Bluetooth PanelDue, less com issues
I made my PanelDue wireless to keep it close to me and removing the regular and unknow com error in the web interface.
- magnetic mount on the printer + soon charging with contact pins on the back instead of the usb connector.
You can't use the SD embeded port wireless (bad idea anyway).
Sorry for non official screenprobably working as good on official.
@jackantubis I love it! super cool.
was there any specific process to pair up the transmitters? Either way that is a very nice minimal way to get a mobile screen!
@Notepad yes you need to pair them Master and slave with right speed and right wiring, if you have 2 HC05 and a USB to TTL you can build a minimal setup with a power bank to supply the micro usb.
Link to the hardware used?
Hc05: https://a.aliexpress.com/_EGOKr6V
5V UPS: I just found this on AliExpress:
1,47€ | Mini 5V 1A UPS Uninterrupted Output Module 2 in 1 Charge Discharge 3.7V 3.8V 4.2V Li-Ion Li-Polymer 18650 Battery Charger Board
https://a.aliexpress.com/_EIco57n1x 18650 li-ion battery or other flat li-ion battery.
1 switch from the shelve.
My design for the case.
First revision of the tutorial for the bluetooth PanelDue
I'll appreciate some feedback on the tutorial
. Thanks for the brave who are trying the Bluetooth COM
