    Common GND on Duet2 Wifi?
    • TomasLundefined
      TomasL
      Is all the gnd/- terminals common on Duet2.
      Thinking of Heaters, Fans etc.
      Want to reduce the amount of cabels running to the printer head/extruder assembly.
      • gloomyandyundefined
        gloomyandy @TomasL
        @TomasL No they are not in general any switched "highish" power output (like a heater or fan) will be switching on the low/ground side of things.
        TomasLundefined 1 Reply Last reply Reply Quote 0
        • TomasLundefined
          TomasL @gloomyandy
          @gloomyandy Ok, so I cannot run a common to fans, heaters and the z-probe
          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
          • DIY-O-Sphereundefined
            DIY-O-Sphere @TomasL
            @TomasL
            Depending on what is needed, the positive voltages can be used together.
            But then also pay attention to the cable cross-section
            (UTC+1)
            • TomasLundefined
              TomasL @DIY-O-Sphere
              I cannot understand why low-side switching is used (Apart from being cheap and easy).
              I know it is easier, But High side is safer and, one get a common ground.
                droftarts administrators @TomasL
                @TomasL It's because the switching is done by N-channel MOSFETs, and these need to be placed after the load, and switch to ground. I don't know enough about electronics to know exactly why these are used, but there's a comparison of N Channel vs P Channel MOSFETs here: https://www.icrfq.net/n-channel-vs-p-channel-mosfet/
                I think mainly that N-channel MOSFETs are better for fast switching, so are more suitable for PWM applications such as the heaters and fans.
                Instead of a common ground, you can have a common +V? You couldn't have both, whichever way the output was switched.
                infiniteloopundefined 1 Reply Last reply Reply Quote 0
                • infiniteloopundefined
                  infiniteloop @droftarts
                  @droftarts
                  I use P-channel MOSFETs a lot, but the fact remains that they dissipate much more heat - up to a magnitude more than the N-types -, so cooling becomes a major problem.
                  Yeah, that's what, on the continent, British cars were famous of - or feared … 😊
