    Activate fan by driver movement
    • RodrigoRMaraujoundefined
      RodrigoRMaraujo
      Hello everyone.
      Please, in RRF 3.5 is it already possible to connect a fan to the drivers that works whenever there is movement of any of the axes or extruders?
      Thanks!
      oliofundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @RodrigoRMaraujo
        @RodrigoRMaraujo you could do this via daemon.g, checking for motors idle state and enabling a fan if one of the motors is not idle (alternately check for active print).
        I know this is a common way to dynamically control electronics box fans in Klipper, but RepRapFirmware has a better way IMO: Using the MCU built in temperature reporting and configuring a thermostatic fan for that.
        If you have another application you want to use this, please do share (-;
        RodrigoRMaraujoundefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @RodrigoRMaraujo
          @RodrigoRMaraujo As @oliof suggests, using the MCU temperature works well for the reporting the temperature of the drivers. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Temperature_configuring_mcu_temp#mcu-temp-as-proxy-for-driver-temp
            RodrigoRMaraujo @oliof
            @oliof thank you!
            You reminded me of this detail about using the MCU temperature. I've been away from RRF for 2 or 3 years and just got back to it, and I ended up forgetting several details like this.
            Thank you very much, problem solved.
            M308 S2 Y"mcu-temp" A"MCU" ; configure sensor 2 as on-chip MCU temperature sensor
            M950 F2 C"out6" ; create fan #2 - Big Dipper fysect board
            M106 P2 C"5015_Drivers" H2 L0.15 X1 B0.3 T40 ; configure fan #2
              RodrigoRMaraujo @droftarts
              @droftarts thank you!
              While you were writing, I was researching this very documentation.
              Thank you very much.
              I don't know yet how to mark a topic as resolved. Should I wait for the administration or can I do it myself?
