    Duet 6HC 1LC core xy quad z motors misbehaving
    • Polyneutron21undefined
      Polyneutron21
      I have the X on drive 0 , Y on drive 1, Z FR on drive 2, Z RR on drive 3 and Z RL on drive 4 and z FL on drive 5. When I home the X and Y work but the Z front left and the Z rear left go up while Z rear left and Z on front right go done binding the gantry. All Kysan Ocean motors are left to right (Red, Green, Yellow, Blue) and the are all paired the same. Do I need to re-wire rear right and front left motors or am I missing something. The printer is a Voron 2.4 R2.
      The config.g:
      ; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC
      ; generated by RepRapFirmware Configuration Tool v3.5.8 on Mon Nov 25 2024 09:23:39 GMT-0600 (Central Standard Time)
      ; General
      G90 ; absolute coordinates
      M83 ; relative extruder moves
      M550 P"Duet 3" ; set hostname
      M551 P"Voron24" ; set UI password
      ; Accelerometers
      ; Smart Drivers
      M569 P0.0 S1 D2 ; driver 0.0 goes forwards (X axis)
      M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Y axis)
      M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Z axis)
      M569 P0.3 S1 D2 ; driver 0.3 goes forwards (Z axis)
      M569 P0.4 S1 D2 ; driver 0.4 goes forwards (Z axis)
      M569 P0.5 S1 D2 ; driver 0.5 goes forwards (Z axis)
      ; Motor Idle Current Reduction
      M906 I30 ; set motor current idle factor
      M84 S30 ; set motor current idle timeout
      ; Axes
      M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 ; set axis mapping
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M906 X800 Y800 Z800 ; set axis driver currents
      M92 X80 Y80 Z80 ; configure steps per mm
      M208 X0:350 Y0:350 Z0:300 ; set minimum and maximum axis limits
      M566 X900 Y900 Z900 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z6000 ; set maximum speeds (mm/min)
      M201 X500 Y500 Z500 ; set accelerations (mm/s^2)
      ; Kinematics
      M669 K1 ; configure CoreXY kinematics
      M574 X1 P"io0.in" S1 ; configure X axis endstop
      M574 Y1 P"io1.in" S1 ; configure Y axis endstop
      ; Sensors
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermister on pins to temp0
      M307 H0 B0 S1.00 ;disable bang bang mode for the bed heater and set PWM limit
      M143 H1 S320 ; Set temperature range for heater 0-320C
      ; Heated beds
      M950 Fo C'121.out1" Q500 ;Ceate fan0 on pin 121.out1 and set frequency
      M106 P0 S0 H-1 ;set fan 0 value
      M950 F0 C"out7" ; create fan #0
      M106 P0 S0.5 L0 X1 B0.1 ; configure fan #0
      M950 F1 C"out8" ; create fan #1
      M106 P1 S0.5 B0.1 H1 T0 ; configure fan #1
      M563 P0 D0 H1 F0 ; create tool #0
      M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
        jay_s_uk @Polyneutron21
        @Polyneutron21 change the direction (S value on M569) on the z drivers going in the wrong direction
