    Setting up Cartesian Printer.
    98
    15.2k
    • Corexyundefined
      Corexy
      As mentioned in my other thread, I'm absolutely new at this and trying hard to learn and figure things out myself.
      Here's where I'm at so far, as per the configuration tool:
      ; Configuration file for Duet WiFi
      ; generated by RepRapFirmware Configuration Tool on Fri Oct 21 2016 19:22:39 GMT+1100 (AUS Eastern Daylight Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M208 X195 Y195 Z175 S0 ; Set axis maxima
      M574 Z0 S0 ; Define active low and unused microswitches
      M574 X2 Y2 S1 ; Define active high microswitches
      M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 P600 X1 Y1 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
      M92 X80 Y80 Z800 E420 ; Set steps per mm
      M203 X12000 Y12000 Z600 E2700 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M305 P0 T100000 B4000 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 C0 R4700 L0 H0 X201 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 201
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 X0 Y0 ; Set tool 0 axis offsets
      M550 PZortrax M200 ; Set machine name
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      • Corexyundefined
        Corexy
        I had to reverse drives 0,1 and 2 so that when homing all the X and Y axis' stopped on the limit switches and the Z axis raised up toward the IR probe.
        Issues I'm seeing straight up are:
        When homing the Z axis, it is activating the IR sensor LEDs but still hits the nozzle. I'm assuming I've got to set some offset somewhere? If so, how?
        • T3P3Tonyundefined
          T3P3Tony administrators
          The direction of the drives depends on the wiring of the stepper motors so if they are going the opposite way to expected then simply use M569 P1 S0 or M569 P1 S1 to change the direction of drive 1. Change the inner after the P parameter to.select the drive.
          The Z offset is set using G31 but first setup your probe type using M558. Have a look at the RepRap wiki for more gcode information:
          http://reprap.org/wiki/G-code#M558:_Set_Z_probe_type
          www.duet3d.com
          • Corexyundefined
            Corexy
            @T3P3Tony:
            Thank you.
            I already had selected the IR probe via the configurator, and it looks like I have it set correctly in M558 (P1 unmodulated IR probe?).
            I'm not sure what to type in to G31 It does seem to be triggering at about 2.5mm…do I need to enter an offset value?
            Should X and Y be 0 not 1, as I don't use the IR probe for those axis'?
            • perolalarsundefined
              perolalars
              Hi Corexy
              dont know so much about this but I found the section "Setting probe parameters" at https://duet3d.com/wiki/Setting_up_automatic_probing_of_the_print_bed very helpful!
              • T3P3Tonyundefined
                Yes X0 and Y0
                Z2.5 means the trigger height is 2.5mm
                Test far away from you bed to avoid crashing your nozzle
                www.duet3d.com
                • Dougal1957undefined
                  Dougal1957
                  And if your using DC42's excellent Mini IR Sensor then the P parameter should be P500
                  Doug
                  • Corexyundefined
                    Corexy
                    @perolalars:
                    Hi Corexy
                    Thanks very much!
                    • Corexyundefined
                      Corexy
                      @T3P3Tony:
                      Yes X0 and Y0
                      And trigger height is used to set the offset?
                      By that I mean if I'm crashing the nozzle I increase the trigger height?
                      I know it sounds dumb, but I thought the trigger height and offset were 2 different things.
                      All of this is language/terms I haven't heard used before.
                      • Corexyundefined
                        Corexy
                        @Dougal1957:
                        Doug
                        I am, and I will change that. thank you as well.
                        And that all helped.
                        Possibly the P500 setting, but I changed the trigger height to 4mm to be safe and it ended up about there.
                        So now according to the wiki I have to set the height so as to pin a sheet of paper to the bed and enter "G92 Z0".
                        Will I insert that code just after G31?
                        I'll clean and level the bed properly before I carry out that step tomorrow.
                        Cheers again
                          Dougal1957
                          see DC42's post in https://www.duet3d.com/forum/thread.php?id=358 which should explain how to determine your Z Param for the G31 line.
                          Basically home the printer
                          move the nozzle to the bed using the paper test
                          send G92 Z0
                          move the nozzle up 5mm or so
                          send G30 S-1 to probe the bed read the Z height of either the web IF or PanelDue and note down
                          Repeat a few time to ensure repeatability and you should have found your Z Trigger height (This is actually the height of the nozzle when the probe triggers.)
                          Hope this helps.
                          Doug
                          • Corexyundefined
                            Corexy
                            This might be a blunder on my part, or a mistake in the config tool, but check this out:
                            On the lower board, the terminal blocks labelled RTD1 and RTD2 will be temperature measurement channels 200 and 201 respectively.
                            I entered RTD1 into the config tool and ended up with:
                            This might explain why my hot end is reading at 2000degC at room temp??
                            I'll try changing it to 200 and see what happens.
                            And yes, that put me with 0.5degC of the bed temp
                            Which would also mean that David's estimated settings for the bed thermistor were pretty good as well.
                              Dougal1957
                              That would make a difference yes
                                Regarding G31 P600 X1 Y1 Z2.5 ; Set Z probe trigger value, offset and trigger height:
                                1. Increasing the probe trigger height (G31 Z parameter) will make a bed crash more likely, because after the probe triggers, the firmware will think it can go down further before it reaches Z=0. You need to measure the trigger height as described in the IR sensor fitting instructions, and use that value.
                                2. The X and Y parameters are the offsets of the sensor sensitive area (just below the black capacitor) from the nozzle. They get subtracted from the XY coordinates in your bed.g file, so that the sensor is over those points during probing, not the nozzle.
                                3. You must always use P500 with the IR sensor.
                                HTH David
                                • Corexyundefined
                                  Corexy
                                  @dc42:
                                  HTH David
                                  Thank you. I'll read the wiki a bit more.
                                  Just starting to get my head around it all.
                                  • Corexyundefined
                                    Corexy
                                    With my homing I am concerned whether I entered the right information in the config tool.
                                    I am pretty sure I entered "high" for all axis'.
                                    My X and Y limit switches are both in the front/left corner, and I had to reverse/enter a 0 value all 3 drives to get them to home to the right position.
                                    Moving them manually with the paneldue I have to use + movement to move towards the homing position.
                                    Is that correct?
                                    It does seem so according to the wiki (I think), and I just want to be sure before I set the Z home position, which is currently in the right rear corner and I'd like to move it to the center
                                    Here's how I'm set up at the moment:
                                    G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                                    • Corexyundefined
                                      Corexy
                                      Re run the config tool and left the high/low settings at their defaults.
                                      Still had to reverse 2 steppers, but I realize this would be just due to wiring connections.
                                      It now homes Z in the back/left corner, and I'd like to set my Z probe height/offset in the center.
                                      My question is: Do I have the correct high/low settings for my machine which has the limit switches in the front/left corner of the gantry?
                                      If not, could someone show me what changes to make?
                                      I've gone through the wiki but am unsure.
                                      Here's where I'm at now:
                                      M574 X1 Y2 S1 ; Define active high microswitches
                                      • StephenRCundefined
                                        StephenRC
                                        Edit homez.g and homeall.g to put the probe/hotend where you want it to be for homing.
                                        • Corexyundefined
                                          Corexy
                                          @StephenRC:
                                          Nice!
                                          I was only doing it in homez.g. Didn't realize it had to be done in both.
                                          Could someone confirm my X Y axis high/low settings in my question above please?
                                            You need to decide where you want X=0 Y=0 to be. That in turn will fix which is the X axis and which is the Y axis. If you choose front left, X will be left-right and Y will be front-back. If you choose rear left then X will be back-front and Y will be left-right.
                                            Having chosen where the origin will be, set the X and Y motor directions so that +X and +Y move the head away from that corner. You may need to swap the X and Y motor connections over to achieve this.
                                            Then use config tool to specify whether each homing switch is at the low or the high end of its axis, to generate the correct M574 command and homing files. You don't need to home to the origin, you can home to zero on some axes and to max on others.
