    PanelDue Firmware 3.5.0-rc9 released
    PanelDue
    724
    • mfs12undefined
      mfs12
      Hey guys,
      a new and likely last release candidate.
      As usual release notes and downloads can be found on github.
      https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.5.0-rc9
      Please report any problems here. And if things will run smooth next week there will be the official 3.5.0.
      Cheers and happy printing...
      Visit me on github at https://github.com/mfs12/
      • achrnundefined
        achrn
        Thanks.
        On a MB6HC (MB6HC) with a SBC with nice new Bookworm 3.5.1 should the IP address in Setup be correct? Mine is showing 0.0.0.0. The object model has it correct - network.interfaces[0].actualIP showing 192.168.52.38. (I can't remember if it was showing correctly before.)
        blt3dpundefined mfs12undefined 2 Replies Last reply Reply Quote 0
        • blt3dpundefined
          blt3dp @achrn
          @mfs12
          Just posted this on the github as a bug but I'm runing the same setup as achrn and I'm not seeing the macros on the right on the main screen. clicking macros shows nothing, and clicking the sd card icon doesn't show my gcodes
          No change for me between rc8 and rc9
          My 3D Printing YouTube Channel
          Better Living Through 3D Printing
          Follow me on Instagram and Twitter
          Instagram
          Twitter
          mfs12undefined achrnundefined 3 Replies Last reply Reply Quote 0
          • mfs12undefined
            mfs12 @blt3dp
            @blt3dp @achrn I will have look into it.
            • achrnundefined
              achrn @blt3dp
              @blt3dp said in PanelDue Firmware 3.5.0-rc9 released:
              FWIW, my macros are fine - show up where they should and run when clicked.
              • mfs12undefined
                mfs12 @achrn
                @achrn said in PanelDue Firmware 3.5.0-rc9 released:
                so there's a little caveat 😉 when in setup tab paneldue does NOT communicate with RRF, therefore if switched to early into setup tab, the ip addr might still show 0.0.0.0 (not connected) although RRF has meanwhile connected.
                So after RRF is connected and then entering setup tab everything should be displayed as expected.
                achrnundefined blt3dpundefined 2 Replies Last reply Reply Quote 0
                • mfs12undefined
                  mfs12 @blt3dp
                  Hey, i can't reproduce it. Everythng shows up as expected. Is there a problem with your folder structure on the sd card? do you have some unusual folder nesting?
                  blt3dpundefined 1 Reply Last reply Reply Quote 0
                  • blt3dpundefined
                    blt3dp @mfs12
                    @mfs12
                    Nothing strange that I know of. Everything shows up normally in DWC. I can initiate prints as well as macros from there.
                    Also, I should say that when the PanelDue was 3.4.1-pre2, it showed the macros on the main screen as well as the list when you hit the button without a problem. But no gcodes.
                    Edit: Interesting, I had left the blank macros screen open, went over to DWC and sent M20. When i got back over to the printer, it was reporting it was unable to access SD card. Dismissed that a couple of times and saw a message stating connection to SBC established. Dismissed that, and all my macros were on the home screen, and tapping the macros or sd card buttons showed the files.
                    Seems to still be working after a few shutdowns. I guess resolved?
                    Edit Again: I'm also able to see the same behavior regarding the IP address as achrn
                    Instagram
                    Twitter
                    • achrnundefined
                      achrn @mfs12
                      @mfs12 said in PanelDue Firmware 3.5.0-rc9 released:
                      It doesn't seem to be working that way for me - if I power on and not touch anything for ten minutes, then go to setup it still has 0.0.0.0.
                      If I press the reset button on the paneldue so it restarts after the mainboard and Pi have been up and idle for about 30 minutes, then let the paneldue sit for a couple of minutes more (long enough that the screen blanks), then go to Setup, still 0.0.0.0
                      Everything else seems to be working.
                      • mfs12undefined
                        mfs12 @achrn
                        @achrn the missing IP addr might be due to SBC mode. I am clarifying this.
                        achrnundefined 1 Reply Last reply Reply Quote 0
                        • Phaedruxundefined Phaedrux referenced this topic
                        • mfs12undefined
                          mfs12 @achrn
                          Hey @achrn,
                          so about you ip address issue.
                          Paneldue displays only the ip address of the first (index 0) network interface.
                          In SBC mode currently in any case the RRF's ip address of interface 0 is displayed which is in SBC mode always 0.0.0.0 as the SBC handles the ip connection.
                          In future this might change that the OM request is forward to SBC which then reports back the SBC's ip address.
                          If you feel eager to request a more sophisticated ip address displaying feel free to drop a feature request in the forum.
                          I hope this helped you.
                          • achrnundefined
                            achrn @mfs12
                            @mfs12 Thanks for the detail.
                            It's not a problem - I just noticed it was 0.0.0.0 The fact that I hadn't noticed that it must have been that in all previous versions too suggests it's not a big problem!
                            • blt3dpundefined
                              blt3dp @mfs12
                              Just wanted to come back around to this, i had updated to the 3.5.0 release and saw the same thing. I noticed something when using DWC to move a gcode to a folder, i got a permissions error. I ssh into my pi and checked the owner of everything in the gcodes, macros, and sys. Turns out that when I followed the instructions to update the os on the pi (involved backing up those items, imaging the sd card, and sftp the backed up files back) that those items took on the owner of the user i was connected through sftp with, which was pi. I went through gcodes, macros, and sys and did 'sudo chown dsf:dsf folderorfilename' and now everything is showing up normally for me in Panel Due
                              Instagram
                              Twitter
