    motor not moving
    MultiAxis Printing
    3.3k
      droftarts administrators @zecreton
      @zecreton said in motor not moving:
      @droftarts i am sending this : g92 [X400]
      That sets the axis position, but doesn't move the axis. Are you sending anything after that? eg G1 X500 F1000. Or move the X axis using the buttons in DWC.
      @droftarts switch 5,6,7 and 8 are off
      I think that's correct.
      zecretonundefined 3 Replies Last reply Reply Quote 0
      • zecretonundefined
        zecreton @droftarts
        @droftarts the brake seem to be always on, is that normal?
        • zecretonundefined
          zecreton @droftarts
          @droftarts still nothing works
          • zecretonundefined
            zecreton @droftarts
            @droftarts hello?
              @zecreton Does your motor have a brake? Post a picture of the motor and model number. If the motor does have a brake, you'll need to wire the brake wires to the BRK/PEND outputs of the driver, and change SW8 to off. If there's no brake, the setting of this switch doesn't matter. If you mean that you can't turn it once it's switched on, that probably means it is enabled.
              Try switching SW6 to 'on', to enable open loop mode. If there's a wiring problem for the encoder that is stopping the motor turning, this should ignore it.
              How are the switches SW1 to SW4 set? Perhaps post a photo of the switches. They should be set for 3200 steps per revolution to match the config.g, ie SW1 to SW4 should be off, off, on, on.
              Please list the exact commands you are sending before and while trying to move the axis.
              zecretonundefined 2 Replies Last reply Reply Quote 0
              • zecretonundefined
                zecreton @droftarts
                • zecretonundefined
                  zecreton @droftarts
                  @droftarts i am sending G1 X200
                    @zecreton that motor does not look like it has brake.
                    Have you changed SW1 to SW4 and SW6 as I suggested? What voltage is the power supply you have connected to the driver?
                    After power on, send the following:
                    G92 X100
                    This sets the axis position. In DWC, check that the axis position for X is 100.
                    G1 X600 F2000
                    This should move the motor 500mm to X600, and will take 15 seconds (500mm / 2000mm/m = 1/4 minute = 15 seconds). Check in DWC that it reports the axis position at the end of the move as X600.
                    If this doesn’t work, check for any error messages in the console.
                    Please report what of the above works or doesn’t work, and the reported axis position after each step.
                    Does the red LED on the driver flash? If so, this signifies an error. See the driver manual to interpret the error code.
                    3.5 LED Status Lights
                    There are two LED lights. The GREEN one is the power indicator which should be always on in normal circumstance. The RED one is a alarm status indication light, which will be OFF while working normally but ON and flash some times in a 3-second period in the case of enabled alarm protections.
                    Driver and motor product page and manual: https://www.omc-stepperonline.com/ts-series-12-0-nm-1699-68oz-in-1-axis-closed-loop-stepper-cnc-kit-nema-34-motor-driver-1-cl86t-s120-v41
                    • zecretonundefined
                      zecreton @droftarts
                      @droftarts yes i did change the switches, the power supply has a voltage of 24v
                      • zecretonundefined
                        zecreton @droftarts
                        @droftarts the reported axis position is correct, there is no error anywhere
                        • zecretonundefined
                          zecreton @droftarts
                          @droftarts but the motor doesn't move at all
                            @zecreton that means that the 6XD is most likely sending the correct signal.
                            Please answer my other questions.
                            zecretonundefined 1 Reply Last reply Reply Quote 0
                            • zecretonundefined
                              zecreton @droftarts
                              @droftarts the reported axis position after the first step is 100, and after the second, 600, the reported speed is 33.33mm/s and it takes about 15 seconds
                                @zecreton These questions:
                                • zecretonundefined
                                  zecreton @droftarts
                                  @droftarts yes i did change the switches, the power supply is a 24v and no the red led doesn't flash
                                  • zecretonundefined
                                    zecreton @droftarts
                                    @droftarts you think it could be the motor? i have another motor i could try it with
                                    • zecretonundefined
                                      zecreton @droftarts
                                      @droftarts where is the big black wire for the encoder supposed to be connected?
                                        @zecreton It says on this page, under the 'Encoder Extension Cable Connection' table: https://www.omc-stepperonline.com/ts-series-12-0-nm-1699-68oz-in-1-axis-closed-loop-stepper-cnc-kit-nema-34-motor-driver-1-cl86t-s120-v41
                                        PLEASE NOTE: The thick black wire can be used for shielding, but it is not required, so you can leave it unconnected.
                                        I really don't know why this isn't working for you. Do you have an oscilloscope, so you can check the output from the 6XD? Can you set the driver up with an Arduino to test it? There are tutorials around to do this quite simply, for example https://youtu.be/FggSRQqB_a4
                                        • zecretonundefined
                                          zecreton @droftarts
                                          @droftarts hey, i tested the mainboard and it works, but i hit the erase jumper and now the firmware is gone, and when i try to reinstall it with bossa, it says the file doesn't exist
                                            @zecreton what file doesn’t exist?
                                            Use file “Duet3Firmware_MB6XD.bin” from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.2 in Bossa.
