    mainboard 6d not answering
    Firmware installation
    714
    • zecretonundefined
      zecreton @Phaedrux
      @Phaedrux how do i change it?
        The computer must be connected to the same network as the Duet to be able to communicate with it.
        zecretonundefined 1 Reply Last reply Reply Quote 0
        • zecretonundefined
          zecreton @Phaedrux
          @Phaedrux i don't understand, i only have one network
            What is the IP address of your computer?
            • zecretonundefined
              zecreton @Phaedrux
              @Phaedrux it is 10.0.0.14 i think
                If that is your internal IP address then your Duet isn't on the same network.
                • zecretonundefined
                  zecreton @Phaedrux
                  @Phaedrux if i connect my pc and the mainboard with an ethernet wire it should be the same right?
                    Yes, you can follow the directions here
                    https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
                    • zecretonundefined
                      zecreton @Phaedrux
                      @Phaedrux it says permission denied when i try to connect to the mainboard by CuteCom
                      • zecretonundefined
                        zecreton @zecreton
                        @Phaedrux i got it, thank you for all the help
