    G30 during G28 issue
    My Duet controlled machine
    1.0k
    • Leonard03undefined
      Leonard03 @dc42
      @dc42 This a ressuregt.g after a print that had a shift, that I cancelled
      ; Resume printing file "0:/gcodes/xyzCalibration_cube,0.2mm,PLA,Anycubic PLA Pantone Spring Leaf,25m.gcode" after print paused at 2025-05-19 21:06
      M140 P0 S60.0
      G29 S1
      M568 P0  A0 S210 R170
      M568 P1  A0 S210 R170
      M568 P2  A0 S210 R170
      M568 P3  A0 S210 R170
      M568 P4  A2 S210 R170
      G21
      M98 P"resurrect-prologue.g" X144.359 Y141.863 Z3.400 U57.000 V0.000 W17.998
      M290 R0 X0.000 Y0.000 Z0.000 U0.000 V0.000 W0.000
      M205 X10.00 Y10.00 Z0.40 U1.00 V4.00 W0.10
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00 U0.00 V0.00 W0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00 U0.00 V0.00 W0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00 U0.00 V0.00 W0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00 U0.00 V0.00 W0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00 U0.00 V0.00 W0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00 U0.00 V0.00 W0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00 U0.00 V0.00 W0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00 U0.00 V0.00 W0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00 U0.00 V0.00 W0.00
      M486 S-1
      T4
      G54
      M106 S0.99
      M116
      G92 E1.83369
      M83
      G94
      G17
      M23 "0:/gcodes/xyzCalibration_cube,0.2mm,PLA,Anycubic PLA Pantone Spring Leaf,25m.gcode"
      M26 S54031
      G0 F6000 Z5.400
      G0 F6000 X144.359 Y141.863 U57.000 V0.000 W17.998
      G0 F6000 Z3.400
      G1 F1871.0 P0
      M204 P1000.0 T2000.0
      G21
      M106 P0 S0.99
      M302 P0
      M24
      And this is resurrect-prologue.g
      M17 E0
      G28 X Y						; home X and Y, hope that Z hasn't moved
      if global.MMUmode = true
      	M98 P"0:/sys/MMU Control/homeMMU.g"
      G91
      G1 Z-5
      Please have a look at this description
      @Leonard03 said in G30 during G28 issue:
      Reenable the extruder stepper (this is a very old bug in RRF. I can't use the MMU to load filament if the extruder stepper is disabled, so enable it before anything else)
      Home X and Y axis (Z axis has never been disabled)
      Rehome the MMU (UVW axis)
      Lower the Z axis (I can't remember exactly why this is necessary, but it works)
      And after, RRF executes ressurrect.g.
      Until now, is anything that seems out of place?
        droftarts administrators @Leonard03
        @Leonard03 We are homing in on a bug, related to applying the skew compensation when axes are homed at the same time. In 3.5.4, this worked correctly, but now doesn't seem to.
        The difference is in how the skew compensation is applied. "resurrect-prologue.g" needs to run just X and Y homing, it runs home X, then home Y. Skew compensation is applied to X once Y is homed. In homeall.g, X and Y are homed at the same time, but doesn't seem to apply skew compensation until after the first move, which is when the axes move to resume the print, so will be in the wrong place.
        A workaround for now is to modify your homeall.g so it homes X, then Y, rather than both at the same time. Either replace the X and Y homing lines with the lines from homex.g and homey.g, or as @fcwilt mentioned earlier in this thread, replace them by calling the homex.g and homey.g macros, eg
        M98 P"homex.g"
        M98 P"homey.g"
        Then it should resurrect in the same place. @dc42 is working on a fix.
        Leonard03undefined 2 Replies Last reply Reply Quote 1
          Leonard03 @droftarts
          @droftarts Interesting point of view. All right, I'm trying this now and report back
            @droftarts Tried the suggested workaround
            Umm.. I don't know what to say
            I've modified the homeall.g from:
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.2.0 on Tue Dec 29 2020 16:23:44 GMT+0200 (Eastern European Standard Time)
            G91							; relative positioning
            G1 H2 Z5 F6000				; lift Z relative to current position
            G1 H1 X-320 Y-306 F1800		; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X5 Y5 F6000				; go back a few mm
            G1 H1 X-320 Y-306 F240		; move slowly to X and Y axis endstops once more (second pass)
            G1 H1 Z-405 F240			; move Z down stopping at the endstop
            G90							; absolute positioning
            G1 Z5
            G1 X{(310/2)-sensors.probes[0].offsets[0]} Y{(310/2)-sensors.probes[0].offsets[1]} F6000
            G30
            G1 X0 Y0
            to
            ; homeall.g
            M98 P"homex.g"
            M98 P"homey.g"
            G1 Z5
            G30
            G1 X0 Y0
            Is an improvement, still shifted but way less then before
            From left to right: No skew compensation, in homeall.g homing both X and Y at the same time and the last is calling independent macros in homeall.g
            The shift is reduced from 2mm to 1mm
            Update: if during a pause I rehome X or Y the print resume at the right position
              @Leonard03 Okay, thanks for testing! Back to the drawing board...
              Leonard03undefined 1 Reply Last reply Reply Quote 0
                @droftarts sorry... 😐
                  @Leonard03 Are you still using RRF 3.6.0-rc3+2 firmware?
                    @droftarts Yes, 3.6.0-rc.3+2 (2025-05-19 11:46:09)
                      dc42 administrators @Leonard03
                      @Leonard03 please try this firmware.
                      Duet2CombinedFirmware.bin
                      Leonard03undefined 1 Reply Last reply Reply Quote 1
                        Leonard03 @dc42
                        @dc42 Thank you very much! I confirm that this issue is solved! Works very ewll 😊
                        Also, thank you to everyone for every input and all the support !
                        • Leonard03undefined Leonard03 has marked this topic as solved
                          @Leonard03 thanks for your feedback and for testing all these firmware builds.
