    Where can i drill big holes in the smarteffector? dual-extruder
    1060
    • lazy_mosquito
      lazy_mosquito last edited by
      i just adapted the smarteffector for use with a bigger mounting plate. Works great!
      i also adpted a 3mm E3d direct drive heatsink for use with the smarteffector as a 3mm bowdendrive with a screwtop. Also working great!
      Next experiment is a dualdrive setup with the smarteffector. So I will have to drill two 12mm holes in the pcb.
      Which parts are drillable? Would it be possible to mark this places on the drawing in the Wiki? (I am aware this will void my guarantee)
      btw: How can i upload a picture on this forum?
      • DjDemonD
        DjDemonD last edited by
        Use a service like postimage.io upload image then copy the "direct link" and then use
        www.precisionpiezo.co.uk
        • Dougal1957
          Dougal1957 last edited by
          but simple answer is you can't drill 2 12 mm holes in the effector without destroying the sensor elements
          • lazy_mosquito
            @ Simon: Thanks
            • lazy_mosquito
              @Dougal:
              Lasercutting? I expect there are places in the pcb which are not used for the copper lanes?
              • Rommie
                Rommie last edited by
                Nope the 3 sensors are around the entire part, if your intention is to use the stress sensors for bed leaving there is no way, if not then drill anywhere
                • T3P3Tony
                  You may even be able to see the pattern of the copper strain traces of you login at the effector under the right light. As already stated, drilling anywhere will stop the sensor working.
                  www.duet3d.com
                  • lazy_mosquito
                    OK, i checked it again, and i suppose the hatched zones you can see around the heatsink are the sensor element?
                    OK this messages crossed eachother 🙂
                    Any plans to create a dual extruder smarteffector?
                    • DjDemonD
                      Youre welcome, you could use a y splitter to unload/load filament via one filament path?
                      • c310
                        c310 last edited by
                        I guess there is another vote for dual extruder 🙂
                        https://www.duet3d.com/forum/thread.php?id=3003
