how to do escape homing using sensor?
@Phaedrux
In Escape homing method, in 1st pass, axis moves towards the sensor a little more than sensing area & then in 2nd pass move axis in opposite direction until axis is outside of sensing area, where I would like to define 0 for X & Y axis respectively.
So basically, after sensing in 1st pass, I want axis to move by a fixed distance outside of sensing area to define 0. Just how some people escape sensing to define origin. -
Maybe like this for X, calling
M98 P"escape-homex.g
from homex.g:; escape-homex.g example macro ; UNTESTED PROCEED AT YOUR OWN RISK ; safeguard if {sensors.endstops[0].endstopType = "motorStallAny" || sensors.endstops[0].endstopType = "motorStallIndividual" || sensors.endstops[0].endstopType="unknown"} abort "unsupported endstop type" ; travel speeds var fast_travel=3600 var slow_travel=600 ; determine homing move direction and length. ; this accounts for negative axis minima on center-zeroed or endstop offsets. var homing_move_length=abs(move.axes[0].min)+ move.axes[0].max + 5 var backoff_direction = 1 ; endstop at axis max if{sensors.endstops[0].highEnd} set var.backoff_direction=-1 ; endstop at axis min else set var.backoff_direction=1 ; standard homing pass if{sensors.endstops[0].highEnd G1 H1 X{var.homing_move_length} F{var.fast_travel} else G1 H1 X-{var.homing_move_length} F{var.fast_travel} ; relative positioning G91 ; move one hundredth of a millimeter until endstop stops triggering. while {sensors.endstops[0].triggered} G0 X{0.01 * var.backoff_direction} F{var.slow_travel} M400 ; back to absolute position G90 M400 ; set axis position according to endstop arrangement if {sensors.endstops[].highEnd} G92 X{move.axes[0].max} else G92 X{move.axes[0].min} That said, to achieve a very similar effect, the convention in RRF is to do a fast homing move, backing off from the endstop for a short length, and then to do a slow homing move. Both approaches reduce the effect of overtravel on repeatability of the homing prodecure.
EDIT: This script is a little bit more complex than it would need to be to show the escape homing mechanism since I had to get this "generalized homing macro" idea out of my head. The part @R006 is interested happens in lines 30 to 37.
I'd never heard of it, but how about:
- do a move until the endstop is triggered
- redefine the endstop with inverted polarity
- put the endstop back to correct polarity
So Y axis might be:
G91 ; relative moves M574 Y1 S1 P"ystop" ; proper endstop polarity G1 H1 Y-720 F1440 ; do homing move @1440 G1 Y-2 F1440 ; touch more M574 Y1 S1 P"!ystop" ; reverse polarity G1 H1 Y10 F360 ; home to release at quarter the speed G90 ; return to absolute G92 Y0 ; set zero M574 Y1 S1 P"ystop" ; reset endstop polarity It seems to work on my sand table (which has a continuous rotation Y axis with optical endstop, so there's no mechanical limit to crash into). The endstop triggers over a range of about 6 units in Y, so this moves until it first triggers, moves one third into the triggered region, then backs out.
It does actually seem a tidier home move (less of a dance).
@achrn endstop inversion is a great idea! Much cleaner than my whole loop.
I forgot about it even though I used it with a Z probe as X endstop on a machine for a while ...
Having thought about this more, I think it suits my sand table more than the 'classic' homing approach, so I'm going to adopt it. Thanks @R006 for highlighting it. (On teh other hand, 99% of the time I don't need the table homed on this axis - the pattern will just face a different direction, and it's truly unlimited continuous rotation mechanically.)
My previous code snippet misbehaves if the endstop is already triggered when first called and the 'touch more' movement drives it out of triggered, so I've actually adopted:
G91 ; relative moves M574 Y1 S1 P"ystop" ; proper endstop polarity if sensors.endstops[1].triggered = false G1 H1 Y-720 F1800 ; do homing move @1800 (5 rpm, 12 secs per rev) G1 H2 Y-2 F1800 ; move slightly further - endstop zone is approx 6 wide M574 Y1 S1 P"!ystop" ; reverse polarity G1 H1 Y10 F360 ; home to release at 1 rpm G92 Y0 ; set zero M574 Y1 S1 P"ystop" ; reset endstop polarity G90 ; absolute moves
