    Firmware 1.20 released
    Firmware installation
    20
    89
    14.2k
    • Captain_squndefined
      Captain_sq
      I've gone back to 1.19 while your busy finding the rodent messing around in the Network task in the 0.6 hardware. I kept the newest DWC and found that this also works with 1.19 FW. Nice with some new functionality. I'm not sure wether all the new controls works for real with 1.19 but the extended system edit possibilities are welcome.
      Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
      Embedded systems designer, RC Pilot, maker and Gadget-o-holic
        I have it on my list to investigate your report before the 1.20.1 release, however I need to get the prototype laser filament sensors completed and shipped first to avoid additional delay to production of filament sensors.
        • Luca79undefined
          Luca79
          Just tried to upgrade from 1.19 to 1.20. I've uploaded DuetWifiFirmware.bin, but I cannot connect anymore to the printer via wireless. Any idea?
          • Luca79undefined
            Luca79
            Adding some bits. I also tried connecting through USB but the serial device is not recognized by my linux machine (before upgrading used to work).
            EDIT: i have tried the fallback procedure #2 described at https://duet3d.com/wiki/Updating_main_firmware but it still doesn't work.
              The USB interface code did not change between 1.19 and 1.20, so I don't understand why you can't access the Duet over USB any more. Do you have any evidence that the firmware update succeeded in other ways, e.g. because an attached PanelDue is working?
              • Luca79undefined
                Luca79
                I don't own a PanelDue. I don't know how to debug this.
                  So as far as you know, the board isn't running at all. See https://duet3d.com/wiki/What_to_do_if_your_Duet_or_Duet_WiFi_won%27t_respond.
                  • abitidiundefined
                    abitidi
                    I just want to report that the github link on this wiki page is broken. https://duet3d.com/wiki/Updating_main_firmware
                    • deckingmanundefined
                      deckingman
                      @abitidi:
                      Works for me. Maybe it got fixed between your post and mine?
                      • abitidiundefined
                        abitidi
                        @deckingman:
                        Weird…I still get a 404 when I try the link.
                          I just tried it again (using the link in deckingman's post above) and it works for me.
                          • Dougal1957undefined
                            Dougal1957
                            it also works for me with no issues (From the OP's original link)
                            • rar26undefined
                              rar26
                              do i have to redo my config file after the update?
                                @rar26:
                                Read the upgrade notes to see whether you need to make any changes.
                                • Mikeundefined
                                  Mike
                                  Both of my Duets stopped printing any G-code file with brackets in it's name after 1.20 update. The files upload fine,it's just that the subsequent M32 command fails with "Gcode file not found". Same files worked fine in 1.19 and before, so it's probably something that was changed with 1.20.
                                  Edit: Rechecked, it's definitely the firmware - already uploaded file prints on 1.19.2, gives error with 1.20 or later. Web interface version had no effect on the outcome.
                                    It's because standard GCode uses brackets to enclose comments, therefore anything enclosed in brackets is stripped out. Workaround is to use double quotes around the filename in the GCode command. The beta PanelDue firmware already does this, and DWC will do so soon.
                                    • Thomllamaundefined
                                      Thomllama
                                      so, upgraded to 1.2 with help from here (thanks a bunch! :). ) everything seemed fine, but now getting an "error G28 failed to home" with X and Y end stops. Z seems to work fine. thing is it visually/mechanically seems to be homing fine. Setup on a CoreXY. here is a video if it helps figure what I'm doing wrong. what settings and such should I be looking at/for? Supposedly it was a beta version of the firmware issue and was fixed? but I never used a beta version.. just upgraded from 1.18 to 1.2
                                      https://youtu.be/2oJRdR2xxqQ
                                        Is is definitely moving as far as the X and Y homing switches when you try to home all, or when you try to home just X or just Y? The movement in your video looks very short.
                                        Please share your config.g and homing files.
                                          Thomllama
                                          I haven't tried to home all as the Y end stop isn't mounted yet so I trip it by hand myself. reason I didn't show it. 😉 I saw the write up on the "home all" for CoreXY which is easy enough .. Short movements was just because I didn't want to waste peoples time watching it slide across, so I was just starting them rather close. - Config -g -
                                          [c]; Configuration file for Duet WiFi (firmware version 1.17)
                                          ; generated by RepRapFirmware Configuration Tool on Mon Oct 16 2017 05:23:05 GMT-0400 (EDT)
                                          M111 S0 ; Debugging off
                                          G21 ; Work in millimetres
                                          M208 X350 Y350 Z350 S0 ; Set axis maxima
                                          M667 S1 ; switch to CoreXY mode
                                          M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
                                          M569 P0 S1 ; Drive 0 goes backwards (X axis)
                                          M569 P1 S0 ; Drive 1 goes forwards (Y Axis)
                                          M569 P2 S0 ; Drive 2 goes forwards (Z Axis)
                                          M569 P3 S0 ; Drive 3 goes forwards (Extruder)
                                          M92 X160 Y160 Z400 E97 ; Set steps per mm
                                          M566 X700 Y700 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                                          M203 X6000 Y6000 Z400 E1200 ; Set maximum speeds (mm/min)
                                          M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
                                          M906 X900 Y900 Z900 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                          M84 S30 ; Set idle timeout
                                          M143 S245 ; Set maximum heater temperature to 245C
                                          M307 H1 A737.5 C231 D5.5 B0
                                          M307 H0 A166.3 C515.3 D2.5 B0
                                          M563 P0 D0 H1 ; Define tool 0
                                          M550 PLlama CoreXY ; Set machine name
                                          M552 S1 ; Enable network
                                          M587 SXXXX P######## ; Configure access point. You can delete this line once connected
                                          M586 P0 S1 ; Enable HTTP
                                          M586 P1 S0 ; Disable FTP
                                          M586 P2 S0 ; Disable Telnet
                                          M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                          M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                          ; custom tune Duet CPU temp
                                          M912 P0 S-5.7
                                          ; Custom settings are not configured[/c]
                                            Thomllama
                                            home X, Y and Z
                                            [c]
                                            ; homex.g
                                            ; called to home the X axis
                                            ; Lift Z relative to current position
                                            G91
                                            G1 Z5 F6000
                                            G90
                                            ; Move quickly to X axis endstop and stop there (first pass)
                                            G1 X-400 F1800 S1
                                            ; Go back a few mm
                                            G91
                                            G1 X5 F6000
                                            G90
                                            ; Move slowly to X axis endstop once more (second pass)
                                            G1 X-235 F360 S1
                                            M84
                                            ; homey.g
                                            ; called to home the Y axis
                                            G91
                                            G1 Z5 F6000
                                            G90
                                            ; Move quickly to Y axis endstop and stop there (first pass)
                                            G1 Y-400 F1800 S1
                                            ; Go back a few mm
                                            G91
                                            G1 Y5 F6000
                                            G90
                                            G1 Y-215 F360 S1
                                            M84
                                            ; homez.g
                                            ; called to home the Z axis
                                            G91 ; relative mode
                                            G1 Z4 F200 ; raise head 4mm to ensure it is above the switch trigger height
                                            G90 ; back to absolute mode
                                            G91 ; relative mode
                                            G1 Z-400 S1 F250 ; move Z down until the switch triggers
                                            G1 Z-200 S1 F50 ; move Z down until the switch triggers
                                            G92 Z0.15 ; tell the firmware that we are at Z=0.15mm
                                            [/c]
