    Error: Heater 1 fault: exceeded allowed, when cold booting
    335
    • TomasLundefined
      TomasL
      Every time I star my printer, I get this message:
      "Event Notification"
      "Heater 1 fault: exceeded allowed temperature excursion: target 220.0°C actual 53.0°C"
      After I close the message and reset the nozzle heater everything is as expected.
      Duet 2 WiFi 2.5.1
      DWC 3.5.1
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.1 (2024-04-19 14:40:46) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6M2-NW4SD-6J9DL-3S46N-1TNRM
      Used output buffers: 1 of 26 (14 max)
      Static ram: 23256
      Dynamic ram: 73344 of which 12 recycled
      Never used RAM 16532, free system stack 184 words
      Tasks: NETWORK(1,ready,13.7%,220) HEAT(3,nWait 5,0.1%,280) Move(4,nWait 5,0.0%,359) MAIN(1,running,85.9%,743) IDLE(0,ready,0.2%,29), total 100.0%
      Owned mutexes:
      Last reset 00:06:51 ago, cause: power up
      Last software reset at 2024-10-20 20:26, reason: User, Gcodes spinning, available RAM 14088, slot 2
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 24.2, current 30.3, max 30.6
      Supply voltage: min 11.6, current 11.8, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 1 queued, 1 completed
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2024-11-06 06:17:17
      Slowest loop: 12.22ms; fastest: 0.18ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.7ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Q0 segments left 0
      Code queue 0 is empty
      === Network ===
      Slowest loop: 15.71ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      === WiFi ===
      Interface state: active
      Firmware version 1.26
      MAC address dc:4f:22:6e:70:65
      Module reset reason: Turned on by main processor, Vcc 3.37, flash size 4194304, free heap 25088
      WiFi IP address 192.168.10.151
      Signal strength -44dBm, channel 0, mode 802.11n, reconnections 0
      Clock register 00002002
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @TomasL
        @TomasL best post your config.g
        TomasLundefined 1 Reply Last reply Reply Quote 0
        • TomasLundefined
          TomasL @jay_s_uk
          @jay_s_uk
          Here they are
          config (1).g
          ; Configuration file for RepRapFirmware on Duet 2 WiFi
          ; generated by RepRapFirmware Configuration Tool v3.5.4 on Mon Oct 14 2024 21:24:21 GMT+0200 (Central European Summer Time)
          ; General
          G90 ; absolute coordinates
          M83 ; relative extruder moves
          M550 P"Frankenstein" ; set hostname
          ; Accessories
          M575 P1 S0 B57600 ; configure PanelDue support
          M552 S1 ; configure WiFi adapter
          M586 P0 S1 ; configure HTTP
          ; Smart Drivers
          M569 P0 S0 D2 ; driver 0 goes backwards (X axis)
          M569 P1 S1 D2 ; driver 1 goes forwards (Y axis)
          M569 P2 S1 D2 ; driver 2 goes forwards (Z axis)
          M569 P3 S1 D2 ; driver 3 goes forwards (extruder 0)
          ; Motor Idle Current Reduction
          M906 I30 ; set motor current idle factor
          M84 S30 ; set motor current idle timeout
          ; Axes
          M584 X0 Y1 Z2 ; set axis mapping
          M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
          M906 X800 Y800 Z800 ; set axis driver currents
          M92 X80 Y80 Z400 ; configure steps per mm
          M208 X0:200 Y0:200 Z0:200 ; set minimum and maximum axis limits
          M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
          M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
          M208 X0 Y0 Z0 S1                                       ; set axis minima
          M208 X185 Y175 Z150 S0                                 ; set axis maxima
          ; Extruders
          M584 E3 ; set extruder mapping
          M350 E16 I1 ; configure microstepping with interpolation
          M906 E1000 ; set extruder driver currents
          M92 E420 ; configure steps per mm
          M566 E120 ; set maximum instantaneous speed changes (mm/min)
          M203 E3600 ; set maximum speeds (mm/min)
          M201 E250 ; set accelerations (mm/s^2)
          ; Kinematics
          M669 K0 ; configure Cartesian kinematics
          ; Probes
          M558 K0 P9 C"^zprobe.in" H10 F120 T6000 ; configure BLTouch probe via slot #0
          G31 P500 X-37 Y0 Z2.82 ; set Z probe trigger value, offset and trigger height
          M950 S0 C"exp.heater3" ; create servo #0 for BLtouch
          ;M307 H3 A-1 C-1 D-1
          M574 X1 P"!xstop" S1 ; configure X axis endstop
          M574 Y1 P"!ystop" S1 ; configure Y axis endstop
          M574 Z1 P"!zstop" S1 ; configure Z axis endstop
          ; Mesh Bed Compensation
          M557 X10:175 Y10:175 S27.5:27.5 ; define grid for mesh bed compensation
          ; Sensors
          M308 S0 P"bedtemp" Y"thermistor" A"Heated Bed" T100000 B3950 ; configure sensor #0
          M308 S1 P"e0temp" Y"thermistor" A"Nozzle" T100000 B3950 ; configure sensor #1
          M950 H0 C"bedheat" T0 ; create heater #0
          M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0
          M307 H0 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #0
          M950 H1 C"e0heat" T1 ; create heater #1
          M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1
          M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
          ; Heated beds
          M140 P0 H0 ; configure heated bed #0
          M950 F0 C"fan0" ; create fan #0
          M106 P0 S0 L0 X1 B0.1 ; configure fan #0
          M950 F1 C"fan1" ; create fan #1
          M106 P1 S0 B0.1 H1 T45 ; configure fan #1
          M563 P0 D0 H1 F0 ; create tool #0
          M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
          ; Custom settings
          ;Injusteringsskruvar
          M671 X 95.2:-6.74:201.6 Y 191.7:-8.38:-8.38 P0.5        ; adjusting screws at rear left (-9.8,-18.3), front middle (95.2,191.7) and rear right (200.2,-18.3), thread pitch 0.5mm
          M501                                                   ; load saved parameters from non-volatile memory
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"     ; set voltage thresholds and actions to run on power loss
          T0                                                     ; select first tool
          ;Bed area
          ;M557 X10:165 Y0:170 S20 ; probe from X=10 to 190, Y=10 to 190mm with a mesh spacing of 20mm
          ;G29 S1
          config-override.g
          ; config-override.g file generated in response to M500 at 2024-10-15 00:28
          ; Heater model parameters
          M307 H0 R0.141 K0.318:0.000 D6.32 E1.35 S1.00 B0
          M307 H1 R2.020 K0.368:0.000 D4.03 E1.35 S1.00 B0 V12.0
          ; Workplace coordinates
          G10 L2 P1 X0.00 Y0.00 Z0.00
          G10 L2 P2 X0.00 Y0.00 Z0.00
          G10 L2 P3 X0.00 Y0.00 Z0.00
          G10 L2 P4 X0.00 Y0.00 Z0.00
          G10 L2 P5 X0.00 Y0.00 Z0.00
          G10 L2 P6 X0.00 Y0.00 Z0.00
          G10 L2 P7 X0.00 Y0.00 Z0.00
          G10 L2 P8 X0.00 Y0.00 Z0.00
          G10 L2 P9 X0.00 Y0.00 Z0.00
          M568 P0 R200 S220 A1
          M140 H0 S70 R55
          M144
            The M307 values in your config.g are quite different from those in config-override.g.
            when did you last tune the heaters? And how did you save the results?
            • TomasLundefined
              TomasL @Phaedrux
              @Phaedrux
              Tuned them them with M303 a couple of weeks ago and M500 to save
                Phaedrux Moderator @TomasL
                @TomasL said in Error: Heater 1 fault: exceeded allowed, when cold booting:
                Do you mean when you start a print, or when the printer powers up?
                • TomasLundefined
                  TomasL @Phaedrux
                  @Phaedrux Turned on, or reset
                    What does your temp graph actually show?
                    • TomasLundefined
                      TomasL @Phaedrux
                      @Phaedrux 53
                        I'm still confused. Is this immediately when you turn the printer on, or after you have set a temperature?
                        Can you take a picture of the temp graph?
                        • TomasLundefined
                          TomasL @Phaedrux
                          @Phaedrux When I switch Power on, or press the emergency stop and it reboots.
                          I might found the problem, last entries in the config override is intended to put the heaters at some middle temperature, in order to speed up the print.
                          I.E sett both extruder and bed at a standby temperature, however when I removed those lines the message dissapeared.
                          Obviously something is wrong with those lines
                          As I understand it
                          M140 H0 S70 R55
                          M144
                          M568 sets the extruder active and standby temperatures, and switches the extruder heater to
                          standby
                          M140 sets the bed heater standby and active temperatures.
                          M144 sets the bed heater to standby.
                          So obviously there must be something wrong with the M568-line
                            droftarts administrators @TomasL
                            @TomasL It's best not to manually edit the config-override.g. It's a firmware-generated file. Put any commands like that in config.g.
                            Also, from https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m140-set-bed-temperature-fast-or-configure-bed-heater
                            Order dependency
                            In RRF3 a M140 command with H parameter (other than H-1) must come after the M950 command that creates that heater, and before any M143 command that sets a temperature limit for that heater.
                            You don't need the H parameter in M140, you've already defined the bed. Use P if you have more than one bed (which you don't).
                            Edit: it's generally not a good idea to have heaters or motors turning on automatically at start up. If you have a fault, or you have taken something apart, and the mainboard resets, you'll get power turned on when you don't want it to, automatically.
                            • TomasLundefined
                              TomasL @droftarts
                              @droftarts
                              Yes I have realized that regarding config override.
                              However the issue with the message regarding the extruder heater is still there.
                              The bed heater did not produce any errors.
