    Shutdowns
    339
    • SonnyD1undefined
      SonnyD1
      I have a printer that just recently started to randomly and seemingly for no reason , just shuts down. I ran a M122 afterwards.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-rc.1 (2025-02-28 14:56:47) running on Duet WiFi 1.02 or later + DueX5v0.11
      Board ID: 0JD0M-9P6B2-NJ4S4-6JKFJ-3SJ6Q-T82AK
      Used output buffers: 1 of 26 (18 max)
      Static ram: 24016
      Dynamic ram: 68228 of which 0 recycled
      Never used RAM 30556, free system stack 140 words
      Tasks: NETWORK(1,ready,11.4%,222) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,270) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,88.4%,734) IDLE(0,ready,0.1%,29), total 100.0%
      Owned mutexes:
      Last reset 00:12:48 ago, cause: software
      Last software reset at 2025-03-08 21:47, reason: AssertionFailed, Platform spinning, available RAM 22784, slot 2
      Software reset code 0x4920 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f823 BFAR 0xe000ed38 SP 0x2001ffac Task MAIN Freestk 31431 ok
      Stack: 00002027 00476944 0045eb69 00000004 2000ba90 2000ca98 00000010 2000ca90 0045ade5 00000004 00000000 2000ca98 ffffffed 00000000 00f00000 e000e000 c0000000 20005d20 0045d2df 0045d054 21000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.4ms, write time 0.0ms, max retries 0
      Segments created 2, maxWait 268ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
      Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00
      No step interrupt scheduled
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min 0
      Driver 4: standstill, SG min n/a
      Driver 5: standstill, SG min n/a
      Driver 6: standstill, SG min n/a
      Driver 7: standstill, SG min n/a
      Driver 8: standstill, SG min n/a
      Driver 9: standstill, SG min n/a
      Driver 10:
      Driver 11:
      === DDARing 0 ===
      Scheduled moves 1, completed 1, LaErrors 0, Underruns [0, 0, 0]
      Segments left 0
      Code queue is empty
      Heater 1 is on, I-accum = 0.0
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      === Filament sensors ===
      Driver 11: ok
      === DueX ===
      Read count 1, 0.08 reads/min
      === Network ===
      Slowest loop: 8.34ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.2.1
      Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 39372
      MAC address f4:cf:a2:68:3b:2f
      IP address 192.168.1.243
      Signal strength -49dBm, channel 2, mode 802.11n, reconnections 0
      Clock register 00002002
      I have also had an error "Driver 7 Error: phase B short to ground" Anybody have an thoughts as to what may be going on?
      Here is my config.g for reference.
      ; Configuration file for Duet WiFi (firmware version 3.4.5)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 17:01:06 GMT-0500 (Eastern Standard Time)
      G21															; work in milimeters
      G90                                                         ; send absolute coordinates...
      M83                                                         ; ...but relative extruder moves
      M550 P"IDEX"                                                ; set printer name
      M111 S0														; debug off
      ;M552 S1                                                    ; enable network
      M586 P0 S1                                                  ; enable HTTP
      M586 P1 S1                                                  ; enable FTP
      M586 P2 S0                                                  ; disable Telnet
      M575 P1 B57600 S1											; enable support for PanelDue
      M569 P0 S1                                                  ; physical drive 0 goes forwards - X stepper
      M569 P1 S1                                                  ; physical drive 1 goes forwards - Z stepper (LEFT)
      M569 P2 S1                                                  ; physical drive 2 goes forwards - Z stepper (RIGHT)
      M569 P3 S1                                                  ; physical drive 3 goes forwards - E0 stepper
      M569 P6 S1                                                  ; physical drive 6 goes forwards - Y stepper (LEFT)
      M569 P7 S0													; physical drive 7 goes backwards - Y stepper (RIGHT)
      M569 P8 S1													; physical drive 8 gows forwards - U stepper
      M569 P9 S1													; physical drive 9 goes forwards - E1 stepper
      M584 X0 Y6:7 Z1:2 U8 E3:9                                   ; set drive mapping
      M350 X16 Y16 Z16 U16 E16:16 I1                              ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 U80.00 E408.21:408.21             ; set steps per mm - ESTEPS
      M205 X20.00 Y18.00 Z1.00 U20.00 E5.00:5.00          	  	; set maximum instantaneous speed changes (mm/s^2) - JERK
      M203 X12000.00 Y12000.00 Z360.00 U12000.00 E3600.00:3600.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z20.00 U2000.00 E250.00:250.00       ; set maximum ACCELERATIONS (mm/s^2)
      M204 P200 T2000												; set print & travel ACCELERATIONS (mm/s^2)
      M906 X1400 Y1400 Z1400 U1400 E600:600 I30					; set motor currents (mA) and motor idle factor in per cent
      M593 P"mzv" F60 S.7										    ; set INPUT SHAPER
      M572 D0:1 S0.080											; set PRESSURE ADVANCE for T0 & T1
      M84 S30                                                     ; Set idle timeout
      M208 X-26 Y0 U0 Z0 S1                                       ; set axis minima
      M208 X290 Y305 U360.47 Z300 S0                              ; set axis maxima, If the (T1) U offset needs to move to the -X then the U axis limit will will increase
      M574 X1 S1 P"e1stop"                                        ; configure switch-type (e.g. microswitch) endstop for low end on X via pin e1stop
      M574 U2 S1 P"duex.e6stop"									; configure switch-type (e.g. microswitch) endstop for high end on U via pin exp.e6stop
      M574 Y1 S1 P"duex.e5stop"                                   ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin exp.e5stop
      M574 Z1 S2                                                  ; configure Z-probe endstop for low end on Z
      ;M591 D0 P1 C"xstop" S1							         	; configure filament monitor (simple switch) for E0
      ;M591 D1 P1 C"duex.e4stop" S0								; configure filament monitor (simple switch) for E1
      ; Emergency Stop
      M950 J1 C"e0stop"											; identify pin number for emergency stop
      M581 P1 T0 S1 R0									        ; invoke trigger 0 when an inactive-to-active edge is detected on input 0 or input 3 and a file is being printed from SD card
      ; BLTouch
      M950 S0 C"duex.pwm1"                                        ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000                         ; set Z probe type to bltouch, connected to zprobe.in and the dive height + speeds
      G31 P500 X-31 Y-14.5 Z3.46                                  ; set Z probe trigger value, offset and trigger height. If you have to move the nozzle closer to the bed, increase the G31 Z value by the amount of baby stepping used. If you have to move the nozzle farther away from the bed, decrease the G31 Z value by the amount of baby stepping used.
      M557 X35:259 Y25:290 P5:5                                   ; define mesh grid
      M376 H10													; taper off bed compensation over 10mm
      M308 S0 P"duex.e4temp" Y"thermistor" T100000 B3950          ; configure sensor 0 as thermistor on pin duex.e4temp
      M950 H0 C"bedheat" T0                                       ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 R0.901 K0.249:0.000 D1.86 E1.35 S1.00 B0            ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                     ; map heated bed to heater 0
      M143 H0 S120                                                ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8      ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                        ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 R4.899 K0.886:0.346 D1.80 E1.35 S1.00 B0 V24.0      ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S300                                                ; set temperature limit for heater 1 to 300C
      M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin duex.e3temp
      M950 H2 C"duex.e6heat" T2                                   ; create nozzle heater output on duex.e6heat and map it to sensor 2
      M307 H2 R4.493 K0.675:0.344 D2.01 E1.35 S1.00 B0 V24.1      ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S300                                                ; set temperature limit for heater 2 to 300C
      M950 F0 C"fan2" Q500                                        ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                              ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                        ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                           ; set fan 1 value. Thermostatic control is turned on at 45c
      M950 F2 C"duex.fan3" Q500                                   ; create fan 2 on pin duex.fan3 and set its frequency
      M106 P2 S0 H-1                                              ; set fan 2 value. Thermostatic control is turned off
      M950 F3 C"duex.fan4" Q500                                   ; create fan 3 on pin duex.fan4 and set its frequency
      M106 P3 S1 H2 T45                                           ; set fan 3 value. Thermostatic control is turned on at 45c
      M563 P0 D0 H1 F0                                            ; define tool 0 that used low end X carriage
      G10 P0 X0 Y0 Z0                                             ; set tool 0 axis offsets
      G10 P0 R0 S0                                                ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 F2 X3                                         ; define tool 1 that used high end U carriage
      G10 P1 X0 Y1.16 Z.13                                        ; set tool 1 axis offsets. If T1 needs to move in the -Y then the offset number will increase +Y
      G10 P1 R0 S0                                                ; set initial tool 1 active and standby temperatures to 0C
      ; Configure Accelerometer
      ;M955 P0 I50 C"spi.cs4+spi.cs3"
      T0                                                          ; select first tool
      M98 P"startwifi.g"
      • gloomyandyundefined
        gloomyandy @SonnyD1
        @SonnyD1 said in Shutdowns:
        One for @DC42 I think.
        What was the printer doing when it shutdown? If you can get a repeatable test case that will probably help.
        SonnyD1undefined 1 Reply Last reply Reply Quote 0
        • SonnyD1undefined
          SonnyD1 @gloomyandy
          @gloomyandy It was printing. Just an ordinary print. I'm beginning to see a pattern though. It only shuts down when its printing at the same time as the Railcore that's sitting right next to it is. Could be a coincidence but I don't think so.
          Notepadundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • Notepadundefined
            Notepad @SonnyD1
            @SonnyD1 This is going to sound real odd. But what powersupply are you using.
            I know the M122 says the reason is a software shutdown. But I have experienced in the past a weird brownout situation where one printer with a cheap PSU was browning the entire power ring for my house, and it would randomly do weird power spikes which caused machines to fail
            The real bamboo printer manufacturer
              dc42 administrators @SonnyD1
              @SonnyD1 please post further M122 reports if it happens again. The one you posted indicates what appears to me to be a very strange failure within FreeRTOS. If further shutdowns show the same cause then this would suggest a firmware issue; however if the causes look random then that would indicated an issue with ESD or mains transients - which would tie in with the issue only occurring when another piece of equipment is running.
              Also please check that the VIN terminal block screws of the Duet and DueX are still tight.
              SonnyD1undefined 2 Replies Last reply Reply Quote 0
              • SonnyD1undefined
                SonnyD1 @Notepad
                @Notepad Meanwell LRS-350-24. I don't buy cheap parts. I considered the possibility of a bad or faulty power supply because lets face it, it does happen. However, with this power supply it would be the least likely culprit I think. That said, I'm not opposed to replacing it since they are pretty affordable. I'd like to pursue other possibilities first.
                Notepadundefined 1 Reply Last reply Reply Quote 0
                • Notepadundefined
                  Notepad @SonnyD1
                  @SonnyD1 The power supply is good as it has integrated filtering. If you did want a cheap solution without changing the PSU, have a look at filter EMI power receptacles.
                  • SonnyD1undefined
                    SonnyD1 @dc42
                    @dc42 That was the first check I made. Everything is snug with a good connection. I'm in the middle of a long print and the neighboring Railcore isn't running. No shutdowns yet. If is does point to only happening when a neighboring machine is running, how would I resolve that?
                    • SonnyD1undefined
                      SonnyD1 @dc42
                      @dc42 So that long print I was talking about shut down again in the middle of the night with nothing else running. Here is the M122: Thoughts?
                      M122
                      Used output buffers: 10 of 26 (24 max)
                      Static ram: 24016
                      Dynamic ram: 68252 of which 0 recycled
                      Never used RAM 30532, free system stack 156 words
                      Tasks: NETWORK(1,ready,9.7%,222) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,288) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,90.2%,734) IDLE(0,ready,0.0%,29), total 100.0%
                      Owned mutexes:
                      Last reset 02:18:04 ago, cause: software
                      Last software reset at 2025-03-11 06:24, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 24264, slot 0
                      Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0041f803 BFAR 0xc9900000 SP 0x200022f8 Task MAIN Freestk 922 ok
                      Stack: 80fe8000 43300000 00000000 407f4000 86600000 004601f3 0046262c 810e1a00 004084f3 00000000 00000064 004601f3 200023d3 00000001 00000001 00000000 00000066 0045c543 0000000a 00000000 41ec9c4c 20002418 00000000 40490000 0000000e 00000073 20002410
                      === Storage ===
                      SD card longest read time 3.3ms, write time 0.0ms, max retries 0
                      Segments created 2, maxWait 264ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
                      Driver 10:
                      Driver 11:
                      === DDARing 0 ===
                      Segments left 0
                      Code queue is empty
                      Driver 11: ok
                      === DueX ===
                      Read count 1, 0.01 reads/min
                      === Network ===
                      Slowest loop: 10.20ms; fastest: 0.00ms
                      === WiFi ===
                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39372
                      Signal strength -53dBm, channel 2, mode 802.11n, reconnections 0
                        @SonnyD1 once again this is a very strange failure, this time inside the floating point maths library. So I still think it was caused by either a power brownout or by an ESD event. Are the metalwork of your hot end and the body of the extruder motor connected to Duet ground?
                        • SonnyD1undefined
                          SonnyD1 @dc42
                          @dc42 No. Frankly I suspected that may be the issue.
