    Overview of .g files
    834
    • Falc.be
      Falc.be last edited by
      I want to see a full list of possible g files than can be called from the firmware
      Doesnt seem to be in the wiki
      • Dougal1957
        Dougal1957 last edited by
        http://reprap.org/wiki/Gcodes
        • Falc.be
          those are the gcode. I asked if there was a list of the .g files
          • deckingman
            deckingman last edited by
            AFAIK, all available .g files can be found in your .sys folder
              And of course you can create your own GCode files and put them in the /macros folder to make them easy to run.
              • Falc.be
                Let me put it another way
                I am looking for a list of .g files that are predefined in the firmware like pause.g, home files, config.g etc
                • deckingman
                  @Falc.be:
                  I don't know how to put my answer any other way excepts maybe this:
                  Open your sys folder and there you will see a list of all the .g files.
                    There is a list at https://duet3d.com/wiki/SD_card_folder_structure.
                    • bot
                      bot last edited by
                      That list seems to not include the tool change g code files, so it doesn't appear to be a complete list.
                      I think Falc.be is looking for an exhaustive list of every g code filename that is or can be referenced by the firmware directly, in special circumstances.
                      Not a list of g code files on his sd card, and not the "minimum required" g code files.
                      *not actually a robot
