    Voron Trident XY configuration
    • SpeedyDadundefined
      SpeedyDad
      I'm building a Voron trident using a Duet Mini 5+. It was part of an older printer I have retired and want to recycle the electronics. The Trident uses A and B drives instead of X and Y. For configuration sakes, I need to know is A=X and Y=B or vice versa. I guess I could just plug them in and play with the config until things go the proper directions but figured someone here might know. Thanks.
        This may prove useful to you.
        https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_coreXY
        X and Y isn't quite right for corexy kinematics because both motors contribute to the X and Y only motion. So the motors are described as A and B. But the important thing is that the movement of the X and Y axis is correct for a right handed coordinate system.
        SpeedyDadundefined 1 Reply Last reply Reply Quote 0
          SpeedyDad @Phaedrux
          @Phaedrux OK, so just assign either one to X and Y and then just fix the directions in the config?
            Phaedrux Moderator @SpeedyDad
            @SpeedyDad said in Voron Trident XY configuration:
            A=X and Y=B
            Just go with this.
