    accelerometer combined with pt100 thermocouple on 6xd
    • lazy_mosquitoundefined
      lazy_mosquito
      The documentation about combining the pt100 and the accelerometer is a bit confusing for me.
      The documentation states: If your Duet mainboard supports more than one temperature daughterboard (Duet 3 6XD), and you have one temperature daughterboards installed, you can connect the accelerometer to the top of the temperature daughterboard.
      Do they mean that I install the pt100 board as standard and then connect the accelerometer on the same SPI connector on top of the connections of the pt100? A schematic would clarify a lot here. I would not even mind drawing it, if I knew which points to connect with which one. I want to keep the accelerometer constantly connected.
        jay_s_uk @lazy_mosquito
        @lazy_mosquito yes. the accelerometer connects to the exposed pins on the top of the PT100 daughter board once it has been installed
        lazy_mosquitoundefined 1 Reply Last reply Reply Quote 0
          lazy_mosquito @jay_s_uk
          @jay_s_uk ok thanks
