    Converting DateTime to string
    Gcode meta commands
    399
    • jonathanbrentundefined
      jonathanbrent
      Hi Everyone,
      I can't seem to find a way to convert a DateTime variable to a string. I am trying to create a file at the start of my gcode that will include the current date and time (using state.time) in its title; however, it seems that the name of a file must be of type string.
      Any thoughts? Thanks!
      Current Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.6
      dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @jonathanbrent
        @jonathanbrent use the ^ operator to concatenate it with a string literal, even an empty string literal will do.
        jonathanbrentundefined 1 Reply Last reply Reply Quote 0
          jonathanbrent @dc42
          @dc42 Thanks! Now it turns out my issue is really that I can't include the ":" character in a file name. Is there a way for me to modify the string that I have retrieved from state.time (e.g. 2024-03-12T12:54:43)? Or is there some other way to get the current time without colons?
          Thanks again
            @jonathanbrent I'm sorry, I can't think of a workaround at present.
            • T3P3Tonyundefined
              T3P3Tony administrators @jonathanbrent
              @jonathanbrent can you convert it to an int instead of a string. They the files will be sequential, with the right number of seconds between names. Just not easily human readable without converting the int back to a datetime.
              Being able to use datetime in a filename is a feature I would like as well. There is a feature request tracking something similar here:
              https://github.com/Duet3D/RepRapFirmware/issues/787
              T3P3 created this issue in Duet3D/RepRapFirmware
              closed allow date and time to be retrieved as individual strings/ints #787
              www.duet3d.com
              • oliofundefined
                oliof
                maybe a generic split function for strings would suffice?
                • T3P3Tonyundefined
                  T3P3Tony administrators @oliof
                  @oliof string split to an array would be even more useful for sure.
                  www.duet3d.com
                    dc42 administrators @T3P3Tony
                    @T3P3Tony or maybe a replace-in-string function e.g. replace(state.time, ':', '-')
                    T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
                    • T3P3Tonyundefined
                      T3P3Tony administrators @dc42
                      @dc42 yes that would work as well for the particular usecase of naming a file with a datetime that's a valid filename. Its less generalisable than being able to use just the date or just the time - but that's not necessarily an urgent requirement.
                      It depends on the overhead to implement various types of string handling.
                      www.duet3d.com
                      • T3P3Tonyundefined
                        @jonathanbrent Since 3.6.0beta4 the functions "drop","find" and"take" have been implemented.
                        documentation is here:
                        https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#functions
                        I have updated this github issue with an example of how to use them for date/time splitting into a string.
                        https://github.com/Duet3D/RepRapFirmware/issues/787#issuecomment-2658795794
                        www.duet3d.com
                        • T3P3Tonyundefined T3P3Tony referenced this topic
