    Tool-change macros with parameters
    Firmware wishlist
    344
    • reroundefined
      rero
      Good evening,
      when using duet-boards on CNC-Mills (or other devices != 3D Printer) it is required to create/write a set of tool-change macros for each tool(-position):
      tfree1.g, tpre1.g, tpost1.g, tfree2.g, tpre2.g, tpost2.g, and so on and so forth ...
      For my current project I created these files, but they contain just a single line to call a generic, parametrized version:
      ; tfree1.g calls my tool-change macro
      M98 P"tfree.g" X1
      It would be nice if such a mechanism would be supported out of the box inside RRF.
      And I could get rid of 57 macros (19 tools) in my sys-folder 😉
      jay_s_ukundefined dwuk3dundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @rero
        @rero it would be nice to be able to have tfree.g etc work without the number and just call one set of tool change files, especially if it's a single head machine.
        I'm lazy and use a macro to create multiple of the same file.
        E.g.
        while iterations < 4
                set var.filename = "tpost"^{iterations}^".g"
                echo >{var.filename} "; autogenerated tpost"^iterations^".g file"
                echo >>{var.filename} "M98 P""0:/sys/AFC/tpost.g"" A"^{iterations}
        • dwuk3dundefined
          dwuk3d @rero
          @rero From looking at the RRF code it looks like it will first try tfree with a number on it - but will then if this doesn't work it will then try a file without a number as a fallback.
          https://github.com/Duet3D/RepRapFirmware/commit/7cea891dcdc276e12edda2c991ce8fb415cfc03a
          0 chrishamm committed to Duet3D/RepRapFirmware
          Added support for tool macro fallbacks
          tpre.g/tpost.g/tfree.g is executed if the specific t...N.g macro is not found
            jay_s_uk @dwuk3d
            @dwuk oh really? I'll try that and see if it works
            reroundefined 1 Reply Last reply Reply Quote 0
            • reroundefined
              rero @jay_s_uk
              @dwuk great find!
              Just tried it on my test-setup and it works as intended.
              Only complaint: no information about the upcoming tool-number in the tpre.g macro.
              But for my concrete needs I should be able to move existing tpre-code to tpost.
              -> Maybe someone can add this information to https://docs.duet3d.com/User_manual/Tuning/Tool_changing ?
              Another idea: having another tXXX-macro which is executed in case a tool has been already selected previously (e.g. to probe a current milling-tool again).
              jay_s_ukundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
                jay_s_uk @rero
                @rero the next tool should be available in the object model under state.nextTool
                • reroundefined
                  rero @jay_s_uk
                  @jay_s_uk thanks for pointing out!
                  "Can't see the forest for the trees" ... 🕶
                  • T3P3Tonyundefined
                    T3P3Tony administrators @rero
                    @rero said in Tool-change macros with parameters:
                    paging @droftarts
                    www.duet3d.com
