2 NEW DUET 2 WIFI's W/EXTERNAL ANTENNA WILL NOT CONNECT
@jay_s_uk I'm really confident that the antenna is connected correctly but I will mention that it is not mounted it is just laying near the board
@GBusy24 just laying around is fine. In that case, I would suggest changing the antenna
@jay_s_uk okay, but who will sell me just the antenna? I have two because I have two new boards. Maybe I should try the other antenna off of The Other Board
@jay_s_uk I will say that when working with the other board the green light on the Wi-Fi module would blink constantly where I get nothing out of this current board I'm working with
@GBusy24 yea, try the other one.
you can get antennas off amazon easily enough. search for aU.FL Antenna
for wifi -
@jay_s_uk okay thanks
@jay_s_uk I've now switched out the antennas, but still in same condition. No connection. Scratching my head. Here's a pic of the board. Is it a mistake to wire everything up before connecting? I know I've done this before successfully.20250415_191452.jpg
@jay_s_uk I set my network ...........it remembers it and M587 confirms. I send M552 S1 and get 'No known networks found".
M587 S"Greg's WIFI" P"**********"
M587
Remembered networks:
Gregs WIFI IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
TNCAPF318D9 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
ok
M552 S1
ok
Error: WiFi module reported: no known networks found -
Just to confirm the situation.... Is this correct?
- you have two old Duet 2 wifi boards that worked with the wifi network in question previously.
- you have two new Duet 2 wifi boards with external antenna that both show No known networks found?
The network in question is a 2.4Ghz network?
Can you test in access point mode to remove your network from the equation?
https://docs.duet3d.com/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
@Phaedrux The answer is yes to all 3 of your questions. It's morning here and I'll try that when I get home from work.
