    Duet2 Wifi, sensorles homing
    • mrjoneskodundefined
      mrjoneskod
      Re: Anybody using a Duet board with a Klipper SBC?
      Does anyone know how to enable stall guard or sensorless homing in Klipper when using Duet2 wifi? I have looked around, and what I found so far isn't very promising:
      github.com/Klipper3d/klipper/issues/3298
      Since it works with RRF, I don't see why it can't work with Klipper.
      I can't use RRF because my toolhead uses CAN bus (SB2209). I looked at schematics, 3 different ones for Duet2, but found nothing that isn't in the GitHub post.
      Pin PB5 current doesn't seem to change from the regular 1.5v on stall guard enable, which doesn't trigger the home position.
      Any help appreciated, as I want to avoid the extra wiring, and I don't need the extra precision of endstop switches.
      Thanks!
        Phaedrux Moderator @mrjoneskod
        @mrjoneskod said in Duet2 Wifi, sensorles homing:
        You'd have to ask the Klipper folks.
        mrjoneskodundefined 1 Reply Last reply Reply Quote 0
          mrjoneskod @Phaedrux
          @Phaedrux Yeah, already did. It seems like Klipper looks for the signal coming from the SG_TST pin, which seems to be PB5 for all steppers.
          I wanted to find out the approach used by RRF so I can try to amend the code and add a PR to Klipper repo.
          I am not very good with electronics, but I am an SWE. So if I understand the mechanism, I think I may be able to add this, solve my problem and help other folks in the same situation as I am.
            dc42 administrators @mrjoneskod
            @mrjoneskod RRF on Duet 2 and Duet 3 6HC boards polls the status of all drivers over SPI at frequent intervals, thereby getting the complete driver status including open load, short circuit, over temperature etc. flags as well as the stall status.
            On Duet 3 Mini it uses the individual DIAG outputs of the drivers to detect stalls instead, because the UART interface to the drivers on that board is much slower.
              mrjoneskod @dc42
              @dc42 Thanks. Is there anything else you could give to help on this quest? Schematics of the poll and how to read the status for each stepper, for example?
              For now, I downloaded the TMC 2660 docs and will start with that. I appreciate your time. @Phaedrux, thanks as well!.
              If I make any progress, I will post about it here.
              jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @mrjoneskod
                @mrjoneskod AFAIK, klipper doesn't currently support getting sensorless homing status over SPI like RRF does. In which case, that'll all need implementing into klipper
                  @mrjoneskod you can find the interrupt service routine for SPI transfer to drivers completed at https://github.com/Duet3D/RepRapFirmware/blob/139f16f52cd30a12431bdf5884aee6bc637b26c4/src/Movement/StepperDrivers/TMC2660.cpp#L874. The ISR checks whether a transfer has been completed and if so, reads the status and kicks off another transfer.
                  On boards other than Duet 2 we use a separate FreeRTOS task to poll the drivers, so as to simplify the control flow and do less work in the ISR.
