Problems from the second layer to the 7th layer
1.2k
  • undefined
    carlinicompetizione
    I'm having problems with over extrusion from the second layer to the seventh or so. I've already used avance presion but it doesn't solve the problem, it only makes it worse because it thickens the filling even more.
    or from the 7th to the 8th layer, the printing normalizes and in some cases even due to the lack of plastic.
    I'm using the filament monitor
    undefined undefined 3 Replies Last reply 17 Jun 2024, 08:18 Reply Quote 0
    • undefined
      droftarts administrators @carlinicompetizione
      @carlinicompetizione please post response to M122 and config.g
      I expect you are using bed mesh compensation? Is your bed particularly uneven? If you have bed mesh taper set M376 https://docs.duet3d.com/User_manual/Reference/Gcodes#m376-set-bed-compensation-taper, what layer height are you printing at?
      • undefined
        carlinicompetizione
        Muito obrigado, não entendo nada de programação, mas acrescentei no config.g essas funções M375 e M376
        • undefined
          carlinicompetizione
          M122
          RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (standalone mode)
          Board ID: 08DJM-9P63L-DJ3S0-7JTDJ-3SD6N-TSJ79
          Used output buffers: 3 of 40 (14 max)
          Static ram: 152760
          Dynamic ram: 97688 of which 0 recycled
          Never used RAM 100080, free system stack 132 words
          Tasks: NETWORK(ready,30.7%,238) ETHERNET(notifyWait,0.1%,561) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,260) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,8.8%,57) MAIN(running,60.4%,1101) IDLE(ready,0.0%,30), total 100.0%
          Owned mutexes:
          Last reset 00:04:19 ago, cause: software
          Last software reset at 2024-06-19 01:09, reason: User, GCodes spinning, available RAM 97020, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 126
          MCU temperature: min 41.4, current 42.1, max 42.3
          Supply voltage: min 24.2, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 808, reads 54266, writes 14 timeouts 0
          Driver 1: ok, SG min 0, mspos 0, reads 54259, writes 21 timeouts 0
          Driver 2: standstill, SG min 0, mspos 552, reads 54260, writes 21 timeouts 0
          Driver 3: standstill, SG min 0, mspos 520, reads 54260, writes 21 timeouts 0
          Driver 4: standstill, SG min 0, mspos 936, reads 54260, writes 21 timeouts 0
          Driver 5: standstill, SG min 0, mspos 728, reads 54260, writes 21 timeouts 0
          Date/time: 2024-06-19 01:13:42
          Slowest loop: 25.68ms; fastest: 0.05ms
          === Storage ===
          Free file entries: 8
          SD card 0 detected, interface speed: 25.0MBytes/sec
          SD card longest read time 3.4ms, write time 0.0ms, max retries 0
          DMs created 125, segments created 6, maxWait 165988ms, bed compensation in use: mesh, comp offset -0.038
          === MainDDARing ===
          Scheduled moves 7, completed 6, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Heater 0 is on, I-accum = 0.4
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by File
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 2 15, running macro
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === Filament sensors ===
          Extruder 0: pos 239.77, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
          === CAN ===
          Messages queued 2361, received 5209, lost 0, boc 0
          Longest wait 3ms for reply type 6053, peak Tx sync delay 173, free buffers 50 (min 49), ts 1298/1297/0
          Tx timeouts 0,0,0,0,0,0
          === Network ===
          Slowest loop: 5.05ms; fastest: 0.03ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          HTTP sessions: 1 of 8
          = Ethernet =
          State: active
          Error counts: 0 0 0 0 0 0
          Socket states: 5 2 2 2 2 2 0 0
          === Multicast handler ===
          Responder is inactive, messages received 0, responses 0
          • undefined
            carlinicompetizione
            config.g
            ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sat Jun 24 2023 18:49:15 GMT-0300 (Horário Padrão de Brasília)
            M83 ; but relative extruder moves
            M550 P"UNO Print" ; set printer name
            ; Wait a moment for the CAN expansion boards to start
            G4 S2
            M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
            M586 P0 S1 ; enable HTTP
            M586 P1 S1 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0.1 S0 ; physical drive 0.1 goes forwards
            M569 P0.2 S0 ; physical drive 0.2 goes forwards
            M569 P0.3 S1 ; physical drive 0.3 goes forwards
            M569 P0.4 S0 ; physical drive 0.4 goes forwards
            M569 P0.5 S0 ; physical drive 0.5 goes forwards
            M584 X0.1 Y0.2:0.3 Z0.4:0.5 E0.0 ; set drive mapping
            M92 X67.00 Y67.00 Z1650.50 E370.00 ; set steps per mm
            M566 X500.00 Y500.00 Z300.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X3000.00 Y3000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z250.00 E1200.00 ; set accelerations (mm/s^2)
            M906 X1680 Y1600 Z1600 E900 I90 ; set motor currents (mA) and motor idle factor in per cent
            M84 S75 ; Set idle timeout
            ;M208 X0 Y0 Z0 S1 ; set axis minima
            M208 X700 Y400 Z400 S0 ; set axis maxima
            M574 X1 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
            M574 Y1 S1 P"io1.in+io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in+io2.in
            M574 Z2 S1 P"io4.in+io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io3.in+io4.in
            M574 Z1 S2
            ;M574 X1 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
            ;M574 Y1 S1 P"io1.in+io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in+io2.in
            ;M574 Z1 S1 P"io3.in+io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io3.in+io4.in
            ;M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            ;M574 Z1 S1 P"io3.in+io4.in" ; configure endstop for high end on Z
            M308 S0 P"temp0" Y"pt1000" ; configure sensor 0 as PT1000 on pin temp0
            M308 S1 P"121.temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin 121.temp0
            M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
            M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
            M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
            M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
            M950 S0 C"121.io0.out" ; Duet 3 MB6HC
            M558 P9 C"121.io0.in" H5 F120 T6000 ; Duet 3 MB6HC
            G31 P500 Y0 ; set Z probe trigger value, offset and trigger height
            G31 P500 X0 Z0.85 ; set Z probe trigger value, offset and trigger height
            M557 X125:650 Y50:350 S262.5:150 ; define mesh grid
            M375 ; Salva o mapa da grid do autolevel
            M376 H10 ; corrige a sobre extrusão na compensaão até 5%
            M575 P1 S1 B57600
            ;M572 D0 S0.4 ; definir o avanço de pressão da extrusora 0 para 0,1 segundos
            M950 D1 C"spi.cs0+spi.cs2" ; PanelDue
            M591 D0 P3 C"io6.in" S1 R5:170 ; filament monitor connected to io6.in
            undefined 1 Reply Last reply 10 Jul 2024, 21:56 Reply Quote 0
            • undefined
              carlinicompetizione @carlinicompetizione
              Firstly, thank you very much for responding, I have already included the requested information, M122 and config.g
              In that same file I added the functions M374 -M375-M376H25, there were no changes, the subsequent layers of the first one have excess plastic for at least 5 years after the first one, then it starts to normalize. I'm very sad because I don't know what to do.
              • undefined
                M122
                === Diagnóstico ===
                RepRapFirmware para Duet 3 MB6HC versão 3.4.5 (2022-11-30 19:35:23) rodando em Duet 3 MB6HC v1.01 (modo autônomo)
                ID da placa: 08DJM-9P63L-DJ3S0- 7JTDJ-3SD6N-TSJ79
                Buffers de saída usados: 3 de 40 (14 no máximo)
                Memória RAM estática: 152760
                Memória RAM dinâmica: 97688 dos quais 0 reciclados
                Nunca usei RAM 100080, pilha de sistema livre 132 palavras
                Tarefas: REDE (pronto ,30,7%,238) ETHERNET(notifyWait,0,1%,561) HEAT(notifyWait,0,0%,322) Mover(notifyWait,0,0%,260) CanReceiv(notifyWait,0,0%,797) CanSender(notifyWait,0,0%,336 ) CanClock(atrasando,0,0%,339) TMC(notifyWait,8,8%,57) MAIN(em execução,60,4%,1101) IDLE(pronto,0,0%,30), total de 100,0% de
                mutexes de propriedade:
                === Plataforma == =
                Última redefinição 00:04:19 atrás, causa: software
                Última redefinição de software em 19/06/2024 01:09, motivo: Usuário, GCodes girando, RAM disponível 97020, slot 0
                Código de redefinição de software 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Tarefa MAIN Freestk 0 n/a
                Status do erro: 0x00
                Erros Aux0 0,0,0
                Intervalo máximo do temporizador de passo 126
                Temperatura MCU: min 41,4, corrente 42,1, máx 42,3
                Tensão de alimentação: min 24,2, corrente 24,3, máx 24,6, abaixo eventos de tensão: 0, eventos de sobretensão: 0, energia boa: sim
                Tensão do trilho de 12 V: mínimo 12,1, corrente 12,1, máximo 12,2, eventos de subtensão: 0
                Heap OK, manipuladores alocados/usados ​​0/0, memória heap alocada/usada/ reciclável 0/0/0, ciclos gc 0
                Eventos: 0 na fila, 0 concluídos
                Driver 0: parado, SG min 0, mspos 808, lê 54266, grava 14 timeouts 0
                Driver 1: ok, SG min 0, mspos 0, lê 54259 , grava 21 timeouts 0
                Driver 2: paralisação, SG min 0, mspos 552, lê 54260, grava 21 timeouts 0
                Driver 3: paralisação, SG min 0, mspos 520, lê 54260, grava 21 timeouts 0
                Driver 4: paralisação, SG min 0, mspos 936, lê 54260, grava 21 timeouts 0
                Driver 5: paralisação, SG min 0, mspos 728, lê 54260, grava 21 timeouts 0
                Data/hora: 19/06/2024 01:13:42
                Loop mais lento: 25,68 ms ; mais rápido: 0,05 ms
                === Armazenamento ===
                Entradas de arquivo gratuitas: 8
                cartão SD 0 detectado, velocidade da interface: 25,0 MBytes/seg
                Tempo de leitura mais longo do cartão SD 3,4 ms, tempo de gravação 0,0 ms, máximo de tentativas 0
                === Mover == =
                DMs criados 125, segmentos criados 6, maxWait 165988ms, compensação de cama em uso: malha, deslocamento de compensação -0,038
                === MainDDARing ===
                Movimentos agendados 7, concluídos 6, soluços 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], estado CDDA 3
                === AuxDDARing ===
                Movimentos agendados 0, concluídos 0, soluços 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], estado CDDA -1
                === Calor == =
                Aquecedores de cama 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, aquecedores de câmara -1 -1 -1 -1, erro no pedido 0
                O aquecedor 0 está ligado, I-accum = 0,4
                O aquecedor 1 está ligado, I-accum = 0,0
                Segmentos restantes: 0 O
                bloqueio de movimento mantido pelo arquivo
                HTTP está ocioso no(s) estado(s) 0 O Telnet está ocioso no(s) estado(s) 0 O arquivo está ocioso no(s) estado(
                s)
                s) 2 15, macro em execução
                O USB está ocioso no(s) estado(s) 0
                Aux está ocioso no(s) estado(s) 0
                O gatilho está ocioso no(s) estado
                (s) 0 A fila está ociosa no(s) estado(s) 0
                O LCD está ocioso no(s) estado(s) ) 0
                SBC está ocioso no(s) estado(s) 0
                Daemon está ocioso no(s) estado(s) 0
                Aux2 está ocioso no(s) estado(s) 0
                Autopause está ocioso no(s) estado(s) 0
                Fila de código está vazia
                === Sensores de filamento ===
                Extrusora 0: pos 239.77, errs: quadro 0 paridade 0 ovrun 0 pol 0 ovdue 0
                === CAN ===
                Mensagens na fila 2361, recebidas 5209, perdidas 0, boc 0
                Maior espera 3ms para tipo de resposta 6053, pico de atraso de sincronização Tx 173 , buffers livres 50 (min 49), ts 1298/1297/0
                Tempo limite de Tx 0,0,0,0,0,0
                === Rede ===
                Loop mais lento: 5,05 ms; mais rápido: 0,03 ms
                Estados da resposta: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                Sessões HTTP: 1 de 8
                = Ethernet =
                Estado: ativo
                Contagens de erros: 0 0 0 0 0 0
                Estados do soquete: 5 2 2 2 2 2 0 0
                configuração.g
                ; Arquivo de configuração do Duet 3 MB 6HC (firmware versão 3.3)
                ; executado pelo firmware na inicialização
                ; gerado pela ferramenta de configuração RepRapFirmware v3.3.16 em sábado, 24 de junho de 2023, 18:49:15 GMT-0300 (Horário Padrão de Brasília)
                ; Preferências gerais
                G90 ; enviar coordenadas absolutas...
                M83 ; mas a extrusora relativa se move
                M550 P"UNO Print"; definir o nome da impressora
                ; Aguarde um momento para que as placas de expansão CAN iniciem
                o G4 S2
                ; Rede
                M552 P0.0.0.0 S1 ; habilitar rede e adquirir endereço dinâmico via DHCP
                M586 P0 S1; habilitar HTTP
                M586 P1 S1; desabilitar FTP
                M586 P2 S0 ; desabilitar Telnet
                ; Aciona
                M569 P0.0 S1; drive físico 0.0 avança
                M569 P0.1 S0 ; a unidade física 0.1 avança
                M569 P0.2 S0 ; a unidade física 0.2 avança
                M569 P0.3 S1 ; a unidade física 0.3 avança
                M569 P0.4 S0 ; a unidade física 0.4 avança
                M569 P0.5 S0 ; unidade física 0,5 avança
                M584 X0.1 Y0.2:0.3 Z0.4:0.5 E0.0 ; definir mapeamento de unidade
                M350 X16 Y16 Z16 E16 I1 ; configurar microstepping com interpolação
                M92 X67.00 Y67.00 Z1650.50 E370.00 ; definir passos por mm
                M566 X500,00 Y500,00 Z300,00 E1200,00 ; definir alterações instantâneas máximas de velocidade (mm/min)
                M203 X3000.00 Y3000.00 Z1000.00 E1200.00 ; definir velocidades máximas (mm/min)
                M201 X500.00 Y500.00 Z250.00 E1200.00 ; definir acelerações (mm/s^2)
                M906 X1680 Y1600 Z1600 E900 I90 ; definir as correntes do motor (mA) e o fator de marcha lenta do motor em porcentagem
                M84 S75 ; Definir tempo limite de inatividade
                ; Limites do Eixo
                ;M208 X0 Y0 Z0 S1 ; definir mínimos do eixo
                M208 X700 Y400 Z400 S0 ; definir eixo máximo
                ; Paradas finais
                M574 X1 S1 P" 121.io2.in "; configure o fim de curso do tipo switch (por exemplo, microswitch) para low end em X via pino io0.in
                M574 Y1 S1 P" io1.in+io2.in " ; configure o fim de curso do tipo switch (por exemplo, microswitch) para extremidade inferior em Y via pino io1.in+io2.in
                M574 Z2 S1 P" io4.in+io5.in " ; configure o fim de curso do tipo switch (por exemplo, microswitch) para extremidade inferior em Y via pino io3.in+io4.in
                M574 Z1 S2
                ;M574 X1 S1 P" 121.io2.in " ; configure o fim de curso do tipo switch (por exemplo, microswitch) para low end em X via pino io0.in
                ;M574 Y1 S1 P" io1.in+io2.in " ; configure o fim de curso do tipo switch (por exemplo, microswitch) para extremidade inferior em Y via pino io1.in+io2.in
                ;M574 Z1 S1 P" io3.in+io4.in " ; configure o fim de curso do tipo switch (por exemplo, microswitch) para extremidade inferior em Y via pino io3.in+io4.in
                ;M574 Z1 S2 ; configure o fim de curso da sonda Z para extremidade inferior em Z
                ;M574 Z1 S1 P" io3.in+io4.in " ; configurar endstop para high end em Z
                ; Aquecedores
                M308 S0 P"temp0" Y"pt1000" ; configure o sensor 0 como PT1000 no pino temp0
                M950 H0 C"out0" T0 ; crie a saída do aquecedor do leito em out0 e mapeie-a para o sensor 0
                M307 H0 B1 S1.00 ; habilite o modo bang-bang para o aquecedor de cama e defina o limite PWM
                M140 H0 ; mapear cama aquecida para aquecedor 0
                M143 H0 S120 ; definir limite de temperatura para aquecedor 0 a 120C
                M308 S1 P"121.temp0" Y"pt1000" ; configure o sensor 1 como PT1000 no pino 121.temp0
                M950 H1 C"121.out0" T1 ; crie a saída do aquecedor do bico em 121.out0 e mapeie-a para o sensor 1
                M307 H1 B0 S1.00 ; desabilitar o modo bang-bang para aquecedor e definir limite PWM
                M143 H1 S280; definir limite de temperatura para aquecedor 1 a 280C
                ; Ferramentas
                M563 P0 D0 H1 F0 ; definir ferramenta 0
                G10 P0 X0 Y0 Z0 ; definir os corretores do eixo da ferramenta 0
                G10 P0 R0 S0 ; definir as temperaturas inicial da ferramenta 0 ativa e de espera para 0C
                ; Ventiladores
                M950 F0 C"121.out1" Q500 ; crie o ventilador 0 no pino 121.out1 e defina sua frequência
                M106 P0 S0 H-1 ; definir o valor do ventilador 0. O controle termostático está desligado
                M950 F1 C"121.out2" Q500 ; crie a ventoinha 1 no pino 121.out2 e defina sua frequência
                M106 P1 S1 H-1 ; definir o valor do ventilador 1. O controle termostático está desligado
                ; Sonda Z
                M950 S0 C"121.io0.out" ; Dueto 3 MB6HC
                M558 P9 C" 121.io0.in " H5 F120 T6000; Dueto 3 MB6HC
                G31 P500 Y0; definir valor de disparo da sonda Z, deslocamento e altura de disparo
                G31 P500 X0 Z0.85 ; definir valor de disparo da sonda Z, deslocamento e altura de disparo
                M557 X125:650 Y50:350 S262.5:150 ; definir grade de malha
                M375; Salva o mapa da grade do autolevel
                M376 H10 ; corrige a sobre extrusão na compensação até 5%
                ; As configurações personalizadas não estão definidas
                M575 P1 S1 B57600
                ; Diversos
                M501; carregar parâmetros salvos da memória não volátil
                M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; definir limites de tensão e ações para execução em caso de perda de energia
                M950 D1 C"spi.cs0+spi.cs2" ; PainelDue
                M591 D0 P3 C" io6.in " S1 R5:170 ; monitor de filamento conectado a io6.in
                undefined 1 Reply Last reply 2 Jul 2024, 00:59 Reply Quote 0
                • undefined
                  carlinicompetizione
                  Hi Ian, well unfortunately I'm very sad about the board, it should work well. I ask for your attention if possible and if there is any way you can help me. In the first layers, I detected that the table does not go down, it only does this from the 4th layer onwards, which is why it keeps accumulating plastic and stagnating the print. I've tried everything I've been told, I've used several slicers and in every case the same problem occurs. Is there a way to resolve this? via firmware putting the Mxx that helps solve it?, if putting a Rapberry PI 4 does it solve it?
                  undefined undefined 2 Replies Last reply 25 Jun 2024, 15:18 Reply Quote 0
                  • undefined
                    oliof @carlinicompetizione
                    @carlinicompetizione A raspberry pi does not help here. There is some chance that this is not a software, but a hardware issue, i.e. the mechanism raising the nozzle (or lowering the bed) may be binding until it overcomes the early layers.
                    You could try commanding the printer without issuing a full print, doing moves with the G0 and G1 commands after homing, to see how things behave.
                    undefined 2 Replies Last reply 25 Jun 2024, 15:42 Reply Quote 0
                    • undefined
                      @carlinicompetizione This sounds more like backlash in the Z axis, or the Z axis is sticking when it changes direction. If you move the bed up, then move it down in small increments, eg 0.1mm, does it move straight away, or only after a few moves? What Z height does DWC report at the beginning of the print, and what height when the bed starts to move? If you can see the Z motors, do they move, but the bed does not?
                      When you start a print, do you use baby stepping? Is the Z probe calibrated for Z height correctly?
                      undefined 2 Replies Last reply 25 Jun 2024, 15:45 Reply Quote 0
                      • undefined
                        carlinicompetizione @oliof
                        @oliof
                        So, it's not a mechanical problem, because it makes the home without problems or locks. the printer has large dimensions 400x 700 mm and Nema 17 motors of 0.8 kg/cm2, if there were any blockages the motors would make noise. In fact, they move, correcting the height of the Z of the map throughout the construction of the first layer, when it is finished, it does not change height for the next one and begins to deposit plastic, thickening too much. From the third layer onwards you feel the movement of the z when changing to the next layer.
                        • undefined
                          carlinicompetizione @droftarts
                          @droftarts
                          Yes, I use CR touch to create the map and I placed the M 374-M375 and M376 without success, it looks the same
                          I use Baby step to get the first layer right, which looks really good. From then on it does another three layers without going down, from the fourth down it goes down normally.
                          undefined 1 Reply Last reply 25 Jun 2024, 17:32 Reply Quote 0
                          • undefined
                            @carlinicompetizione I can hardly imagine that the machine would ignore some Z motion commands and then suddenly respect them again. Maybe share the start of a gcode file up to the layer where things work again?
                            undefined 2 Replies Last reply 25 Jun 2024, 17:53 Reply Quote 0
                            • undefined
                              @oliof
                              I will place a dial indicator on the table and activate the fan on the third layer to check if there is a change in the Z height
                              • undefined
                                @droftarts
                                I've read a forum where this happens, but I lost the link and I can't find anything about it, it gave some instructions to read. If I barely remember, the problem was related to a conflict with self-leveling that removed the first layers from the first.
                                • undefined
                                  @oliof
                                  In the settings made on the board, there is something wrong or something that could be improved or something that is missing. I know about jerk accelerations to some instruction that is missing for the automatic height adjustment in Z with the CR touch.
                                  undefined undefined 2 Replies Last reply 26 Jun 2024, 11:01 Reply Quote 0
                                  • undefined
                                    dc42 administrators @carlinicompetizione
                                    @carlinicompetizione have you tried reducing the Z speed and acceleration limits in the M203 and M201 commands? Your Z acceleration value in particular looks high to me.
                                    • undefined
                                      How much do you need to babystep to get the first layer looking good?
                                      Can you post the first 100-200 lines of a Gcode file that causes this problem? Or upload a whole Gcode file somewhere so we can take a look? It's possible the slicer is inserting speed/acceleration/jerk settings that are overriding those set in config.g.
                                      Some errors in your config.g:
                                      o G4 S2
                                      Remove the o from the beginning of the line.
                                      Do not use commas for decimal point. Use decimal point: .
                                      You have commented out the M208 minimum, but X0 Y0 Z0 is the default.
                                      Check your config.g is valid by sending M98 P"config.g", and check the response in the console. If there are any errors, please post the response in your reply.
                                      undefined 2 Replies Last reply 26 Jun 2024, 12:50 Reply Quote 0
                                      • undefined
                                        @droftarts said in Problems from the second layer to the 7th layer:
                                        M98 P"config.g"
                                        Hello, Ian
                                        I did the request and here is the answer
                                        M98 P"config.g"
                                        HTTP is enabled on port 80
                                        FTP is enabled on port 21
                                        TELNET is disabled
                                        Height map saved to file 0:/sys/heightmap.csv
                                        Error: Failed to load height map from file 0:/sys/heightmap.csv: invalid grid
                                        undefined 1 Reply Last reply 26 Jun 2024, 13:27 Reply Quote 0
                                        • undefined
                                          @droftarts
                                          400 lines Gcode with problem
                                          G-Code generated by Simplify3D(R) Version 5.1.2
                                          ; Jun 20, 2024 at 10:52:46 PM
                                          ; Settings Summary
                                          ; processName,PLA
                                          ; autoConfigureMaterial,PLA
                                          ; autoConfigureQualidade,High
                                          ; targetModels,suporte encoder Honda k20
                                          ; profileName,Projeto Uno
                                          ; profileVersion,2024-05-08 17:07:31
                                          ; app,S3D-Software 5.1.2
                                          ; technology,fff
                                          ; baseProfile,Default
                                          ; extruder,Extruder 1
                                          ; toolheadNumber,0
                                          ; nozzleDiameter,0.80000
                                          ; extrusionMultiplier,0.55000
                                          ; extrusionWidthMode,manual
                                          ; extrusionWidth,0.62000
                                          ; useRetraction,1
                                          ; retractDistance,6.50000
                                          ; extraRestartDistance,0.20000
                                          ; retractVerticalLift,0.00000
                                          ; retractSpeed,600.00000
                                          ; useCoasting,1
                                          ; coastingDistance,2.10000
                                          ; useWiping,1
                                          ; wipingDistance,6.00000
                                          ; speedMaxFlowRate,900.00000
                                          ; toolheadOffsetX,0.00000
                                          ; toolheadOffsetY,0.00000
                                          ; filamentDiameter,1.75000
                                          ; filamentPricePerKilogram,46.00000
                                          ; filamentDensity,1.25000
                                          ; primaryExtruder,Extruder 1
                                          ; layerHeight,0.20000
                                          ; topSolidLayers,7
                                          ; bottomSolidLayers,1
                                          ; outlinePerimeters,5
                                          ; useVaseMode,0
                                          ; useAdaptiveLayerHeights,0
                                          ; minAdaptiveLayerHeight,0.10000
                                          ; maxAdaptiveLayerHeight,0.40000
                                          ; adaptiveSmoothingLevel,5
                                          ; horizontalOuterCompensation,0.00000
                                          ; horizontalInnerCompensation,0.00000
                                          ; firstLayerUnits,percentage
                                          ; firstLayerHeightPercentage,117
                                          ; firstLayerWidthPercentage,100
                                          ; firstLayerSpeedPercentage,80
                                          ; firstLayerHeightAbsolute,0.30000
                                          ; firstLayerWidthAbsolute,0.40000
                                          ; firstLayerSpeedAbsolute,900.00000
                                          ; startPointStrategy,closest
                                          ; alignStartPointsX,0.00000
                                          ; alignStartPointsY,0.00000
                                          ; restrictStartPoints,0
                                          ; perimeterPrintingOrder,inside_out
                                          ; islandPrintingOrder,closest
                                          ; printInfillBeforePerimeters,0
                                          ; useSkirt,1
                                          ; skirtExtruder,Extruder 1
                                          ; skirtLayers,1
                                          ; skirtOffset,0.00000
                                          ; skirtOutlines,15
                                          ; useRaft,0
                                          ; raftExtruder,Extruder 1
                                          ; raftBaseLayers,2
                                          ; raftTopLayers,3
                                          ; raftOffset,3.00000
                                          ; raftSeparationDistance,0.14000
                                          ; raftSpeedUnits,percentage
                                          ; raftSpeedPercentage,30
                                          ; raftSpeedAbsolute,600.00000
                                          ; usePrimePillar,0
                                          ; primePillarExtruder,All Extruders
                                          ; primePillarWidth,12.00000
                                          ; primePillarLocation,north_west
                                          ; primePillarSpeedPercentage,100
                                          ; primePillarInfillPercentage,100
                                          ; autoStopPrimePillar,1
                                          ; primePillarLayersAfterAutoStop,0
                                          ; useOozeShield,0
                                          ; oozeShieldExtruder,All Extruders
                                          ; oozeShieldOffset,2.00000
                                          ; oozeShieldOutlines,1
                                          ; oozeShieldSidewallShape,waterfall
                                          ; oozeShieldSidewallAngle,30
                                          ; oozeShieldSpeedPercentage,100
                                          ; autoStopOozeShield,1
                                          ; oozeShieldLayersAfterAutoStop,0
                                          ; sparseInfillExtruder,Extruder 1
                                          ; sparseInfillPattern,fast_honeycomb
                                          ; sparseInfillRotation,0
                                          ; sparseInfillPercentage,30
                                          ; sparseInfillExtrusionWidthPercentage,115
                                          ; sparseInfillCombinedLayers,1
                                          ; denseInfillLayers,0
                                          ; denseInfillPercentage,55
                                          ; infillOutlineOverlapPercentage,15
                                          ; minInfillLength,1.00000
                                          ; externalInfillPattern,rectilinear
                                          ; externalInfillRotation,0
                                          ; solidInfillThresholdArea,25.00000
                                          ; solidInfillExtraExpansion,0.00000
                                          ; useMonotonic,1
                                          ; useDiaphragm,0
                                          ; diaphragmSolidLayers,3
                                          ; diaphragmSpacingLayers,20
                                          ; topLayerExtraExpansion,0.00000
                                          ; topLayerExtrusionModifier,100
                                          ; overrideFanSpeedForTopLayer,0
                                          ; topLayerFanSpeedPercentage,100
                                          ; useIroning,0
                                          ; ironingOutlineOffsetPercentage,50
                                          ; ironingExtrusionWidthPercentage,25
                                          ; ironingExtrusionModifier,15
                                          ; ironingSpeedModifier,30
                                          ; sparseSupportExtruder,Extruder 1
                                          ; sparseSupportInfillPattern,aligned
                                          ; sparseSupportInfillRotation,0
                                          ; sparseSupportInfillPercentage,25
                                          ; sparseSupportOutlines,0
                                          ; sparseSupportCombinedLayers,1
                                          ; upperDenseSupportLayers,0
                                          ; lowerDenseSupportLayers,1
                                          ; denseSupportExtruder,Extruder 1
                                          ; denseSupportInfillPercentage,50
                                          ; denseSupportExtraExpansion,0.00000
                                          ; baseSupportLayers,0
                                          ; supportInflationDistance,0.00000
                                          ; supportHorizontalPartOffset,0.70000
                                          ; supportUpperSeparationLayers,1
                                          ; supportLowerSeparationLayers,1
                                          ; temperatureController,Extruder 1
                                          ; enableTemperatureController,1
                                          ; temperatureNumber,0
                                          ; temperatureType,extruder
                                          ; stabilizeAtStartup,1
                                          ; temperatureSetpoints,1|210,2|195
                                          ; useIdleCooldown,0
                                          ; cooldownTemperature,150
                                          ; cooldownRequiredIdleTime,180
                                          ; cooldownReheatTime,60
                                          ; temperatureController,Heated Bed
                                          ; temperatureType,platform
                                          ; temperatureSetpoints,1|60
                                          ; useIdleCooldown,0
                                          ; fan,Ventoinha
                                          ; fanNumber,0
                                          ; fanType,extruder
                                          ; blipFanToFullPower,0
                                          ; fanSetpoints,1|0,2|100
                                          ; increaseFanForQuickLayers,0
                                          ; fanMaxQuickLayerTime,45.00000
                                          ; fanMinQuickLayerTime,15.00000
                                          ; maxQuickLayerFanSpeedPercentage,100
                                          ; defaultPrintSpeed,2400.00000
                                          ; outerPerimeterSpeedPercentage,50
                                          ; innerPerimeterSpeedPercentage,80
                                          ; topLayerSpeedPercentage,50
                                          ; solidInfillSpeedPercentage,80
                                          ; sparseSupportSpeedPercentage,80
                                          ; denseSupportSpeedPercentage,70
                                          ; travelSpeedXY,4800.00000
                                          ; travelSpeedZ,1002.00000
                                          ; reduceSpeedForQuickLayers,1
                                          ; speedMaxQuickLayerTime,15.00000
                                          ; minQuickLayerSpeedPercentage,20
                                          ; reduceSpeedForShortPerimeters,1
                                          ; speedMaxShortPerimeterLength,80.00000
                                          ; minShortPerimeterSpeedPercentage,50
                                          ; reduceSpeedForMaxFlowRate,0
                                          ; accelXY,1000.00000
                                          ; accelZ,150.00000
                                          ; accelE,3000.00000
                                          ; jerkXY,600.00000
                                          ; jerkZ,24.00000
                                          ; jerkE,300.00000
                                          ; exportFileFormat,gcode
                                          ; useStickyCommands,1
                                          ; use5D,1
                                          ; relativeExtrusionDistances,0
                                          ; allowExtruderAxisZeroing,1
                                          ; independentExtruderAxes,0
                                          ; includeM10123,0
                                          ; includeThumbnailImages,0
                                          ; thumbnailImageEncoding,standard
                                          ; thumbnailImageSizes,300|300
                                          ; x3gMachineProfile,r2
                                          ; overrideStepsPerMillimeter,0
                                          ; stepsPerMillimeterX,88.57319
                                          ; stepsPerMillimeterY,88.57319
                                          ; stepsPerMillimeterZ,400.00000
                                          ; stepsPerMillimeterA,96.27520
                                          ; stepsPerMillimeterB,96.27520
                                          ; xyzFileFormatVersion,1
                                          ; makerBotMachineProfile,replicator_5
                                          ; makerBotModelExtruder,mk13
                                          ; makerBotSupportExtruder,mk14_s
                                          ; makerBotModelMaterial,pla
                                          ; makerBotSupportMaterial,pva
                                          ; globalOffsetX,0.00000
                                          ; globalOffsetY,0.00000
                                          ; globalOffsetZ,0.00000
                                          ; applyToolheadOffsets,0
                                          ; buildVolumeShape,rectangular
                                          ; buildVolumeX,700.00000
                                          ; buildVolumeY,400.00000
                                          ; buildVolumeZ,400.00000
                                          ; buildVolumeDiameter,200.00000
                                          ; originOffsetX,0.00000
                                          ; originOffsetY,0.00000
                                          ; originOffsetZ,0.00000
                                          ; homingDirectionX,min
                                          ; homingDirectionY,min
                                          ; homingDirectionZ,min
                                          ; mirrorVisualX,0
                                          ; mirrorVisualY,1
                                          ; mirrorVisualZ,0
                                          ; machineBackgroundModel,
                                          ; startingScript,M140 S60; faz aquecimento cama |G28; HOME GERAL|G29 V4 T ; AUTO NIVELAMENTO|G1 Y0 Z25 F8000; VAI PRA PONTO DE PURGA|G1 X0 F8000|G1 E60 F250; PURGA FILAMENTO|G92 E0; RESETA EXTRUSOR|G1 X350 F8000 |G1 Y200 Z0 F8000 ; MOVIMENTO para iniciar a impressao
                                          ; preLayerChangeScript,
                                          ; postLayerChangeScript,
                                          ; preRetractionScript,
                                          ; postRetractionScript,
                                          ; preToolChangeScript,
                                          ; postToolChangeScript,
                                          ; processChangeScript,
                                          ; endingScript,G1 Z300 F6000|M104 S0 ; turn off extruder|M140 S0 ; turn off bed|M84 ; disable motors
                                          ; postProcessingScript,
                                          ; useBridging,1
                                          ; bridgingThresholdArea,50.00000
                                          ; bridgingInfillExtraExpansion,0.00000
                                          ; bridgingExtrusionModifier,100
                                          ; bridgingSpeedModifier,100
                                          ; overrideFanSpeedForBridging,0
                                          ; bridgingFanSpeedPercentage,100
                                          ; useFixedBridgingAngle,0
                                          ; fixedBridgingAngle,0
                                          ; applyBridgingToPerimeters,0
                                          ; bridgingPerimeterExtraOverlap,0.00000
                                          ; minBridgingPerimeterLength,10.00000
                                          ; useToolChangeRetraction,1
                                          ; toolChangeRetractDistance,12.00000
                                          ; toolChangeExtraRestartDistance,-0.50000
                                          ; toolChangeRetractSpeed,600.00000
                                          ; toolChangePrimeOnFirstUse,0
                                          ; toolChangeRetractAtEnd,0
                                          ; externalThinWallType,perimeters_only
                                          ; internalThinWallType,gap_fill
                                          ; thinWallAllowedOverlapPercentage,10
                                          ; singleExtrusionMinLength,1.00000
                                          ; singleExtrusionMinWidthPercentage,50
                                          ; singleExtrusionMaxWidthPercentage,200
                                          ; singleExtrusionEndpointExtensionDistance,0.20000
                                          ; onlyRetractWhenCrossingOutlines,1
                                          ; retractBetweenLayers,1
                                          ; retractOnTopLayers,0
                                          ; useRetractionMinTravel,0
                                          ; retractionMinTravel,3.00000
                                          ; useRetractionMinExtrusion,0
                                          ; retractionMinExtrusion,3.00000
                                          ; onlyVerticalLiftOnTopLayers,0
                                          ; retractWhileWiping,0
                                          ; wipingMode,outer_perimeter
                                          ; avoidCrossingOutlines,0
                                          ; maxMovementDetourFactor,3.00000
                                          ; openLoopSlicingBehavior,heal
                                          ; openLoopThickenWidth,0.50000
                                          ; slicingRegionRepairMode,positive
                                          G90
                                          M82
                                          M106 S0 P0
                                          M140 S60
                                          M190 S60
                                          M104 S210 T0
                                          M109 S210 T0
                                          G28; HOME GERAL
                                          G1 X0 F8000
                                          G1 X350 F8000
                                          ; process PLA
                                          ; layer 1, Z = 0.2340
                                          T0
                                          G92 E0.00000
                                          G1 E-6.50000 F600
                                          ; feature skirt
                                          ; tool H0.2340 W0.620
                                          G1 Z0.2340 F1002
                                          G1 X321.538 Y175.143 F4800
                                          G92 E0.00000
                                          G1 E6.70000 F600
                                          G92 E0.00000
                                          G1 X322.328 Y173.810 E0.05142 F1920
                                          G1 X323.416 Y172.206 E0.11569
                                          G1 X324.412 Y170.915 E0.16978
                                          G1 X326.044 Y169.079 E0.25128
                                          G1 X327.847 Y167.376 E0.33355
                                          G1 X329.376 Y166.143 E0.39872
                                          G1 X330.287 Y165.482 E0.43606
                                          G1 X331.517 Y164.671 E0.48493
                                          G1 X332.820 Y163.905 E0.53508
                                          G1 X334.162 Y163.208 E0.58525
                                          G1 X335.539 Y162.582 E0.63541
                                          G1 X336.946 Y162.028 E0.68558
                                          G1 X338.454 Y161.524 E0.73833
                                          G1 X340.754 Y160.929 E0.81714
                                          G1 X342.307 Y160.641 E0.86956
                                          G1 X343.807 Y160.443 E0.91975
                                          G1 X345.403 Y160.317 E0.97285
                                          G1 X347.831 Y160.294 E1.05340
                                          G1 X350.265 Y160.482 E1.13440
                                          G1 X351.841 Y160.715 E1.18723
                                          G1 X353.324 Y161.014 E1.23742
                                          G1 X354.789 Y161.390 E1.28759
                                          G1 X356.232 Y161.842 E1.33775
                                          G1 X357.649 Y162.368 E1.38792
                                          G1 X359.038 Y162.968 E1.43808
                                          G1 X360.393 Y163.639 E1.48825
                                          G1 X361.711 Y164.380 E1.53842
                                          G1 X362.989 Y165.188 E1.58859
                                          G1 X364.254 Y166.085 E1.64004
                                          G1 X365.765 Y167.299 E1.70431
                                          G1 X366.913 Y168.343 E1.75580
                                          G1 X367.978 Y169.419 E1.80603
                                          G1 X369.044 Y170.614 E1.85914
                                          G1 X370.482 Y172.473 E1.93712
                                          G1 X371.367 Y173.795 E1.98990
                                          G1 X372.141 Y175.095 E2.04009
                                          G1 X372.846 Y176.433 E2.09026
                                          G1 X373.480 Y177.806 E2.14042
                                          G1 X374.042 Y179.210 E2.19059
                                          G1 X374.530 Y180.641 E2.24076
                                          G1 X374.942 Y182.096 E2.29092
                                          G1 X375.270 Y183.533 E2.33985
                                          G1 X377.187 Y194.033 E2.69391
                                          G1 X379.210 Y196.056 E2.78884
                                          G1 X379.210 Y208.056 E3.18693
                                          G1 X383.210 Y212.056 E3.37460
                                          G1 X383.210 Y231.944 E4.03435
                                          G1 X373.944 Y241.210 E4.46909
                                          G1 X358.056 Y241.210 E4.99615
                                          G1 X354.056 Y237.210 E5.18381
                                          G1 X350.056 Y237.210 E5.31651
                                          G1 X346.056 Y233.210 E5.50417
                                          G1 X342.056 Y233.210 E5.63687
                                          G1 X328.790 Y219.944 E6.25927
                                          G1 X328.790 Y215.691 E6.40035
                                          G1 X321.837 Y203.926 E6.85372
                                          G1 X321.161 Y202.712 E6.89980
                                          G1 X320.457 Y201.275 E6.95290
                                          G1 X319.568 Y199.086 E7.03129
                                          G1 X319.064 Y197.549 E7.08495
                                          G1 X318.574 Y195.675 E7.14921
                                          G1 X318.273 Y194.152 E7.20071
                                          G1 X318.057 Y192.655 E7.25087
                                          G1 X317.917 Y191.110 E7.30235
                                          G1 X317.857 Y189.081 E7.36969
                                          G1 X317.978 Y186.601 E7.45204
                                          G1 X318.308 Y184.184 E7.53297
                                          G1 X318.630 Y182.638 E7.58536
                                          G1 X319.034 Y181.101 E7.63808
                                          G1 X319.822 Y178.775 E7.71956
                                          G1 X320.804 Y176.541 E7.80051
                                          G1 X321.538 Y175.143 E7.85290
                                          G92 E0.00000
                                          G1 E-6.50000 F600
                                          G1 X322.079 Y175.445 F4800
                                          G92 E0.00000
                                          G1 E6.70000 F600
                                          G92 E0.00000
                                          9 out of 40
