error after upgrading firmware
291
  • undefined
    oldironjunkie
    I recently upgraded my firmware to 3.5.2 and after doing so I started to get a warning message "Error in start-up file macro line 2: Heater 1 not found" a start up. In the past I had issues with an extruder driver that was burned out by a faulty motor. I had to switch to extruder 1 and also heater 2 and was working for an extended period of time. Till the firmware upgrade. Not sure where to look for the start up file macro (unable to find). I am sure if I am pointed in the right direction I will fix it. Also tried uploading the config.g file but it is not working. Probably not doing it right. Printer is working ok but the message is annoying. Please help.
    • undefined
      oldironjunkie
      I just copied and pasted the config.g file. hope this helps.
      ;General preferences
      M550 P"OLDIRON PRINTER" ; set printer name
      ;Network
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      ;Drives
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S0 ; physical drive 3 goes backwards
      ;M569 P4 S0 ; physical drive 4 goes backwards TITAN AERO
      M569 P4 S1 ; physical drive 4 goes forwards SLICE MOSQUITO
      ;M569 P3 S0 ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E4:4:4:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping with interpolation
      ;M92 X80.70 Y79.95 Z399.74 E408 ;set steps per mm E3D titan aero extruder
      M92 X80.70 Y79.95 Z399.74 E405 ; set steps per mm mosquito extruder (recheck)
      ;M92 X80.70 Y79.95 Z399.74 E454. ; set steps per mm biqu extruder
      M566 X800.00 Y800.00 Z800.00 E650:800:800:800 ; set maximum instantaneous speed changes (mm/min)
      M203 X7500.00 Y7500.00 Z6500.00 E900:900:900:900 ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z500.00 E250:300:300:300 ; set accelerations (mm/s^2)
      M906 X1400 Y1800 Z900 E1200:800:800:800 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S300 ; Set idle timeout
      ;Axis Limits
      M208 X315 Y310 Z400 S0 ; set axis maxima3
      ;Endstops
      M574 X1 S1 P"!xstop" ; configure active-(high) LOW endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-(high) LOW endstop for low end on Y via pin ystop
      M574 Z1 S1 P"!zstop" ; configure active-(high) LOW endstop for low end on Z via pin zstop
      ;Z-Probe
      M950 S0 C"duex.pwm1" ; Duet 2 WiFi/Ethernet + DueX2/5
      M558 P9 C"^zprobe.in" H3 F50 T9000 R0.5 ; Duet 2 WiFi/Ethernet, DueX2/55
      G31 X-5 Y-25 Z3.66 ; z probe offset
      M557 X0:300 Y10:300 S30 ; bed mesh size and spacing
      M376 H9 ;bed mesh fading
      ;Heaters
      M307 H0 B0 S1.0 ; enable bang-bang mode for the bed heater and set PWM limit
      M950 H2 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H2 R2.584 C226.4 D8.23 S.5 V24.3 ;tool heat
      M143 H2 S350 ; set temperature limit for heater 1 to 350C
      ;Fans
      M950 F0 C"fan0" ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S.75 H-1 Q500 ; set fan 0 value. Thermostatic control is turned off
      M106 P1 S.75 H-1 Q500 ; set fan 1 value. Thermostatic control is turned on
      ;Tools
      M563 P1 D1 H2 F0 ; define tool 1
      M572 D1 S0.02 ;ADDED PRESSURE ADVANCE SETTING
      G10 P1 R0 S0
      T1 ; select first tool
      undefined 1 Reply Last reply 4 Jul 2024, 23:47 Reply Quote 0
      • undefined
        jay_s_uk @oldironjunkie
        @oldironjunkie what's in your config-override.g?
        undefined 1 Reply Last reply 5 Jul 2024, 09:17 Reply Quote 1
        • undefined
          droftarts administrators @jay_s_uk
          @jay_s_uk said in error after upgrading firmware:
          That would make sense regarding the error message and line number, as heaters are the first thing that are written in config-override.g:
          ; config-override.g file generated in response to M500 at 2023-10-02 12:25
          ; Heater model parameters
          M307 H0 R0.326 K0.151:0.000 D5.80 E1.00 S1.00 B0
          M307 H1 R1.967 K0.377:0.221 D8.17 E1.00 S1.00 B0 V12.1
          ; Workplace coordinates
          G10 L2 P1 X0.00 Y0.00 Z0.00
          G10 L2 P2 X0.00 Y0.00 Z0.00
          I expect you have M307 H1 ... left in config-override.g, left over from when you had more hot ends, and the firmware is complaining that you haven't defined this heater before setting M307 for it.
          config-override.g will also be overriding the M307 heater values set in config.g, so make sure they are the ones you want to use.
          undefined 1 Reply Last reply 5 Jul 2024, 15:33 Reply Quote 0
          • undefined
            oldironjunkie @droftarts
            @droftarts Here is my config-override.g. looks like heater 2 is listed.
            M307 H2 R2.584 C226.4 D8.23 S.7 V24.3 ;TOOL HEAT updtaed 6/28/2023
            M572 D0 S.02 ;pressure advance
            M307 H0 R0.890 C200.2 D3.32 S1.00 V24.0 ;bed heat
            undefined 1 Reply Last reply 5 Jul 2024, 20:32 Reply Quote 0
            • undefined
              droftarts administrators @oldironjunkie
              @oldironjunkie It looks like you have manually edited that config-override.g. Usually it is generated by the firmware, sending M500 to save the current settings. If you want to manually add things, add them directly to config.g, to avoid confusion.
              Perhaps comment out the M501 in config.g, then send M98 P"config.g" to see if there are any errors generated.
              undefined 3 Replies Last reply 5 Jul 2024, 22:39 Reply Quote 0
              • undefined
                @droftarts I am in the middle of a print for the next 20 hours. Will try all when it is done.
                • undefined
                  @droftarts I forgot to sayt hat the config.g and config-override.g were changed when I had issues with the motor driver last year.
                  • undefined
                    @droftarts Thanks for your help I did all you asked and kept having the same issue. I reloaded the firmware and it is now working ok. No messages. It must have been something in the install process that caused it.
                    undefined 1 Reply Last reply 8 Jul 2024, 09:53 Reply Quote 0
                    • undefined
                      @oldironjunkie Did you go back to an older firmware, or are you still on v3.5.2?
                      undefined 1 Reply Last reply 8 Jul 2024, 11:36 Reply Quote 0
                      • undefined
                        @droftarts Still on 3.5.2. About to start some long prints . We will see if it works in a few days. Again I thanks you. John.
                        9 out of 11
