mainboard 6d not answering
@Phaedrux i don't understand, i only have one network
What is the IP address of your computer?
@Phaedrux it is 10.0.0.14 i think
If that is your internal IP address then your Duet isn't on the same network.
@Phaedrux if i connect my pc and the mainboard with an ethernet wire it should be the same right?
Yes, you can follow the directions here
https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
@Phaedrux it says permission denied when i try to connect to the mainboard by CuteCom
@Phaedrux i got it, thank you for all the help
