    [3.6.0-rc.1] Z-probe starts untriggered even when the probe is.
    Beta Firmware
    z-probe firmware
    • tcamguilundefined
      tcamguil
      I am running a 3D-printer with a klicky as the Z-probe.
      Meaning the Z-probe is not on the toolhead most of the time
      When I boot up the printer the Z-probe value is at 0 even if the Z-probe is not on the toolhead (ie: open-circuit, ie: should be triggered).
      But as soon as I load and unload the probe once the Z-probe value is now correctly set to 1000.
      I tried to set the Z-probe as a scanning probe and it correctly displays a value of 65000 as soon as the printer boots.
      I haven't updated the config.g file after upgrading from 3.5.4 and it was working fine
      extract from the config.g file
      ;Kliky
      M558 P8 C"11,io0,in" H2:0.25 F1200:120 T18000 K0 R0.0 A15 S0.005 ; set Z probe type to bltouch and the dive height + speeds
      (the forum thinks this is an URL hence the commas)
      G31 P500 X-42.00 Y0.00 Z-25.000 K0 ; set Z probe trigger value, offset and trigger height
      M556 S50 X0 Y0 Z0 U0 ; set orthogonal axis compensation parameters
      M557 X0:300 Y0:250 S50 ; define mesh grid
      Board Name:
      • Duet3-6HC
      • Toolboard1LC
      Firmware Version:
      • MB6HC: 3.6.0-rc.1 (2025-02-28 15:00:13)
      • Toolboard1LC: 3.6.0-rc.1 (2025-02-28 15:03:36)
      DWC Version: 3.6.0-beta.2
      Raspberry Pi: No
      I have looked for threads already mentioning this issue and not found any.
        jay_s_uk @tcamguil
        @tcamguil this has already been fixed in the source a couple of days ago.
        See here https://github.com/Duet3D/RepRapFirmware/commit/85d692da97158febf620a891fa7dca4814e62db3
        Not sure if there has been a subsequent test release made available that includes this fix
        FYI, you should update your DWC version to be the same as the firmware version
        0 dc42 committed to Duet3D/RepRapFirmware
        Fixed initial value of digital remote Z probes when they are created
        Thanks to Andy Shaw for this one
        • tcamguilundefined
          tcamguil
          Thanks for the fast response.
          No, it has not yet been made available for the public as I re-downloaded the files this morning before posting.
          I will then wait patiently for the next update.
          • gloomyandyundefined
            gloomyandy @tcamguil
            @tcamguil There is a test build in this thread that may have the fix in it... https://forum.duet3d.com/topic/37610/3-6-0-beta1-rc1-laser-not-working/4
            • tcamguilundefined
              tcamguil
              It is working now
              thank you
              • dwuk3dundefined
                dwuk3d
                I've had a few issues with probes showing up as triggered when they aren't and I'm fairly sure that this happens in 3.5.4 too on a 1LC tool board (with 6HC main board).
                I've found you need to move through the trigger point up to 2 times to get the problem to clear.
                Glad it is being fixed in a later release.
                My workaround is to add this to Bed.g before every probe
                   M400
                    if sensors.probes[0].value[0] > 0
                        M98 P"0:/macros/probefix.g"
                ;probefix.g
                if exists(global.mms) == true
                    M596 P0
                G1 Z0.5
                M400
                G1 Z5
                M400
                G1 Z0.3
                M400
                G1 Z7
                M400
                echo "probe after error handler:",sensors.probes[0].value[0]
                  dc42 administrators @dwuk3d
                  @dwuk3d this particular bug was new in 3.6.0-rc.1.
                  • tcamguilundefined tcamguil marked this topic as a question
                  • tcamguilundefined tcamguil has marked this topic as solved
