    motor not moving
    MultiAxis Printing
    3.3k
    • zecretonundefined
      zecreton @Phaedrux
      @Phaedrux i did it, the status light is now flashing again, but i still can't access dwc
      • zecretonundefined
        zecreton @Phaedrux
        @Phaedrux nvm it's all working, it's just that the ip adress changed
        • zecretonundefined
          zecreton @Phaedrux
          @Phaedrux im pretty sure the driver is the problem, bc from what we tested before deleting the firmware, the mainboard was sending signals but not the driver
            Phaedrux Moderator @zecreton
            @zecreton said in motor not moving:
            @droftarts you think it could be the motor? i have another motor i could try it with
            So we're back to here then?
            zecretonundefined 2 Replies Last reply Reply Quote 0
            • zecretonundefined
              zecreton @Phaedrux
              @Phaedrux yea, but i already tried another motor but not the driver
              • zecretonundefined
                zecreton @Phaedrux
                @Phaedrux i tried another driver, it still doesn't work
                  Can you be more detailed on what you've actually changed?
                  zecretonundefined 1 Reply Last reply Reply Quote 0
                  • zecretonundefined
                    zecreton @Phaedrux
                    @Phaedrux i had another driver that is smaller and goes with a smaller motor, so i changed both but kept the same wires
                      Please more detail than that. When you changed drivers, did you change the config.g to map the axis to the other driver? Did you alter the motor current to match the driver? Photos of your wiring?
                      The more detail you provide the better chance we have of understanding what is going wrong.
                      zecretonundefined 3 Replies Last reply Reply Quote 0
                      • zecretonundefined
                        zecreton @Phaedrux
                        • zecretonundefined
                          zecreton @Phaedrux
                          @Phaedrux i didn't change the config.g file and i didn't change the motor current and idk how to do that
                          • zecretonundefined
                            zecreton @Phaedrux
                            @Phaedrux said in motor not moving:
                            Idk what to put there
                              Sorry I forgot you were working with external drivers here.
                              As this thread has grown to nearly 100 posts and has involved several issues, I think it may be best if you can create a new thread with a detailed restatement of your current issue. Please include the basic details of your setup and the hardware used. Please include your config.g as well.
