    ender 5
    My Duet controlled machine
    448
    • Rob Holierhoekundefined
      Rob Holierhoek
      running an ender 5 with duet2 wifi managed to get network running and having an issue while it homes fine and can probe the bed mesh all speeds seem fine but when I print a file everything seems slow and constantly pauses second issue is i cannot post anything until I have 2 rep points on these forums kind of frustrating as I am soo close to having this working any help would be great thanks
      jay_s_ukundefined 1 Reply Last reply Reply Quote 2
        jay_s_uk @Rob Holierhoek
        @Rob-Holierhoek you probably have your firmware type set to something other than reprapfirmware in the slicer you're using.
        And for pauses it could be that your z jerk is too low and you're using a bed mesh
        Rob Holierhoekundefined 4 Replies Last reply Reply Quote 0
          Rob Holierhoek @jay_s_uk
          @jay_s_uk i have it set for rep rap in the slicer
            @jay_s_uk i will try changing those thanks ill let you know
              droftarts administrators @Rob Holierhoek
              @Rob-Holierhoek what slicer are you using? Most likely the slicer is overriding the speeds and acceleration limits you have set. It’s also possible you have some setting like ‘adaptive pressure advance’ or ‘adaptive jerk’, which RRF doesn’t support. Post a small Gcode file that exhibits the problem, and your config.g,
              For suggested slicer settings see https://docs.duet3d.com/en/How_to_guides/Calibration#h-7-suggested-slicer-settings
              The ‘two upvotes’ stops the spammers. I’ve added an upvote.
              Rob Holierhoekundefined 1 Reply Last reply Reply Quote 0
                @jay_s_uk ; Configuration file for Duet WiFi (firmware version 3.3)
                ; generated by RepRapFirmware Configuration Tool v3.4.1 on Tue Jan 21 2025 16:44:34 GMT-0500 (Eastern Standard Time)
                M550 P"*****" ; set printer name
                M551 P"********" ; set password
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P3 S0 ; physical drive 3 goes backwards
                M92 X400.00 Y400.00 Z400.00 E420.00 ; set steps per mm
                M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X500.00 Y500.00 Z10.00 E5000.00 ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                M906 X950 Y950 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X220 Y220 Z300 S0 ; set axis maxima
                M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                G31 P500 X-5 Y-10 Z2.5 ; set Z probe trigger value, offset and trigger height
                M557 X15:200 Y15:200 S50 ; define mesh grid
                  Rob Holierhoek @Rob Holierhoek
                  @Rob-Holierhoek now the issue is the home x and y are correct but when it homes to z it goes to the center of the bed and when it does its leveling it seems it isnt happy at the home position frustrating to say the least
                      @Rob-Holierhoek 10mm/min max speed for z is super low
                      we'd also need to see your homing files
                        Rob Holierhoek @droftarts
                        @droftarts CE5_3DBenchy.gcode
                          @jay_s_uk ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool v3.4.1 on Tue Jan 21 2025 16:44:35 GMT-0500 (Eastern Standard Time)
                          G91 ; relative positioning
                          G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                          G1 H2 X5 Y5 F6000 ; go back a few mm
                          G1 H1 X-225 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
                          G90 ; absolute positioning
                          G1 X20 Y25 F6000 ; go to first bed probe point and home Z
                          ;G91 ; relative positioning
                          ;G1 Z5 F100 ; lift Z relative to current position
                          ;G90 ; absolute positioning
                            @jay_s_uk ; homex.g
                            ; called to home the X axis
                            G1 H1 X-225 F1800 ; move quickly to X axis endstop and stop there (first pass)
                            G1 H2 X5 F6000 ; go back a few mm
                            G1 H1 X-225 F360 ; move slowly to X axis endstop once more (second pass)
                            G1 H2 Z-5 F6000 ; lower Z again
                              @jay_s_uk ; homey.g
                              ; called to home the Y axis
                              G1 H1 Y-225 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                              G1 H2 Y5 F6000 ; go back a few mm
                              G1 H1 Y-225 F360 ; move slowly to Y axis endstop once more (second pass)
                                @jay_s_uk ; homez.g
                                ; called to home the Z axis
                                G1 X20 Y25 F6000 ; go to first probe point
                                  Rob Holierhoek
                                  managed to get things printing at a decent speed it was issue with the slicer not set same as the config for the duet...running pretty good speed and nice and quiet thanks for all the advice
