    IR Height Sensor
    459
    • br7408undefined
      br7408
      I finally got around to building my third printer. All 3 are exactly identical printers. I am noticing a weird issue with the 3rd IR height sensor. It boots into digital mode just fine, but it seems to trigger at 2 different heights. The first height is well off the bed, second height is about normal. Never seen this before. Is this unit defective?
      • oliofundefined
        oliof @br7408
        @br7408 ISTR that there is a chance for false triggers at high distances due to stray reflections. I dont remember what the workaround/mitigation was.
        br7408undefined 1 Reply Last reply Reply Quote 0
        • br7408undefined
          br7408 @oliof
          @oliof It has this issue with any surface.
          • oliofundefined
            oliof @br7408
            @br7408 it may be a faulty probe, a similar case of this was handled under warranty (ref https://forum.duet3d.com/topic/30051/ir-probe-faulty-triggers-well-before-the-actual-trigger-point/22). One for @Phaedrux I guess.
            • br7408undefined
              br7408 @oliof
              HMMM. Strangely it seemed to fix itself somehow. I wonder if the EBB 42 woke up stupid or something.
              • oliofundefined
                oliof @br7408
                @br7408 it didnt endeavor the threat of replacemebt I guess.
                • br7408undefined
                  br7408
                  I take that back.
                  I went to calibrate the probe and I am getting errors, because it is not triggering properly. How do I initiate obtaining a replacement?
                  Here you can see it is initially triggering way low, and then nothing, and then triggering again high. Getting 2 red blinks on startup, as it should.
                  Specifically: "No trigger on probe after full movement" error in Klipper. Both other IR sensors in the other two identical machines work just fine.
                  20250128_202731.mp4
                    droftarts administrators @br7408
                    @br7408 said in IR Height Sensor:
                    It certainly looks to be a bit flaky. I think it should be replaced.
                    Is a Duet3D IR probe? Is it less than two years old? Where did you buy it from?
                    Here's the terms of the warranty: https://www.duet3d.com/page/warranty-policy
                    • br7408undefined
                      br7408 @droftarts
                      @droftarts Yes, it is Duet. Bought it through filastruder April 22nd 2023.
                        @br7408 Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                        • br7408undefined
                          br7408 @droftarts
                          @droftarts Thank you.
