    Custom toolboard + duet wiring limitations
    537
    • SamKudarauskasundefined
      SamKudarauskas
      I am looking to design a toolhead breakout board very similar to the prusa loveboard. I want to run all the hot end, io, fan, ect wires to this breakout board I am designing and then have each of the individual components, ie fans/ hot end plug into my board.
      How are fans/ heaters/ io ports, ect. controlled exactly? Are the V+ pins turned on and off or the V- pins? Since many of the compents use 24V and all need ground can the number of wires I run to the breakout board be simplified? What I am curious to know is if for example all components are controlled by turning on the V+ pin can I connect the ground pins of all of my components on the breakout board together and just run one ground pin back to the duet? Or visa versa with +24V?
      I am using a duet mini 5+
      Looking to connect to my custom breakout board:
      • 40W heater
      • thermistor
      • 3wire heatsink fan
      • 2wire part cooling fan
      • Pancake stepper motor
      • my force sensitive resistor bed probe
      • maybe also integrate the accelerometer into the PCB
      Thank you for your help and insight.
      -Sam
      • fcwiltundefined
        fcwilt @SamKudarauskas
        @SamKudarauskas
        What would be the benefit of such a board if it is merely controlled by I/O pins from the main board?
        Have you looked at the various CAN bus boards that achieve the sort of control you are talking about using just 4 wires from the main board to the remote board - power (2 wires) and the CAN bus (2 wires).
        SamKudarauskasundefined 1 Reply Last reply Reply Quote 0
          SamKudarauskas @fcwilt
          @fcwilt Yes I have considered those boards. I have a few reasons for wanting to make such a board. First, I have designed a manual tool swap mechanism that lets me unclip the tool from the gantry and swap in a different tool. (This lets me make a custom extruders and rapidly switch between them). Secondly, it is significantly more convenient and easy to just plug in a new fan if one breaks to my board then to pull out the old cable and run the new cable all the way back to the mainboard. Third, it means I can make the wiring harness much neater and smaller because I can run a single ribbon cable from the mainboard to the tool instead of needing to run like 18 individual wires back to the mainboard. Fourth, my design will cost only a few dollars rather than the $40+ than the duet tool board would cost me.
          Sam
          • fcwiltundefined
            @SamKudarauskas
            Have you determined how many conductors your ribbon cable will need to be equivalent to the individual wires, taking into account the various different wire gauges that would likely be in use?
            For example I run 18 gauge wire to carry the load of the heaters and fans which works out to about 16 conductors in common ribbon cable with 24 gauge conductors.
            Is your tool swapping device something like these?
            Hermit Crab
            Mutant
              @fcwilt Mine is similar. However it rather than an electrical connection between the master plate and the tool plate mine is purely mechanical and I plan to just unplug the single ribbon cable from my PCB when I switch tools. Yes, I have taken into account the necessary wire gauges for the heaters.
              Sam
              jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                jay_s_uk @SamKudarauskas
                @SamKudarauskas everything switches on the negative side
                  SamKudarauskas @jay_s_uk
                  @jay_s_uk So am I safe to connect everything that uses +24V together (hot end heater and two fans) and then just run each individual ground wire back? Is this unadvisable for any/all of the components I wish to connect to my board? Also does the thermistor run on +3.3V and can its +V wire be combined with that of my force sensitive resistor that uses an io port?
                  Thank you for your help - Sam
                    @SamKudarauskas nothing wrong with you bunching all the 24v together with individual grounds back.
                    The thermistor uses VSSA so it would have to have its own wiring
                    you may have difficulties with an accelerometer as it uses SPI to connect and being combined with all the other cabling you may have interference issues
                      @jay_s_uk Ok thank you for your help. Is using out1's 24V line the best place to draw the 24V from to power everything? Also, would using a separate ribbon cable be best for the accelerometer or would that still have interference problems if that ribbon cable is in the same wiring loom as the main ribbon cable?
                        @SamKudarauskas I would just take the power directly from the PSU and then make sure you don't exceed the mosfets switching capability for each out connection you're going to use to switch load.
                        and a separate cable would be a better idea. I've been able to run an accelerometer with a 2.7m USB3 cable. you may get away with a ribbon cable
                          @jay_s_uk Why is taking the +24V from a main line rather than from the dedicated +24V pin for each component run the risk of blowing the mosfet? What is the current limit on the mosfets and is my wire simplification idea worth it if I run the risk of damaging the board? What kind of precautions could I take to just use the +24V from heater 1?
                          Also, I probably should have mentioned this earlier but I was inspired by this:d1fff08d-df40-4b34-b015-67dd643a6564-image.png
                          Edit: link to part here
                          On this stealthburner part it appears that they hae done some sort of wire simplification since it looks like they have more things connected to the board then wires running back to the main baord and I wanted to do something similar.
                          Edit: The stealthburner part has pins labeled +24V (connected to heater 0 V+), +5V and GND which appear to have multiple things connected to it. Hence where my idea to simply the wiring came from.
                            SamKudarauskas
                            What is the mosfet switching capacity of the fan GND pins? Is it rated to handle the current that heater 1 outputs? If it is, would that be the simpliest way to simplify the wires and feed +24V to heater 1 and both of my fans?
                              @SamKudarauskas i meant to reply to you before.
                              The heater outputs on a mini 5+ can handle 5A switching loads each (out 1 and out 2) and the rest of the outs (out 3 - out 6) can handle 2A switching loads per output, all at 24V.
                              So as long as whatever you're switching (heater or fan etc) is less than those values each you'll be fine.
                              If you take the supply from out1, the maximum onboard 24v output current is 10A, that includes steppers etc which is why toolboards etc are usually wired directly to the PSU with their own fuse.
                              Are you looking to replicate the stealthburner setup?
                              Typically running lots of wires like the stealthburner setup you linked to was only done because some people were cheap and they couldn't afford a CAN toolboard or because some people are against CAN in the klipper world.
                              But when you typically find, unless you're running proper cable aimed at continually being moved and conform to t he correct bend radius of stuff, one of the cables will break. You constantly hear voron users with the stock setup complaining of a cable being broken preventing something from working.
                              So my advise would be to avoid this sort of setup, especially if you're running a mutlicore cable to the print head.
                              Is there any particular reason you're against using a CAN toolboard?
                              What type of toolhead setup is it?
                                @jay_s_uk Thank you for your reply. Do I understand this correctly? As long as each fan draws less than the 2A switching load max then it doesn't matter where the +24V comes from, so I can use out1 to power the heater and the two fans.
                                I'm not looking to directly replicate the stealth burner setup. I like to build different toolheads for my custom built 3D printer which is why I built a tool hot swap setup. My printer is small and my duet has many available pins on it so I'd rather just use the capabilities of my mainboard then spend $45+ dollars on a Duet tool board for each new tool I build.
                                My idea has all of the convivences of a CAN tool board without the extra cost. My Prusa Mk4S with the Prusa Loveboard has a very similar setup to my idea for the same reasons and I wanted to implement it in the printer that I built. By making it myself it can be much more compact since it doesn't need any driver chips on it as well. Also truthfully, its a fun project for me to learn KiCAD.
                                  @SamKudarauskas fair enough.
                                  and yes, you understand that correctly
                                    @jay_s_uk Thank you for your help. Is the duet IO pins capable of triggering different events if it receives a pulse of being turned on/off versus a stable on or off signal?
                                      @SamKudarauskas yes. have a look at M581
                                        @jay_s_uk M581 appears to be used to detect going from low to high or high to low for some trigger, how can I use that to map it to different actions based off of if it goes high low high quickly or just from low to high and stays that way?
                                        fcwiltundefined gloomyandyundefined droftartsundefined 3 Replies Last reply Reply Quote 0
                                        • fcwiltundefined
                                          @SamKudarauskas
                                          I'm using a Duet 3 6HC board with 3.5.4 firmware.
                                          I have cases where I have used M581 to assign two triggers to the same input.
                                          One for the inactive-to-active condition and the other active-to-inactive condition.
                                          It seems to work just fine.
                                          But I'm not sure how you would detect a steady state condition.
                                          • gloomyandyundefined
                                            gloomyandy @SamKudarauskas
                                            @SamKudarauskas It might help if you explain what it is you are trying to do here. So what sensor (or other input) are you trying to monitor and what conditions do you want to detect and what do you want to do when that condition is detected.
