slow down your poll rate
Hey,
I have duet3 MB6HC.
I get very often a "slow down poll rate" warning. What does it means?@Phaedrux @jay_s_uk @droftarts
config.g
G90 ; Extrude relatively M83 M552 P192.168.1.20 S1 ; enable HTTP M586 P0 S1 ; disable FTP M586 P1 S0 ; disable Telnet M586 P2 S0 ; wait for Ready state. G4 S2 M569 P0.0 S1 M569 P0.1 S1 M569 P0.2 S1 M569 P0.3 S1 M569 P0.4 S0 T1.3:1.3:1.3:1.3 M569 P0.5 S1 T1.3:1.3:1.3:1.3 M569 P40.0 S1 M569 P41.0 S1 M584 X0.5 Y0.4 Z0.0:0.1:0.2:0.3 E40.0:41.0 M350 X8 Y8 Z16 E16:16 I1 M92 X100.00 Y100.00 Z200.00 E417.00:417.00 M566 X600.00 Y600.00 Z120.00 E1200.00:1200.00 M203 X24000.00 Y24000.00 Z1800.00 E15000.00:15000.00 M201 X2000.00 Y2000.00 Z30.00 E4000.00:4000.00 M906 X800 Y800 Z2000 E700:700 I30 M84 S30 M208 X0 Y0 Z0 S1 M208 X605 Y605 Z660 S0 M591 D0 P7 C"40.io0.in" R15:300 L7 E17 S1 M591 D1 P7 C"41.io0.in" R15:300 L7 E17 S1 ; Endstops M574 X1 S1 P"!io6.in" M574 Y1 S1 P"!io5.in" M574 Z1 S1 P"!io4.in+!io1.in+!io2.in+!io3.in" ; Z-Probe M950 S0 C"io7.out" M558 P9 C"^io7.in" H8 F120 T6000 G31 P500 X0 Y0 Z4.83 M671 X-47.5:-47.5:724.5:724.5 Y-11:634.5:634.5:-11 S1.0 M572 D0:1 S0.065:0.065 M308 S0 P"temp0" Y"thermistor" T100000 B4138 M950 H0 C"out0" T0 M307 H0 B0 S1.00 M140 H0 M143 H0 S152 M308 S1 P"temp1" Y"pt1000" M950 H1 C"out1" T1 M307 H1 B0 S1.00 M143 H1 S305 M308 S2 P"temp2" Y"pt1000" M950 H2 C"out2" T2 M307 H2 B0 S1.00 M143 H2 S305 M950 F0 C"out7" Q32000 M106 P0 S0 H-1 M575 P1 S1 B57600 M501 M911 S21 R22.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" M122
M98 P"0:/macros/SERVICE/Diagnose/Diagnose.g" === Diagnostics === RepRapFirmware for Duet 3 MB6HC MOD. By STPL version 3.4.0beta3 (2023-04-15 11:15:04) running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-9P63L-DJ3T0-6J1DG-3SJ6N-1B3VA Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 151160 Dynamic ram: 94364 of which 40 recycled Never used RAM 101412, free system stack 116 words Tasks: NETWORK(ready,482.3%,220) ETHERNET(notifyWait,0.4%,158) HEAT(notifyWait,4.6%,120) Move(notifyWait,72.9%,248) CanReceiv(notifyWait,4.5%,772) CanSender(notifyWait,0.3%,366) CanClock(delaying,1.4%,339) TMC(notifyWait,210.0%,59) MAIN(running,548.3%,1090) IDLE(ready,0.0%,29), total 1324.8% Owned mutexes: HTTP(MAIN) === Platform === Last reset 68:39:39 ago, cause: power up Last software reset time unknown, reason: User, GCodes spinning, available RAM 105108, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,11,0 Step timer max interval 134 MCU temperature: min 35.9, current 48.1, max 53.1 Supply voltage: min 23.5, current 23.7, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0 Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/36/18, gc cycles 0 Driver 0: position 33610, standstill, reads 25835, writes 17 timeouts 0, SG min/max 0/321 Driver 1: position 16848, standstill, reads 25841, writes 17 timeouts 0, SG min/max 0/314 Driver 2: position 7784, standstill, reads 25841, writes 17 timeouts 0, SG min/max 0/291 Driver 3: position 0, standstill, reads 25841, writes 17 timeouts 0, SG min/max 0/311 Driver 4: position 0, ok, reads 25842, writes 17 timeouts 0, SG min/max 0/74 Driver 5: position 0, open-load-A, open-load-B, reads 25847, writes 17 timeouts 0, SG min/max 0/73 Date/time: 2024-08-14 11:21:29 Slowest loop: 227.64ms; fastest: 0.03ms === Storage === Free file entries: 7 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 4.3ms, write time 45.5ms, max retries 0 === Move === DMs created 125, segments created 35, maxWait 71099644ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 320158, completed moves 320125, hiccups 0, stepErrors 0, LaErrors 47, Underruns [0, 0, 70], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.9 === GCodes === Segments left: 1 Movement lock held by null HTTP is ready with "M122" in state(s) 0 0, running macro Telnet is idle in state(s) 0 File is doing "G0 F6000 X351.012 Y156.382" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0 sensor: no data received Extruder 1 sensor: no data received === CAN === Messages queued 2492419, received 4202209, lost 0, longest wait 1ms for reply type 6018, peak Tx sync delay 283, free buffers 49 (min 40), ts 1235900/1235899/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 219.84ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 2 2 2 2 2 0 0 0 -
@R006 said in slow down your poll rate:
Are you running a custom firmware?
I get very often a "slow down your poll rate" warning
I can't find that message anywhere in the current RRF code base. Where exactly are you getting the message? It looks like you may have some sort of display attached are you seeing it there? Can you post a screenshot of the actual message.
@R006 what is the exact message, and are you seeing the message just on an attached PanelDue? There is a message along the lines of "reducing polling rate" produced by PanelDueFirmware.
@Phaedrux
yes it is -
after that print paused automatically.
@R006 yes that's the PanelDue detecting that it's getting delayed responses from the main board and slowing down its poll rate to reduce the load on the main board. So something is keeping the main board very busy. One possibility is that you have set microstepping too high.
Okay,
but why print is paused after that information?microsteps M350 X8 Y8 Z16 E16:16 I1
