Duet3d Dashboard for multiple Printers
Is there a tool that aggregate the states or the print logs of multiple printers to monitore the health, and success rate of a print farm?
@qurt There is https://github.com/Duet3D/DuetPrintFarm and https://github.com/Duet3D/DuetPrintFarmUI
There is the older https://github.com/DanalEstes/MultiDuetWebMonitor, but this hasn't been updated for a long time, I don't know if it will work with newer firmware versions.
I'm not aware of others, unless it's possible to do it in DueUI https://github.com/gtjoseph/DueUI by @gtj0, or Btncmd https://github.com/MintyTrebor/BtnCmd by @MintyTrebor ?
@droftarts You can nest other instances of DWC with BtnCmd's remote source panel, but I'm not sure how optimised it would be (I only have 2 printers to test with), I don't think it really meets the criteria though.
Otherwise its possible to pull a unified data dashboard togther with NodeRed & NodeDSF
Also have a look at this thread
