Motor current idle factor not working over canbus?
Hey @droftarts, I hope this doesn’t make me sound crazy (though I wouldn’t blame you if it does!), but I just tested it in standalone mode, and the problem is still happening. I was sitting right next to the printer, with my hand under the print plate ready to catch it as soon as the low idle motor kicked in ... thankfully, I managed to catch it in time. I repeated the test several times with the same result. Anyway, I really don’t know what to do next. At this point I'm wondering if it's a hardware issue?
@mike_b Can you post your config.g, and the config.g on the Mini 5+-as-expansion? There should be not M906 in the config.g of the expansion board.
Hey @droftarts, I shared the configurations for both boards just a few days ago - you can find them here
I need to include the
M906 I90
command in theconfig.g
file for the expansion board; otherwise, the motors default to the default idle current, which causes my print plate to drop. For testing purposes, I remove that line. So, when I say the issue persists, I mean the problem still occurs when the M906 command is omitted from the expansion board’sconfig.g
file. This was a workaround recommended by @dc42 himself here. Sorry, I know this is all a bit confusing, happy to jump on a quick voice call, to explain everything, if you think it could help?EDIT: fixed links
@mike_b said in Motor current idle factor not working over canbus?:
Sorry, senior moment, and that I was looking on my phone, I missed them!
M906 I90
file for the expansion board...I understand that. I didn't have it in the expansion board config.g in my test setup, so I need to work out the differences between your setup and mine. Unfortunately I had to take my setup apart to do some 3.6.0-beta.2 testing, and I won't be able to put it back together to test until early next week.
I've had a look through your config.g, and the only thing that stands out to me is that your drives are running in stealthChop mode (M569 ... D3 Vn) while I ran mine in spreadcycle (M569 D2). You also have stallguard enabled on X and Y axes. Could you test without stallguard and with the drivers in spreadCycle? I'm not sure why this would make a difference though. Otherwise I'll try and test early next week with your config.g. I don't feel like this is a hardware issue, just yet.
This post is deleted! -
@droftarts said in Motor current idle factor not working over canbus?:
LOL, no worries, I know the feeling!
Just tried it, unfortunately no luck, problem still persists.
Thank you! And please do let me know if there is anything I can do on my end to help with the debugging.
