Error: G1: intermediate position outside machine limits
this is doing my head in
was working find now suddenly it doesn't work any more01-TCM-03-029 REVB_ABS_6h6m_nozzle_0.6.gcode
3.6.0-beta.2 and just tested its same with 3.5.4
there is nothing obvious in the gcode and it is working on the other machine
@dc42config.g
; Configuration file for Duet 3 Mini 5+ (firmware version 3) ; executed by the firmware on start-up G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Vega2.0" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 D3 V40 ; physical drive 0.0 goes forwards M569 P0.1 S0 D3 V40 ; physical drive 0.1 goes forwards M569 P0.2 S1 D3 V40 ; physical drive 0.2 goes forwards M569 P0.3 S1 D3 V40 ; physical drive 0.3 goes forwards M569 P0.4 S0 D3 V40 ; physical drive 0.4 goes forwards M584 X0.0 Y0.1 Z0.4 E0.2 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X100.00 Y80.00 Z1920.00 E400.00 ; set steps per mm M566 X300.00 Y300.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X2500.00 Y2500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1200 Y1200 Z900 E650 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S90 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X320 Y300 Z350 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io2.in" ; configure active-high endstop for low end on X via pin !io2.in M574 Y2 S1 P"!io4.in" ; configure active-high endstop for low end on Y via pin !io4.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe ;M950 S0 C"io3.out" M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch ;M558 P9 C"^io3.in" H5 F120 T6000 M558 P9 C"121.^io0.in" H5 F3000 T8000 S0.25 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-30 Y10 Z4 ; set Z probe trigger value, offset and trigger height M557 X20:280 Y20:280 S60 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S160 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S350 ; set temperature limit for heater 1 to 350C M308 S2 P"temp2" Y"pt1000" R2200 ; configure sensor 2 as PT1000 on pin temp2 M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H2 S350 ; set temperature limit for heater 2 to 350C ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on ; Tools M563 P0 S"Left Extruder" D0 H1 F0 ; define tool 1 G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; ; Custom settings are not defined ; Miscellaneous M575 P1 S0 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory ; T0 ; select first tool
@Aurimas At what point during the job do you get the message? I assume at the start?
The job start sequence appears to be to home all, move the nozzle to Y1 Z3, wait for temperatures, then do a mesh scan of the print area. Does that all work?
