    Unresponsive duet 3 6HC board
    Using Duet Controllers
    573
      droftarts administrators @gsch1803
      @gsch1803 are you setting a static IP address with M552? Have you tried a different Ethernet cable to the Duet, or checked the one you’re using with another device?
      gsch1803undefined 1 Reply Last reply Reply Quote 0
      • gsch1803undefined
        gsch1803 @dc42
        @dc42 Thank you for the response, when I send M552 I get:
        M552
        Ethernet is enabled, configured IP address: 192.168.2.1, actual IP address: 192.168.2.1
        ok
        I will try sending M122 when I get a chance to work with the board again. When I would attempt pinging the board I wouldn't get any response.
        It seems that there is no communication going through the cable whatsoever. I have tried using the cable else where and confirmed that it does function though.
        • gsch1803undefined
          gsch1803 @droftarts
          @droftarts Thank you for getting back to me. The static IP is set in the config file and verified via the M552 command. I have tried a couple ethernet cables with no luck and confirmed they work with other devices.
            Have you followed this when trying to do a direct Duet to PC connection?
            https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
            • gsch1803undefined
              gsch1803 @Phaedrux
              @Phaedrux Hi, thanks for the reply. Yes I followed that guide to get the board setup initially but since these connection issues have started this sort of approach no longer works. Computers won't even recognize a device has been connected when the duet ethernet is plugged in.
                When and where did you purchase the Duet?
                • gsch1803undefined
                  gsch1803 @Phaedrux
                  @Phaedrux I believe it was purchased from Amazon in October
                  jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @gsch1803
                    @gsch1803 what colour is the PCB?
                    • gsch1803undefined
                      gsch1803 @jay_s_uk
                      @jay_s_uk Dark blue
                        Phaedrux Moderator @gsch1803
                        @gsch1803 said in Unresponsive duet 3 6HC board:
                        Who is the amazon seller?
