    motor not moving
    MultiAxis Printing
    3.3k
      I don't know about that, but I know you can get a USB SD card reader for a few dollars.
      zecretonundefined 2 Replies Last reply Reply Quote 0
      • zecretonundefined
        zecreton @Phaedrux
        @Phaedrux ok i'll look for that, thank you
        • zecretonundefined
          zecreton @Phaedrux
          @Phaedrux i have the sd card reader, now what am i supposed to do so i can access dwc?
            Can you take a screen shot of what your root folders look like on the SD card?
            Is there a folder named WWW?
            Download this zip file
            https://github.com/Duet3D/DuetWebControl/releases/download/v3.5.2/DuetWebControl-SD.zip
            Extract the contents into the WWW folder. Replacing the files that are there if they are there.
            Try connecting again.
            zecretonundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
            • zecretonundefined
              zecreton @Phaedrux
              • zecretonundefined
                zecreton @Phaedrux
                @Phaedrux there is already a file named DuetWebControl-SD.zip, is that normal?
                  Phaedrux Moderator @Phaedrux
                  @Phaedrux said in motor not moving:
                  zecretonundefined 1 Reply Last reply Reply Quote 0
                  • zecretonundefined
                    zecreton @Phaedrux
                    @Phaedrux so the only files that should be left in www are the ones in the dwc sip file?
                    • zecretonundefined
                      zecreton @zecreton
                      @zecreton *zip
                        Yes. You can delete the entire contents of the WWW folder and replace it with the contents of the zip file.
                        zecretonundefined 3 Replies Last reply Reply Quote 0
                        • zecretonundefined
                          zecreton @Phaedrux
                          @Phaedrux i did it, the status light is now flashing again, but i still can't access dwc
                          • zecretonundefined
                            zecreton @Phaedrux
                            @Phaedrux nvm it's all working, it's just that the ip adress changed
                            • zecretonundefined
                              zecreton @Phaedrux
                              @Phaedrux im pretty sure the driver is the problem, bc from what we tested before deleting the firmware, the mainboard was sending signals but not the driver
                                Phaedrux Moderator @zecreton
                                @zecreton said in motor not moving:
                                @droftarts you think it could be the motor? i have another motor i could try it with
                                So we're back to here then?
                                • zecretonundefined
                                  zecreton @Phaedrux
                                  @Phaedrux yea, but i already tried another motor but not the driver
                                  • zecretonundefined
                                    zecreton @Phaedrux
                                    @Phaedrux i tried another driver, it still doesn't work
                                      Can you be more detailed on what you've actually changed?
                                      • zecretonundefined
                                        zecreton @Phaedrux
                                        @Phaedrux i had another driver that is smaller and goes with a smaller motor, so i changed both but kept the same wires
                                          Please more detail than that. When you changed drivers, did you change the config.g to map the axis to the other driver? Did you alter the motor current to match the driver? Photos of your wiring?
                                          The more detail you provide the better chance we have of understanding what is going wrong.
                                          • zecretonundefined
                                            zecreton @Phaedrux
