G30 during G28 issue
Hello everyone. I got a very strange problem with homing my printer that I observed only now.
First of all, those are my macros:
From config.gM950 S0 C"!exp.heater7" M558 P9 C"^zprobe.in" H4:2 F240:120 T9000 A20 S0.01 G31 P500 X-27.4 Y-28.6 Z2.00 M557 X8.0:285.0 Y21.6:279.4 P10 ... M208 X4 Y-2 Z0 S1 if global.MMUmode = true M208 U0 V-1000 W0 S1 M208 X315 Y308 Z400 S0 if global.MMUmode = true M208 U75 V1000 W225 S0
Homeall.g
G91 G1 H2 Z5 F6000 G1 H1 X-320 Y-306 F1800 G1 X5 Y5 F6000 G1 H1 X-320 Y-306 F240 G1 H1 Z-405 F240 G92 Z0 G90 G1 Z5 G1 X{(310/2)-sensors.probes[0].offsets[0]} Y{(310/2)-sensors.probes[0].offsets[1]} F6000 G30 G1 X0 Y0 if global.MMUmode = true M98 P"0:/sys/MMU Control/homeMMU.g"
Homex.g
G91 G1 H2 Z5 F6000 G1 H1 X-320 F1800 G1 X5 F6000 G1 H1 X-320 F240 G1 H2 Z-5 F6000 G90
homey.g
G91 G1 H2 Z5 F6000 G1 H1 Y-306 F1800 G1 Y5 F6000 G1 H1 Y-306 F240 G1 H2 Z-5 F6000 G90
The problem occurs in homeall.g. In this macro, using the
G30
command is introducing an offset of about 10mm in homing position. This doesn't sound like much but during aM916
or if I rehome the X axis during a pause, a layer shift of about 10mm occures in the X- direction.
In any case, on PanelDue or in DWC reported coordinates ar always correct. Only the physical position is wrong. Homing only X axis, is working as it should.
Inhomeall.g
, with G30 at line 12:
and with G30 commented out:
Both photos are taken after aG1 X0 Y0
Duet 2 WiFi running RRF 3.6.0-rc.3
Any clues? -
@Leonard03 said in G30 during G28 issue:
G1 H1 Z-405 F240
G92 Z0You also have a z endstop?
Please post your full config.g and the results of M122 and M98 P"config.g"
@Phaedrux Thank you for the replay
@Phaedrux said in G30 during G28 issue:
Yes, is there, so why not use it
When homing Z I lower the gantry until that switch is triggered and then do a
G30
in the center of the bed.@Phaedrux said in G30 during G28 issue:
This is my full config, but it uses some additional macros
; Configuration file for Duet WiFi (firmware version 3.5) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.0 on Tue Dec 29 2020 16:23:44 GMT+0200 (Eastern European Standard Time) global MMUmode = true ; enable or disable Multi Material Unit if global.MMUmode = true global spoolJoin = false ; enable or disable the SpoolJoin feature of the Multi Material Unit global useCutter = true ; enable or disable the CUT feature of the Multi Material Unit global statusBondtech = 0 global statusFinda = 0 global currentSlot = {null, null} ; [0]last loaded slot, [1]last tool temperature global loadNext = false global pause = false global tcBlock = false global counter = {0,0,0} ; [0]extruder count, [1]fails, [2]total attempts global errQueue = {null,null} ; first two elements are reserved ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves if global.MMUmode = false M550 P"Creality CR-10L" ; set printer name else M550 P"Creality CR-10L+MMU3" ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; enable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards (X) M569 P1 S1 ; physical drive 1 goes forwards (Y) M569 P2 S0 ; physical drive 2 goes backwards (Z1) M569 P3 S0 ; physical drive 3 goes forwards (E) M569 P4 S0 ; physical drive 4 goes backwards (Z2) if global.MMUmode = true M569 P5 S1 ; physical drive 3 goes forwards (U) M569 P6 S0 ; physical drive 3 goes backwards (V) M569 P7 S1 ; physical drive 3 goes backwards (W) M584 X0 ; set drive mapping for X axis M584 Y1 ; set drive mapping for Y axis M584 Z2:4 ; set drive mapping for Z axis (dual independent) if global.MMUmode = true M584 E3:3:3:3:3 ; set drive mapping for virtual extruders M584 U5 ; set drive mapping for U axis (MMU selector) M584 V6 ; set drive mapping for V axis (MMU pulley) M584 W7 R1 S1 ; set drive mapping for W axis (MMU idler) else M584 E3 ; set drive mapping for extruder M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation if global.MMUmode = true M350 U16 V16 W16 I1 M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm if global.MMUmode = true M92 U400 V167.13 W8.89 M566 X600.00 Y600.00 Z24.00 E3000.00 ; set maximum instantaneous speed changes (mm/min) if global.MMUmode = true M566 U60 V240 W6 M203 X18000.00 Y18000.00 Z1200.00 E7200.00 ; set maximum speeds (mm/min) if global.MMUmode = true M203 U2700 V5700 W18000 M201 X3000.00 Y3000.00 Z100.00 E3000.00 ; set accelerations (mm/s^2) if global.MMUmode = true M201 U200 V800 W1000 M201.1 X500 Y500 Z50 E500 ; set reduced acceleration for special move types (mm/s^2) if global.MMUmode = true M201.1 U100 V400 W500 M906 X1000 Y1000 Z800 E600 I40 ; set motor currents (mA) and motor idle factor in per cent if global.MMUmode = true M906 U700 V700 W700 if global.MMUmode = true ; set idle timeout M906 T60 else M906 T30 ; Axis Limits M208 X4 Y-2 Z0 S1 ; set axis minima if global.MMUmode = true M208 U0 V-1000 W0 S1 M208 X315 Y308 Z400 S0 ; set axis maxima if global.MMUmode = true M208 U75 V1000 W225 S0 ; Endstops M574 X1 S1 P"^xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"^ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"^zstop" ; configure active-high endstop for low end on Z via pin zstop if global.MMUmode = true M574 U2 S3 M574 V2 S3 M574 W1 S3 ; Z-Probe M950 S0 C"!exp.heater7" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H4:2 F240:120 T9000 A20 S0.01 ; set Z probe type to bltouch and the dive height + speeds S0.005 G31 P500 X-27.4 Y-28.6 Z2.00 ; set Z probe trigger value, offset and trigger height M557 X8.0:285.0 Y21.6:279.4 P10 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S110 ; set temperature limit for heater 0 to 110C M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1 ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; E3D V6 thermistor (Semitec 104-GT2) M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S400 ; set temperature limit for heater 1 to 400C ; Fans M950 F0 C"fan0" Q10000 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 L0.3 C"Tool" ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1+^exp.pb6" Q25000 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 C"Heatsink" ; set fan 1 value. Thermostatic control is turned on ; Tools if global.MMUmode = false M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets M568 P0 R0 S0 A0 ; set initial tool 0 active and standby temperatures to 0C elif global.MMUmode = true M563 P0 S"Slot 1" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets M568 P0 R0 S0 A0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"Slot 2" D1 H1 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets M568 P1 R0 S0 A0 ; set initial tool 1 active and standby temperatures to 0C M563 P2 S"Slot 3" D2 H1 F0 ; define tool 2 G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets M568 P2 R0 S0 A0 ; set initial tool 2 active and standby temperatures to 0C M563 P3 S"Slot 4" D3 H1 F0 ; define tool 3 G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets M568 P3 R0 S0 A0 ; set initial tool 3 active and standby temperatures to 0C M563 P4 S"Slot 5" D4 H1 F0 ; define tool 4 G10 P4 X0 Y0 Z0 ; set tool 4 axis offsets M568 P4 R0 S0 A0 ; set initial tool 4 active and standby temperatures to 0C ; Custom settings M81 C"pson" ; ATX in stadby mode at boot M308 S2 Y"mcu-temp" A"MCU" ; MCU temperature sensor (sensor 2) M912 P0 S-7.2 ; set temperature monitor adjustment (MCU) M308 S3 Y"drivers" A"SD Duet" ; duet drivers temperature sensors (sensor 3) if global.MMUmode = true ; duet drivers temperature sensors, only when MMU is used (sensor 4) M308 S4 Y"drivers-duex" A"SD DueX" M308 S5 P"e1temp" Y"thermistor" T100000 B4092 A"Ambient" ; Ambient teperature sensor (sensor 5) M307 H0 R0.135 C783.5 D0.39 S1.00 V12.2 ; set the process parameters (bed 60degC) M307 H1 R1.757 K0.275:0.139 D6.31 E1.35 S1.00 B0 V12.2 ; set the process parameters (hotend 210degC) M207 S0.8 F1800 ; set retract length (PLA) M404 N1.75 ; set filament width if global.MMUmode = false M591 D0 P2 C"^e0stop" S0 ; filament monitor connected to E0 endstop (Drive 0), not enabled M950 J1 C"^e1stop" ; Input 1 uses e2stop pin, pullup enabled (EmergencyStop button) M581 P1 T0 S1 R0 ; external trigger 1, trigger occurs on the active-to-inactive edge, trigger at any time M950 J2 C"^duex.e3stop" ; Input 1 uses e2stop pin, pullup enabled (power feedback for UPS) M581 P2 T2 S1 R1 ; external trigger 1, trigger occurs on the inactive-to-active edge, trigger at any time (UPS Backup power) M581 P2 T3 S0 R2 ; external trigger 1, trigger occurs on the active-to-inactive edge, trigger only when not printing from SD card (AC back, resume prompt) M593 P"ZVD" F30.1 S0.05 ; use MZV input shaping to cancel ringing at 26.35Hz, damping factor 0.1, minimum acceleration 20mm/s^2 ;M204 P600 T800 ; set printing and travel accelerations (mm/s^2) - original Creality CR-10S ;M204 P1000 T2000 ; set printing and travel accelerations (mm/s^2) - Artillery SW-X2, https://github.com/MarlinFirmware/Configurations/tree/import-2.1.x/config/examples/Artillery/Sidewinder%20X2 M204 P1250 T1250 ; Prusa MK4 ;M204 P1500 T2000 M671 X-25:334 Y0:0 S2.5 F1.6 ; adjusting screws at front left, back left, back right and front right. Thread pitch M4 corse: 0.7mm M556 S100 X0.69 ; axis skew compensation, diagonal method if global.MMUmode = true M98 P"0:/sys/MMU Control/settingsPrinter.g" M98 P"0:/sys/MMU Control/settingsDefaultFilament.g" M98 P"0:/sys/MMU Control/currentSlot.g" M98 P"0:/sys/MMU Control/currentSlotReset.g" ; Miscellaneous M575 P1 S1 B115200 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory
This is the full SD card: https://drive.google.com/drive/folders/1OcTPiUw0RlYuLT-Skopb6It37nG4u9Io?usp=drive_link
M98 P"config.g"
This is failing short because of global variables defined at startup..
M98 P"config.g" Error: in file macro line 6 column 17: meta command: variable 'MMUmode' already exists
@Leonard03
I don't have an answer for your original issue, but...If you want to get your
config.g
to run withM98
without the error after startup, you can use theexists()
function to check if the global already exists and use the result to skip defining the globals again.
https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands
So this,
becomes this,
if !exists(global.MMUmode) global MMUmode = true if global.MMUmode = true global spoolJoin = false ; enable or disable the SpoolJoin feature of the Multi Material Unit global useCutter = true ; enable or disable the CUT feature of the Multi Material Unit global statusBondtech = 0 global statusFinda = 0 global currentSlot = {null, null} ; [0]last loaded slot, [1]last tool temperature global loadNext = false global pause = false global tcBlock = false global counter = {0,0,0} ; [0]extruder count, [1]fails, [2]total attempts if !exists(global.errQueue) global errQueue = {null,null}
Then just change the
true
tofalse
on line 2 to achieve the mode your desire between reboots.You only need to check
MMUmode
because ifMMUmode
doesn't exist, then none of the globals can exist becauseMMUmode
is used to create all of the other globals. -
@davidjryan Thank you for the suggestion. I might modify all the startup in the near future. I'm still thinking about
M505
to split my printer in two separate configurations. Anyway, you gave me a very good idea. Is way easy at least for now to comment out all global variables and macros that create them. So, the response is this:
@PhaedruxM98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled
G30
in the center of the bed.Using it makes perfect sense.
What is odd, at least to me, is that your homing code is written as if there is not a Z end-stop. Those G1 H2 Z# commands are not needed if you simply home Z first and leave it at a safe position for then homing X and Y.
Now is is just my personal preference but I forgo the minor optimizations that can be done in homeALL.g by just invoking the individual homing routines:
M98 P"homeZ.G" M98 P"homeX.G" M98 P"homeY.G"
One other minor difference is that I don't set the Z=0 Datum during homing but only:
- when creating a height map
- when loading a height map
- when starting a print
Doing this ensures that any possible variations due to thermal changes are taken into account.
As to the original issue I am still stumped - something is being overlooked I imageine.
One thing to remember is the some errors in config.g can cause the processing of config.g to be cut short.
I dealt with this by tracing the processing of config.g to make sure that it ran to completion:
At the start of config.g I have this local variable declared:
var trace = "config_trace.txt"
Then I create the first line of the file:
echo >{var.trace} "trace begun"
Then I add additional lines as seem appropriate at appropriate locations:
echo >>{var.trace} "network config" echo >>{var.trace} "motor config"
Finally at the end of config.g I have this:
echo >>{var.trace} "trace done"
It's not much work and can save time in the long run.
@Leonard03 did you ever test this system using RRF 3.6.0-rc.2; and if so, did that have the same issue?
I made a change to the way G30 probe coordinates are calculated between rc.2 and rc.3. It's possible that this change may have introduced a fault that is specific to Duet 2 boards.
@fcwilt Thank you for the extensive response. I will try to answer your ideas an questions in order
so:
@fcwilt said in G30 during G28 issue:
Homez.g I tried to keep it as simple as possible. Most of the time I don't use individual homing files, and every time I home XY and after Z and if MMU is enabled W V and U in that order.
I use theH2
parameter in home X and Y only because it allow movement of Z.@fcwilt said in G30 during G28 issue:
I use this approach only for the MMU part (UV and W) The only reason I don't use this for main axis is because I like the motion of both X and Y during homing, in tandem
Running both as separate
M98
calls will separate that motion, that I don't like. Aesthetics, only reason :)) Ah, and I set the Z offset only during a print using G28 because the homez.g I can use it for another thing: rough leveling the bed after disassembly. After that I use the BL touch for more accurate Z0.
Before any print and before bed tramming (G32) and mesh (G29) yes, i use the sensor. for anything else, the switch is good enough (another example is NonLinear Extrusion calibration. Extruding in mid air)@fcwilt said in G30 during G28 issue:
I am pretty sure that is the case..
Very good point! And I have a dumb answer to this :)) Apart of the last command regarding the config-override.g.. If my config.g gets in trouble, I know it because the PanelDue will remain not connected :)) So.. if PanelDue is is not connecting, I know that I messed something up in the config
@dc42 said in G30 during G28 issue:
Thank you for your replay. I tried rc.2 now with the same result... Sadly I don't know when this behavior started. I will try with rc.1 as well and report back
Thanks for the reply.
Since you have a Z end-stop homing Z first means you have no need to use G1 H2 commands.
Why not use the simplest code possible?
I understand it may be satisfying in some sense to optimize homing by coding homeALL.g discretely but that again makes the code more complicated. Also it means if you find a flaw in homing X or Y you have to makes changes in multiple places.
In any case it's your printer to configure as you please, just offering advice based on many years of programming experience and several years for using Duet hardware.
Now back to the original issue.
If you don't set the Z=0 Datum in the homing code, it all homes correctly?
When you set the Z=0 Datum in some separate code is the X position the same before and after executing the code?
@dc42 Found when! Tried now old binaries that I have saved.
This particular issue occurred between3.6.0-beta.2+4 (2024-12-01 18:14:39)
and3.6.0-beta.2+5 (2025-01-04 14:18:24)
In +4 version the X axis homes in the same location regardless of theG30
. In the +5 version.. well.. is the present topic. I also have the .map files for them if they help you in any way -
@fcwilt Now, back on the 3.6.0-rc.3
You pointed out some very interesting things, I admit!@fcwilt said in G30 during G28 issue:
Now looking at that particular macro.. I wonder the same.. Why?
For those two points, I don't have an answer, just an excuse :)) This macro most likely is the original generated by the RRF configurator for the version 3.2. So is quite old. But if it is not broken, don't fix it
This is the excuse. But now I'm releasing that it makes no sense now.
This part, done. Removed the line that contained theG1 H2
command from homez.g.@fcwilt said in G30 during G28 issue:
Thank you very much for this, I really appreciate this ^_^
Let me see if I understand the question correctly:
You are referring to theG92 Z0
command, right?
I use it in both homez and homeall.- Removing it from homez.g: no change, so another line deleted
- Removing it from homeall.g: no change, so another line deleted as well
The original issue is still present, sadly..
As for this
I don't understand your question, I apologize. Plese give me a little more details so I can try out
Let's assume the current Machine Position is X=20 Y=20.
To verify this you will need to check in the Object Model as the DWC user interface shows User Position, not Machine Position.
Then execute the G30 at that position.
Then check the Machine Position to see if it has changed.
@fcwilt Right, got the point!
I've made this little macro:; printer is homed using G28 X Y Z prior to executing this macro G90 G1 Z10 F600 ; space for the BLTouch pin to extend echo "User " ^ move.axes[0].letter ^ " position is: ", move.axes[0].userPosition echo "Machine " ^ move.axes[0].letter ^ " position is: ", move.axes[0].machinePosition echo "User " ^ move.axes[1].letter ^ " position is: ", move.axes[1].userPosition echo "Machine " ^ move.axes[1].letter ^ " position is: ", move.axes[1].machinePosition
This is the result after
G28 X Y Z
:User X position is: 4.739 Machine X position is: 4.739 User Y position is: -2.000 Machine Y position is: -2.000
Now, moving the nozzle 100mm in X and Y, so,
G1 X100 Y100 F2400
User X position is: 100.000 Machine X position is: 99.997 User Y position is: 100.000 Machine Y position is: 100.000
G30
and the result:User X position is: 99.285 Machine X position is: 99.285 User Y position is: 100.000 Machine Y position is: 100.000
Not exactly, but they seems to be pretty close. The physical position is way bigger
Good job.
Very strange.
I'm wondering at this point if there is a problem in the firmware.
If I was using RC firmware (which I never do) I would resort to the last stable version prior to the RC version and see if the problem goes away.
@fcwilt Thank you ^_^
Digging deeper, I got something:@Leonard03 said in G30 during G28 issue:
This particular issue occurred between 3.6.0-beta.2+4 (2024-12-01 18:14:39) and 3.6.0-beta.2+5 (2025-01-04 14:18:24).
I feel really sorry... Looking at commits on GitHub between those dates, there were many and substantial changes in RRF.. I feel sorry because only now I came across this bug (?) after so much time
There was a time when I would install beta or rc firmware - but no longer - I have things to print.
So I am still using 3.5.4.
. In the +5 version.. well.. is the present topic. I also have the .map files for them if they help you in any wayThanks for pinning this down to that version increment. I will review the commit history and work out the cause. It may be specific to Duet 2.
@Leonard03 are you able to reproduce this issue other than in the homing file?
For example: suppose you home the printer, then send G1 X150 Y150. Ignore any error that this point. Then send G30 zero or more times; then send G1 X160 Y160. Does the head position at this point (relative to where the head was after the G1 X150 Y150) depend on how many times you sent G30?
PS - one more test please: if you temporarily set the probe X and Y offsets to 0 in your G31 command, does the issue still occur?
PPS - created https://github.com/Duet3D/RepRapFirmware/issues/1116
I'm glad I can help
@fcwilt @davidjryan Sorry for the delay.. Thank you guys for your help. I managed to modify my configuration, cleaned up some macros, renamed some others to make them easy to follow so now I can use the command
M98 P"config.g"
and you both were right. Is way better now, thank you again ^_^@dc42 said in G30 during G28 issue:
So far, no. Is only related to homing, with or without a probe.
I will use every time the individual homing files, do some
G30
s at some points (I think they will change) and report back. I will use the macro above to keep track of the coordinates
