    Jerky movements, again
    6.2k
      @roboduet:
      I hear this clicking sounds with interpolation disabled at 1/16 microstepping.
      Also seems like I found bug, printer completely freezes (including ESP8266 web server code) then I executing this commands: [c]G28[/c] to home printer, [c]M350 X16 Y16 Z16 I0[/c] to disable interpolation (interpolation enabled in config) and then start printing file without (!) homing after executing M350 command. This is reproducible every time I enter this commands.
      I can guess what is happening. Executing M350 flags the axes as not homed, so for every move that your file asks for there will be a error message generated. The Duet will run out of message buffers, so it will no longer process status requests. Sending a pause command via USB or possibly PanelDue may still work. Or you can wait until the file finishes"printing".
      • roboduetundefined
        roboduet
        @dc42:
        So my guess is that the clicking noises are produced when the drive gets the interpolation wrong, perhaps when a carriage reverses direction in the middle of a move.
        Just small note about interpolation and this clicks - linear (straight) movement of effector does not produce this clicks with interpolation enabled. At the start of first two videos effector goes down to Z = 10.3 mm at X0 and Y0 and then goes to start of circle at X-49.744 Y1.647. This straight move is without clicks.
        To summarize my messages:
        Moves with clicks: segmented (many g-codes with short straight lines) movement around circle regardless of interpolation mode at 1/16 microstepping.
        Moves without clicks: straight movement with any microstepping setting or segmented movement around circle with 1/256 microstepping.
        I will try tomorrow to create small script that produces straight segmented moves and slightly bent (extremely large radius) segmented moves to test how angle between two straight movement g-codes affects this.
        • roboduetundefined
          roboduet
          I'm just created simple script that produces segmented (0.5 mm) straight movement from X-50 Y-50 to X50 Y50 and then goes back to X-50 Y-50 with single g-code:
          [[language]]
          T0
          G21 ; set units to millimeters
          G90 ; use absolute coordinates
          M83 ; use relative distances for extrusion
          G1 X-50 Y-50 Z10.300 F4800
          G1 X-49.5 Y-49.5 F960
          G1 X-49 Y-49
          G1 X-48.5 Y-48.5
          G1 X-48 Y-48
          G1 X-47.5 Y-47.5
          G1 X-47 Y-47
          G1 X-46.5 Y-46.5
          G1 X-46 Y-46
          G1 X-45.5 Y-45.5
          G1 X-45 Y-45
          G1 X-44.5 Y-44.5
          G1 X-44 Y-44
          G1 X-43.5 Y-43.5
          G1 X-43 Y-43
          G1 X-42.5 Y-42.5
          G1 X-42 Y-42
          G1 X-41.5 Y-41.5
          G1 X-41 Y-41
          G1 X-40.5 Y-40.5
          G1 X-40 Y-40
          G1 X-39.5 Y-39.5
          G1 X-39 Y-39
          G1 X-38.5 Y-38.5
          G1 X-38 Y-38
          G1 X-37.5 Y-37.5
          G1 X-37 Y-37
          G1 X-36.5 Y-36.5
          G1 X-36 Y-36
          G1 X-35.5 Y-35.5
          G1 X-35 Y-35
          G1 X-34.5 Y-34.5
          G1 X-34 Y-34
          G1 X-33.5 Y-33.5
          G1 X-33 Y-33
          G1 X-32.5 Y-32.5
          G1 X-32 Y-32
          G1 X-31.5 Y-31.5
          G1 X-31 Y-31
          G1 X-30.5 Y-30.5
          G1 X-30 Y-30
          G1 X-29.5 Y-29.5
          G1 X-29 Y-29
          G1 X-28.5 Y-28.5
          G1 X-28 Y-28
          G1 X-27.5 Y-27.5
          G1 X-27 Y-27
          G1 X-26.5 Y-26.5
          G1 X-26 Y-26
          G1 X-25.5 Y-25.5
          G1 X-25 Y-25
          G1 X-24.5 Y-24.5
          G1 X-24 Y-24
          G1 X-23.5 Y-23.5
          G1 X-23 Y-23
          G1 X-22.5 Y-22.5
          G1 X-22 Y-22
          G1 X-21.5 Y-21.5
          G1 X-21 Y-21
          G1 X-20.5 Y-20.5
          G1 X-20 Y-20
          G1 X-19.5 Y-19.5
          G1 X-19 Y-19
          G1 X-18.5 Y-18.5
          G1 X-18 Y-18
          G1 X-17.5 Y-17.5
          G1 X-17 Y-17
          G1 X-16.5 Y-16.5
          G1 X-16 Y-16
          G1 X-15.5 Y-15.5
          G1 X-15 Y-15
          G1 X-14.5 Y-14.5
          G1 X-14 Y-14
          G1 X-13.5 Y-13.5
          G1 X-13 Y-13
          G1 X-12.5 Y-12.5
          G1 X-12 Y-12
          G1 X-11.5 Y-11.5
          G1 X-11 Y-11
          G1 X-10.5 Y-10.5
          G1 X-10 Y-10
          G1 X-9.5 Y-9.5
          G1 X-9 Y-9
          G1 X-8.5 Y-8.5
          G1 X-8 Y-8
          G1 X-7.5 Y-7.5
          G1 X-7 Y-7
          G1 X-6.5 Y-6.5
          G1 X-6 Y-6
          G1 X-5.5 Y-5.5
          G1 X-5 Y-5
          G1 X-4.5 Y-4.5
          G1 X-4 Y-4
          G1 X-3.5 Y-3.5
          G1 X-3 Y-3
          G1 X-2.5 Y-2.5
          G1 X-2 Y-2
          G1 X-1.5 Y-1.5
          G1 X-1 Y-1
          G1 X-0.5 Y-0.5
          G1 X0 Y0
          G1 X0.5 Y0.5
          G1 X1 Y1
          G1 X1.5 Y1.5
          G1 X2 Y2
          G1 X2.5 Y2.5
          G1 X3 Y3
          G1 X3.5 Y3.5
          G1 X4 Y4
          G1 X4.5 Y4.5
          G1 X5 Y5
          G1 X5.5 Y5.5
          G1 X6 Y6
          G1 X6.5 Y6.5
          G1 X7 Y7
          G1 X7.5 Y7.5
          G1 X8 Y8
          G1 X8.5 Y8.5
          G1 X9 Y9
          G1 X9.5 Y9.5
          G1 X10 Y10
          G1 X10.5 Y10.5
          G1 X11 Y11
          G1 X11.5 Y11.5
          G1 X12 Y12
          G1 X12.5 Y12.5
          G1 X13 Y13
          G1 X13.5 Y13.5
          G1 X14 Y14
          G1 X14.5 Y14.5
          G1 X15 Y15
          G1 X15.5 Y15.5
          G1 X16 Y16
          G1 X16.5 Y16.5
          G1 X17 Y17
          G1 X17.5 Y17.5
          G1 X18 Y18
          G1 X18.5 Y18.5
          G1 X19 Y19
          G1 X19.5 Y19.5
          G1 X20 Y20
          G1 X20.5 Y20.5
          G1 X21 Y21
          G1 X21.5 Y21.5
          G1 X22 Y22
          G1 X22.5 Y22.5
          G1 X23 Y23
          G1 X23.5 Y23.5
          G1 X24 Y24
          G1 X24.5 Y24.5
          G1 X25 Y25
          G1 X25.5 Y25.5
          G1 X26 Y26
          G1 X26.5 Y26.5
          G1 X27 Y27
          G1 X27.5 Y27.5
          G1 X28 Y28
          G1 X28.5 Y28.5
          G1 X29 Y29
          G1 X29.5 Y29.5
          G1 X30 Y30
          G1 X30.5 Y30.5
          G1 X31 Y31
          G1 X31.5 Y31.5
          G1 X32 Y32
          G1 X32.5 Y32.5
          G1 X33 Y33
          G1 X33.5 Y33.5
          G1 X34 Y34
          G1 X34.5 Y34.5
          G1 X35 Y35
          G1 X35.5 Y35.5
          G1 X36 Y36
          G1 X36.5 Y36.5
          G1 X37 Y37
          G1 X37.5 Y37.5
          G1 X38 Y38
          G1 X38.5 Y38.5
          G1 X39 Y39
          G1 X39.5 Y39.5
          G1 X40 Y40
          G1 X40.5 Y40.5
          G1 X41 Y41
          G1 X41.5 Y41.5
          G1 X42 Y42
          G1 X42.5 Y42.5
          G1 X43 Y43
          G1 X43.5 Y43.5
          G1 X44 Y44
          G1 X44.5 Y44.5
          G1 X45 Y45
          G1 X45.5 Y45.5
          G1 X46 Y46
          G1 X46.5 Y46.5
          G1 X47 Y47
          G1 X47.5 Y47.5
          G1 X48 Y48
          G1 X48.5 Y48.5
          G1 X49 Y49
          G1 X49.5 Y49.5
          G1 X-50 Y-50
          Update: also click frequency directly depends on frequency of g-codes, seems like this clicks going between g-code commands. Maybe something like fill of next command queue or read-ahead of g-codes freezing movements?
          Example of low-frequency clicks with longer segments:
          [[language]]
          T0
          G1 X-50 Y-50 Z10.300 F4800.000
          G1 X-50 Y-50 F960
          G1 X-45 Y-45
          G1 X-40 Y-40
          G1 X-35 Y-35
          G1 X-30 Y-30
          G1 X-25 Y-25
          G1 X-20 Y-20
          G1 X-15 Y-15
          G1 X-10 Y-10
          G1 X-5 Y-5
          G1 X0 Y0
          G1 X5 Y5
          G1 X10 Y10
          G1 X15 Y15
          G1 X20 Y20
          G1 X25 Y25
          G1 X30 Y30
          G1 X35 Y35
          G1 X40 Y40
          G1 X45 Y45
          Now I'm sure that this clicks are result of a lot of g-code fragments. David, I think that something wrong.
          • roboduetundefined
            roboduet
            @dc42:
            Thanks for your example. My printers are out of action until my office refurbishment is complete, but I'll try it out when I can. Feel free to remind me on Wednesday if you don't get a response before then.
            David, did you have time to check this? It seems to me that RRF produces very small pauses after each g-code, this pauses causes jerky moves. Even linear (straight?) movement of effector on my delta produces this pauses. You can view example g-codes in my previous post. But 1-line (w/o segments) g-code does not produce this pauses.
            Now I can hear this pauses almost in every print with smooth curved movements 🙂
            • botundefined
              bot
              I think if I listen very carefully to my delta running a 0.8.5 I can hear similar sounds. Can you post photos of the surface defects it creates on the sides of the print? I'm sorry if you posted this already and I missed it.
              *not actually a robot
              • roboduetundefined
                roboduet
                @bot:
                I said earlier that I'm unable to take macro photos of differences with acceptable quality of photo. I will try later with another plastic colors and right light. UPD: this defects looks like vertical columns of very small plastic blobs on surface of printed part.
                Also I said before that print quality isn't a problem for me, I'm happy Duet WiFi owner, but I still think that something is wrong here with g-code processing or something another.
                That's why I'm trying to draw David's attention to this problem. But seems like he is very busy in the last month and haven't time to check this.
                • botundefined
                  bot
                  Okay, no worries. I just figured since I checked the other day and noticed a faint sound that is similar to yours, and with the same consistency, that I'd let you know. I don't notice any print defects at all that I can attribute to this noise, however.
                    I am sorry, it is still on my list to investigate.
                      I finally got round to testing this. I can hear and feel clicks on my deltas but they are very faint, perhaps because my printer has 0.9deg motors.
                      At this stage I can think of two possible explanations:
                      1. At the boundaries between segments, the motor positions each have to be rounded to the nearest microstep. Interpolation doesn't help here. The clicks may just be the result of this rounding.
                      2. Or there could be a problem with the precise time interval between the start of the old move and the start of the new move. Currently, the new move starts as soon as the old move has taken its last step; but the first step of the new move won't happen until it is due.
                      I will investigate further.
                      • roboduetundefined
                        roboduet
                        Thank you, David!
                        Also I noticed that in 1/256 microstepping mode this clicks not audible nor feeling. Maybe this can help to investigate.
                        • roboduetundefined
                          roboduet
                          Hello, David. Do you have any news? Maybe I can help you testing/debugging this issue?
                            My best guess is that the clicks are due to the boundaries between segments having to be rounded to the nearest microstep for each motors. That would explain why reduces or goes away at higher microstepping. But I have it on my list to check the pulse time with an oscilloscope, to make sure that each move is starting at the correct time and is not early or late.
                            • roboduetundefined
                              roboduet
                              Seems like beta boards does not have pins for step signals for onboard drivers or I just overlooked something.
                              I remapped drivers to expansion header pins (M584 X6 Y5 Z8) and connected logic analyzer to this pins.
                              Then I manually pressed homing switches during homing to cheat homing procedure and printer "homed" correctly. Then I captured X/Y/Z step signals during g-code printing with segmented straight movement with this clicks.
                              I see pauses in step signal generation but I can not interpret this information correctly.
                              If you wish I can upload logic analyzer dump file. I'm using Seleae Logic software, it's free to download. Also I can export data in other formats.
                              • botundefined
                                bot
                                Would it be possible to take screenshots of the output of the software and post the results here? Thanks, roboduet, for being persistent and proactive about what you feel is an underlying issue. This may turn out to be a very useful avenue of exploration, even if to simply determine that this behaviour is unavoidable.
                                • roboduetundefined
                                  roboduet
                                  Yes, I can post images. I also want to say again that I do not fully understand what happens and who is responsible for this (logic analyzer hardware, usb bus, software or Duet itself).
                                  Pauses are selected with marker (blue icons). X channel is first from top, Y is second, Z is third (bottom).
                                  @bot - thanks for your support 🙂
                                    Thanks for posting those traces.
                                    I see that each pause is less than twice the normal pulse interval for that motor, and the pauses do not occur on all motors at the same point. Also there is sometimes a reduction in the interval between pulses instead of a pause.
                                    I think this confirms my suspicion that the pauses are caused by the need to round each motor position to the nearest microstep at the junction between each pair of segments. Such rounding is unavoidable. Increasing the microstepping is the only real cure I can think of.
                                    Whereas all other delta printer firmwares chop moves into short segments, RRF doesn't except when grid bed compensation is enabled, and even then the segments are quite long (about as long as the grid spacing). So this should be much less of an issue with RRF than with other firmwares.
                                    btw you can use M584 to map each motor to more than one driver, allowing you to use the internal drivers as well as putting the pulses on the expansion connector.
                                    • roboduetundefined
                                      roboduet
                                      Yet another two examples. I just created g-code with 50 millisecond segments (F1200, 1mm movements), so pauses (or step signals with shorter interval) going exactly every 50 ms, easy to find in analyzer logs:
                                      All three motors paused at 7.420+ s position
                                      Pause for X step, premature step for Y and Z at 7.520+ s position
                                      Pause for X and Y, premature step for Z at 7.670+ s position, also steps are skewed at 7.770+ s position
