    SDCard reading stops while power was on
    • GeneRisiundefined
      GeneRisi
      My Duet2 failed running after I edited the tpostx.g files to use the Z coordinate saved before the tool change occurred. I can read the SDCard successfully on my Mac. I copied the contents of the SDCard onto another one that I had. It also was not read by the Duet2. The firmware seems to be in its default state with the extruder 0 fan constantly running.
      How should I proceed?
      Gene
        jay_s_uk @GeneRisi
        @GeneRisi I'll post here instead. When it "stops reading" post an output of M122
        GeneRisiundefined 1 Reply Last reply Reply Quote 0
        • GeneRisiundefined
          GeneRisi @jay_s_uk
          @jay_s_uk thank you! M122 shows there sdcard being recognized, so I tried to run config.g and got an error "insufficient axis homed" . When I removed the problem everything worked as expected.
            Phaedrux Moderator @GeneRisi
            @GeneRisi said in SDCard reading stops while power was on:
            What was the problem?
            • GeneRisiundefined
              GeneRisi @Phaedrux
              @Phaedrux The problem was that I had entered a move in config.g before axis homing. "Insufficient axis homed" seems to leave the machine in a state similar in this case to config.g not existing.
