    Failed to open IO device error after installing Raspbian updates
    DSF Development
    469
    • curieosundefined
      curieos
      I updated the packages via apt this morning on a machine in SBC mode, and after restarting the Pi I'm getting this error:
      The setup is two 6XDs and two 1LCs. The Pi is a Pi 5 running the bookworm image from April 19th. Fully rebooting the machine (cutting power) does not work.
      She/Her
      I work at a local 3D printing shop.
      Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
      • curieosundefined curieos marked this topic as a question
        I'd backup your configs and try flashing a freshly downloaded DuetPi image.
        • gloomyandyundefined
          gloomyandy @Phaedrux
          @Phaedrux Another user reported a similar problem and found a possible solution: https://forum.duet3d.com/topic/36515/just-upgraded-sbc-duet-6hc-now-have-error-connecting
          p8blrundefined 1 Reply Last reply Reply Quote 1
          • p8blrundefined
            p8blr @gloomyandy
            @curieos Hey I had this error on my last try to image my rpi 5
            https://forum.duet3d.com/topic/36442/firmware-update-bricked-printer-spi-connection-has-been-reset/16
            • chrishammundefined
              chrishamm administrators @curieos
              @curieos @p8blr I had a chance to look at it today and it appears the new RPi 5 kernel brings the pin mapping in-line again with previous RPi versions. That means the gpiochip device and pin number are now incompatible on the Raspberry Pi 5.
              To fix this problem, log into your Pi via SSH or Linux terminal and run sudo rm /opt/dsf/conf/config.json. After a few seconds, DSF should come back up again.
              Duet software engineer
              curieosundefined p8blrundefined 2 Replies Last reply Reply Quote 1
              • curieosundefined
                curieos @chrishamm
                @chrishamm Will this be fixed in a DSF update? We'd like to know if our customers will have this issue if they update in the future.
                She/Her
                  @curieos I'm about to build new DuetPi images. If your customers use only M997 S2 to install DSF updates, they won't encounter this problem. If they use apt for updates, the one-liner above will be necessary.
                  curieosundefined 1 Reply Last reply Reply Quote 0
                  • p8blrundefined
                    p8blr @chrishamm
                    @chrishamm can confirm this works.
                    sudo apt update
                    sudo apt full-upgrade
                    sudo systemctl reboot
                    • curieosundefined curieos has marked this topic as solved
                    • curieosundefined
                      curieos @chrishamm
                      @chrishamm When will the new duet pi images be available?
                      She/Her
                        @curieos I've got new builds ready for testing, please DM me if you wish to try them as well (with 3.5.2). I expect they'll be public sometime next week.
