    motherboard replacement
    244
    • adventuremanundefined
      adventureman
      how does one get a replacement motherboard for a defective one?
        droftarts administrators @adventureman
        @adventureman You tell us here what's wrong with it, and if we diagnose that it's a manufacturing fault, we approve a warranty replacement subject to our warranty policy: https://www.duet3d.com/page/warranty-policy
        Start by saying when and where you brought it from, and the result of following this guide: https://docs.duet3d.com/User_manual/Troubleshooting/Duet_wont_respond
          adventureman
          i have3 followed all the blogs and procedures from the duet site to connect to the motherboard to no avail. i have tried connecting with both wifi and usb and in all cases i get a message that says that communication was rejected. i have updated all firmware per the discussion forums and have followed all instructions for accessing via usb and duettest.local but cannot connect to the motherboard. i am at my wits end and do not know what else to do. it is a duet 2 wifi board . thanks for any help you can give
            adventureman
            the board was purchased through ali express about a moth and a half ago
            jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @adventureman
              @adventureman duet don't sell on AliExpress so I'm afraid you have a cloned board.
                @adventureman as @jay_s_uk says, it's not made by Duet3D. Contact the seller on AliExpress. They'll probably send you a new one.
                Follow this link https://docs.duet3d.com/User_manual/Troubleshooting/Duet_wont_respond, tell us what works and what doesn't, post a picture of the board when USB power is plugged in and the lights are on.
                  adventureman
                  ok so i got it to connect to the port com3 and it shows a duet on that com port but now im getting a low voltage event in yat along with no configuration files found message. i pulled the sd card and the files are there just as they were in the download. it also said that my wifi is now connected but still cannot access through the ip address
                    @adventureman Post the sys/config.g file from the SD card (either copy and paste the text, or upload the file). If you can connect via YAT, send M122, and copy and paste the response into your reply here.
                    Put the SD card in your PC, and take a screen shot of the folder structure. At a minimum, there should be a sys folder (with the config files in it) and a www folder (with the web interface files in it). See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#sd-card-structure. The SD card needs to be in the Duet for the web interface to work, and if you remove it, either reset the Duet or send M21 so it sees the SD card.
                    If you think the SD card isn't working in the Duet, see the troubleshooting section here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
                    The low voltage warning is probably that there is something in the config that tries to move a motor or turn on a heater. You can ignore this for now.
                      adventureman
                      M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
                      Board ID: 0JD0M-9K662-MGPSN-6J1D8-3SD6J-9VX6Z
                      Used output buffers: 1 of 24 (2 max)
                      Static ram: 25712
                      Dynamic ram: 93212 of which 0 recycled
                      Exception stack ram used: 328
                      Never used ram: 11820
                      Tasks: NETWORK(ready,764) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,4600) IDLE(ready,160)
                      Owned mutexes:
                      Last reset 00:37:29 ago, cause: power up
                      Last software reset at 2022-10-03 23:26, reason: User, spinning module GCodes, available RAM 10704 bytes (slot 0)
                      Error status: 0
                      Free file entries: 10
                      MCU temperature: min 20.7, current 25.8, max 39.1
                      Supply voltage: min 1.1, current 24.1, max 24.1, under voltage events: 2, over voltage events: 0, power good: yes
                      Driver 5: standstill, SG min/max not available
                      Driver 6: ok, SG min/max not available
                      Driver 7: standstill, SG min/max not available
                      Driver 8: standstill, SG min/max not available
                      Driver 9: standstill, SG min/max not available
                      Slowest loop: 99.65ms; fastest: 0.05ms
                      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                      === DDARing ===
                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                      Segments left: 0
                      Stack records: 0 allocated, 0 in use
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is idle in state(s) 0
                      serial is ready with "M122" in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 48.45ms; fastest: 0.00ms
                      HTTP sessions: 0 of 8
                      • WiFi -
                        Network state is running
                        WiFi firmware version 1.25
                        WiFi MAC address f4:cf:a2:69:52:e5
                        WiFi Vcc 3.32, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 27016
                        WiFi IP address 192.168.1.240
                        WiFi signal strength -59dBm, reconnections 0, sleep mode unknown
                        ok
                        @adventureman said in motherboard replacement:
                        Ugh, the cloners always put such old firmware on their boards. Almost certainly this is part of the problem. Probably the configuration files on the SD card are for a later version of the firmware, if you created them using the Configuration Tool: https://configtool.reprapfirmware.org/
                        The SD card interface is working, and it seems to be seeing a card is there, though hasn't tried to access it.
                        That's a bit odd. Dodgy power supply or connections?
                        • WiFi -
                          ok
                        WiFi is working fine. I Imagine most of your problems are down to the out-of-date firmware, and files on the SD card.
                        To update the firmware, I'd tend to erase the firmware and flash the latest with Bossa, see https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
                        Because to get it working with the current firmware will require you to change the files on the SD card back to the ones that match RRF 2.05.1 (from here https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1), then do the incremental upgrade described here: https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#updating-from-older-firmware-versions
                          adventureman
                          ok i got the new firmware to download and now the wifi is working and i can connect to the duet. now it seem like the polarity on the motor is reversed. when trying to home it goes in the opposite direction. can you help with this as well? dont really understand the control panel for duet
                            @adventureman See the guides on the wiki, on the left side. Work through them to understand how to change the configuration with config.g. Specifically for changing the motor direction, see https://docs.duet3d.com/en/How_to_guides/Commissioning#h-10-check-stepper-motors and see the sub section 'Reversing a stepper motor". But really you want to start at the beginning of this page, and check through everything.
