    New Duet3D wifi - constant reconnects
    172
    • DTinNCundefined
      DTinNC
      Brand new Duet 3D w wifi was installed to upgrade my Rostock Max 3D printer. Used several times without any issues. After a couple months of no use I just powered it back on and the screen on the Rostock keeps reporting "error: wifi module reported: auto reconnect succeeded"
      Literally nothing changed since last use. It's in a temp controlled environment. no humidity etc. I believe that I am using v3.4.4
      Thank you in advance for any help... super, super frustrated that the brand new board is acting up.
        jay_s_uk @DTinNC
        @DTinNC I would suggest upgrading to 3.5.3 and the new WiFi firmware and then report back
        DTinNCundefined 1 Reply Last reply Reply Quote 1
        • DTinNCundefined
          DTinNC @jay_s_uk
          @jay_s_uk Thank you - is there a non-destructive way so that I keep my settings and configs that were specific to this printer?
            jay_s_uk @DTinNC
            @DTinNC yes. Just upload the zip file https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.3/Duet2and3Firmware-3.5.3.zip to the system tab in DWC and it'll update everything.
            Worth having a looking at the change log too so you can see what's changed https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
            DTinNCundefined 2 Replies Last reply Reply Quote 1
            • DTinNCundefined
              DTinNC @jay_s_uk
              @jay_s_uk Thanks so much!
              • DTinNCundefined
                DTinNC @jay_s_uk
                @jay_s_uk Quick question - I am not connected to the board (since wifi is not stable). Is there a way to access the DWC other than wifi? I don't think usb supports it... thank you
                Phaedruxundefined oliofundefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @DTinNC
                  @DTinNC No, network only for DWC. You can connect via USB terminal to send commands and receive replies from the firmware.
                  • oliofundefined
                    oliof @DTinNC
                    @DTinNC you can try running the board in AP mode creating it's own WiFi.
