
                                  droftarts administrators @imartinez
                                  @imartinez I second @jay_s_uk's comments about your wiring. You're risking shorting out a stepper driver with this:
                                  Inconsistent temperature readings with this:
                                  And potentially creating heat at the junction of the crimp and ferrule with this:
                                  imartinezundefined 1 Reply Last reply Reply Quote 2
                                    imartinez @jay_s_uk
                                    @jay_s_uk Ok.... Thank You ....
                                      imartinez @droftarts
                                      @droftarts Ok
                                      Thank You
                                        @imartinez
                                        Hello again.... 🙂
                                        I revised my wiring conexions and fixed it , but i have problems again , i remplaced my 307 lines with the parameters of the tunning but , when i try to use the heaters I have a notification "Header 2 fault: failed to read sensor: sensor shot to other wiring" , i resised wiring 2 or 3 times and i think was Ok, Do you think the cause could be the length of the cables or it could be something else??????
                                        parameters of M307
                                        M307 H1 R0.337 K0.402:0.000 D11.85 E1.35 B0
                                        M307 H2 R0.238 K0.228:0.000 D8.78 E1.35 B0
                                        Thanks
                                          @imartinez Yes, the sudden jumps in temperature reading are usually because the wiring is shorting out, or is being disconnected. It's also possible it is interference; does the temperature jump happen at the same time as motor movement, or heater turning on and off?
                                          I can see you have the 'Connecting PT100 temperature sensors' wiki page open! See particularly this section on the subject of interference: https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_connecting_PT100#wiring-the-pt100-temperature-sensor
                                          2-wire connections have the advantage of wiring simplicity. 4-wire connections have the advantage of greater accuracy; the extra wires compensate for the resistance drop in the wires, making readings more accurate. 4-wire does not improve resistance to interference; better approaches to reduce noise include twisted wiring, isolation from noise sources, shielded wiring, better grounding of components etc.
                                          See the troubleshooting advice at the end of the page here to check the problem isn't the temperature board: https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_connecting_PT100#troubleshooting
                                            @droftarts Good Morning....
                                            I already put the sensors with 4 wired conexion and i have the error again , i don´t know what is happend .......
                                            The pt100 sensors read 2000 ºC when the heater is on every 10 or 15 seconds , is no always the same time , do u think is a interference problem???? , do u think a ferrita core is a possible solution??????
                                            Thanks
