    Duet 2 and Duex 5 : BL Touch Wiring
    358
    • djthumaundefined
      djthuma
      I am setting up a duet 2 and BL Touch. But having some trouble. I tried looking at previous forum posts, but I am not getting the same results or understanding.
      I have this in the config file.
      M574 X1 P"xstop" S1 ; configure X axis endstop
      M574 Y1 P"ystop" S1 ; configure Y axis endstop
      M574 Z1 S2 ; configure Z axis endstop
      ; Probes
      G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height
      M950 S0 C"duex.pwm1" ; Duet 2 WiFi/Ethernet + DueX2/5
      M558 P9 C"^zprobe.in" H5 F120 T6000 ; configure BLTouch probe via slot #0
      But I don't understand when it says "First, you need to allocate an unused heater expansion channel to reconfigure as the servo control for the BLTouch."
      Am I using H5 in my case?
      When I plug in black and white into the Z Probe GND and Z_PROBE_IN. Then the other wires into PWM1 it gives me a voltage overload warning.
      Any help appreciated! Thanks
      infiniteloopundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @djthuma
        @djthuma
        … when it says "First, you need to allocate an unused heater expansion channel…"
        Suppose you got this from a forum post? Better follow the Duet3D Documentation. For your BL-Touch (and similar Z-probes), read this: Connecting a Z probe - BLTouch. If questions remain, you're welcome to return to this thread.
        djthumaundefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @djthuma
          @djthuma said in Duet 2 and Duex 5 : BL Touch Wiring:
          Your config says DueX PWM1, that’s where you can plug in 5V, GND, and the control wire. The expansion connector, where pin exp.heater5 is, is where the DueX plugs in, so is not accessible.
          • djthumaundefined
            djthuma @infiniteloop
            @infiniteloop
            I was referring to this page on the documentation.
            droftartsundefined infiniteloopundefined 3 Replies Last reply Reply Quote 0
            • djthumaundefined
              djthuma @droftarts
              @droftarts Thank you.
              When I plug in the Probe to PWM1 I get an over voltage error. The screen goes white. I unplug it, of course I don't want things to fry.
                First, you need to allocate an unused heater expansion channel to reconfigure as the servo control for the BLTouch. For example, if the E2Heat output is unused, you can use heater 3 which corresponds to the PWM1 connector.
                Yes, it's a bit confusing. Because each of the PWM and heater outputs are shared on the Duex, ie the same signal controls PWM1 as e2heat, and PWM2 is shared with e3heat, etc, you need to use a PWM connector whose matching heater is free. The naming of the heater outputs is also a little confusing; heater 0 is the bed heater, heater 1 is e0heat, heater 2 is e1heat, and the heater 3 pin on the expansion header (exp.heater3) controls e2heat and servo output PWM1 on the Duex!
                I think I'll rewrite this in the morning, to make it clearer.
                That's not good. Most likely your wiring is incorrect, possibly you have shorted 5V to GND, or the servo control pin. Check your wiring. Post a picture if you're not sure.
                  @djthuma
                  So we are on the same page 😊
                  Can you share the version of your Duet board?
                  Do we talk about a genuine BLTouch or a lookalike (CR-Touch, BTT Microprobe, …)?
                  Which version is the BLTouch?
                    @djthuma I've updated the text so it is clearer:
                    On the Duex and EBoB, connect the BLTouch GND, +5V, and control wires to an available three-pin PWM output. Connect the BLTouch out and GND wires to the Duet Z Probe connector.
                    On the Duex, heater outputs and PWM outputs share the same signal, ie the same signal controls PWM1 as e2heat, PWM2 is shared with e3heat, PWM3 is shared with e4heat, etc. You need to use a PWM connector whose matching heater is free.
                    I've also updated the wiring table, as it wasn't in the same order as the pins. Note that +5V is the middle pin on the PWM connector. See the wiring diagram: https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#wiring-diagram
                    • djthumaundefined
                      djthuma @droftarts
                      @droftarts !
                      Attached a picture of the wiring of the board, when all plugged in and the BLTouch.
                      White = Z Probe in
                      Black = GND
                      Green = yellow = E2_PWM
                      RED = 5V AUX
                      Blue = GND
                      processed-9CFE7776-9501-420C-B9EA-0C4F3F11F905.jpeg processed-A93A5DF4-F311-4CF6-8629-C6AD5FD2DA5C.jpeg
                      • djthumaundefined
                        djthuma @djthuma
                        @djthuma
                        Config.g file
                        ; Motor Idle Current Reduction
                        M906 I30 ; set motor current idle factor
                        M84 S30 ; set motor current idle timeout
                        ; Axes
                        M584 X0 Y1 Z2:5 ; set axis mapping
                        M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
                        M906 X800 Y800 Z800 ; set axis driver currents
                        M92 X80 Y80 Z400 ; configure steps per mm
                        M208 X0:200 Y0:200 Z0:200 ; set minimum and maximum axis limits
                        M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
                        M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
                        M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
                        ; Extruders
                        M584 E3 ; set extruder mapping
                        M350 E16 I1 ; configure microstepping with interpolation
                        M906 E1000 ; set extruder driver currents
                        M92 E420 ; configure steps per mm
                        M566 E120 ; set maximum instantaneous speed changes (mm/min)
                        M203 E3600 ; set maximum speeds (mm/min)
                        M201 E250 ; set accelerations (mm/s^2)
                        ; Kinematics
                        M669 K1 ; configure CoreXY kinematics
                        ; Probes
                        M558 P9 C"^zprobe.in" H3 F120 T6000 ; configure BLTouch probe via slot #0
                        ;M950 S0 C"zprobe.mod" ; create servo #0 for BLtouch
                        ; Mesh Bed Compensation
                        M557 X25:175 Y25:175 S40:40 ; define grid for mesh bed compensation
                        ; Sensors
                        M308 S0 P"bedtemp" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0
                        M308 S1 P"e0temp" Y"pt1000" A"Nozzle" ;T100000 B4725 C7.06e-8 ; configure sensor #1
                        M950 H0 C"bedheat" T0 ; create heater #0
                        M143 H0 P0 T0 C0 S100 A0 ; configure heater monitor #0 for heater #0
                        M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0
                        M950 H1 C"e0heat" T1 ; create heater #1
                        M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1
                        M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
                        M950 H2 C"e1heat" T1 ; create heater #2
                        M143 H2 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #2
                        M307 H2 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #2
                        ;M140 P9 H3 ; configure heater
                        ; Heated beds
                        M140 P0 H0 ; configure heated bed #0
                        M950 F0 C"fan0" ; create fan #0
                        M106 P0 S0 L0 X1 B0.1 ; configure fan #0
                        M950 F1 C"fan1" ; create fan #1
                        M106 P1 S0 B0.1 H1 T45 ; configure fan #1
                        M950 F3 C"duex.fan3" Q500
                        M106 P3 S1 H-1
                        M563 P0 D0 H1:2 F0 ; create tool #0
                        M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
                          What errors and or problems are you getting in this configuration?
                          Can you please send M122 and M98 P"config.g" and share the results?
                            @djthuma The colour of the wires at your BLTouch are reversed. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_BLTouch#bltouch-pinout-and-wire-colours
                            Normally brown and black are GND, but on yours its white and red. Assuming the plug isn't just plugged in backwards, the wiring from the BLTouch is:
                            GND +5V Control GND Out
                            White Black Yellow > Green Red Blue
                            Which explains why it's shorting out, as the red wire is connected to +5V on the PWM1 connector, and is shorting to the white wire, connected to Z probe in on the Duet.
                            djthumaundefined 1 Reply Last reply Reply Quote 2
                            • djthumaundefined
                              djthuma @droftarts
                              @droftarts Yes!
                              That did work to get the probe to function!
                              I just need to setup the z probe routine for bed leveling.
                              I am running into a different error, trying to have multiple z axis motors.
                              Only one of them is functioning. Driver 2 with a jumper on the ZB segment.
                              Then trying to pair the driver 6 and 7 to the Z axis.
                              Is this correct? When I jog after M564 H0, I only have one drive moving.
                              ; Smart Drivers
                              M569 P0 S0 ;D1 ; driver 0 goes forwards (X axis)
                              M569 P1 S1 ;D2 ; driver 1 goes forwards (Y axis)
                              M569 P2 S1 ;D2 ; driver 2 goes forwards (Z axis)
                              M569 P3 S1 ;D2
                              M569 P6 S1 ;D2 ; driver 3 goes forwards (extruder 0)
                              M569 P7 S1 ;D2 ; driver 3 goes forwards (extruder 0)
                              ; Axes
                              M584 X0 Y1 Z2:6:7; set axis mapping
