RepRapFirmware 2.0 with RTOS in development
I do have a PanelDue. I disconnected it and had no further disconnects. Didn't try putting it in Setup.
Tried three prints today. All Benchys.
First print completed successfully.
Second print never starting printing before claiming 100% done and returning to idle. Don't know if heating completed.
Third print completed successfully.
I didn't reset between these prints. Just picked the print again button. -
Thanks. I put my Panel Due on the Setup page and had no further disconnects. I thought I had protected all the critical places in the output buffer management system with a mutex, but it looks like I must have missed one.
Exiting!
I'll be following this closely. We had an earlier discussion about G code look-ahead to enable rising/lowering of extruder temperature according to the current extrusion speed. I hope this is on the list somewhere.
Another thing I have been pondering is a "predictive" and self-adjusting start time for the heating up of the hotend in relation to the timeline of the heating of the bed in order to save some time when starting a print. With the PID parameters resulting from the auto-tune of the heated bed, one should be able to estimate the time when the bed reaches the target temperature. The same goes for the hotend. With these estimated predictions, one should be able to start the heating of the hotend at a certain time during the heating of the bed so that both the bed and hotend reaches the target temperature at the same time.
Small adjustment to this factors can be made by measuring the actual time each print. Over time, the prediction factors will "home in" on the correct value as the printer is being used. -
I've just released another 2.0 alpha. The two bugs in the previous release (crash if you tune a heater, and DWC disconnecting after a while if a PanelDue is also connected) are believed fixed. Nevertheless, I caution against using this release for doing long-running prints. The DWC disconnects were caused by printf in the GNU C library not being re-entrant if you use floating point formats. There may be other issues in the library with lack of reentrancy that I haven't mitigated yet.
Hi David,
This is the first run for me with RTOS, here you can find M122 resultM122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)alpha1 running on Duet WiFi 1.02 or later
Board ID: 08DAM-9K9K2-NGNSN-6J9D6-3S46J-TPSMJ
Used output buffers: 2 of 40 (31 max)
Static ram: 28484
Dynamic ram: 97188 of which 0 recycled
Exception stack ram used: 384
Never used ram: 5016
Task NETWORK ready, free stack 316
Task HEAT blocked, free stack 572
Task MAIN running, free stack 3808 -
Thanks, those figures look good, but let me know if you get any unexplained behaviour.
Quick Question on this point.
What exactly will change if you're done with Version 2.0?Is it just more compact or can it operate faster?
Is it a performance jump like from Windows Vista to Windows 7?
Sry but i don't get it. -
The use of RTOS will make it much easier for us to implement some types of new feature. I hope it will also allow us to improve file upload speed a little.
@AS-3D:
Sry but i don't get it.In short: More efficient use of the microcontrollers and development resources.
Which means that you can do more things with the resources you have at your disposal without sacrificing performance. In plain english that means that you can add more features, speed up certain parts and shorten development times.
For the developer a lot of things becomes easier as the abstraction level is significantly raised. Code becomes more robust as you don't have to twiddle around with low-level error prone code that often incurs limitations that makes the entire code base hard to maintain. Hunting for bugs becomes somewhat easier too.
Firmware Version: 2.0(RTOS)alpha1 (2018-04-05b2) installed on one of my Ultibots D300VS deltas. 1 print completed. Amazing progress David.
Completed 2 5 hour prints on 2.0 alpha without any issues, amazing stuff David!.
2 (minor) problems I found so far:
- sometimes the ESP8266 would not boot a power up (blue led won't light up) ( a power cycle solves this).
- DWC Disconnects at the end of an upload.
for reference:
WiFi Server Version: 1.21
Web Interface Version: 1.21.1-b1 -
I've uploaded multiple files from DWC with no disconnects. I'll keep my eye open for this and if it happens, report back.
After updating to 2.0(RTOS)alpha1 (2018-04-03b2) I ran a few small test calibration cubes. Everything was working fine. On the third run I walked out of the room for a few minutes and came back to the printer frozen (not moving).
I reset the printer and ran an M122.
Here are the results
12:01:24 PMM122
Static ram used: 26196
Dynamic ram used: 95340
Recycled dynamic ram: 1344
Handler stack ram used: 324
Never used ram: 7868
Task NETWORK: state 0 stack rem 676
Task HEAT: state 2 stack rem 172
Task MAIN: state 1 stack rem 428
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)alpha1 running on Duet WiFi 1.0 or 1.01 + DueX5
Board ID: 08DAM-999TL-MQ4S4-6JKDA-3S06M-95HMY
Last reset 00:00:26 ago, cause: software
Last software reset at 2018-04-08 12:00, reason: User, spinning module GCodes, available RAM 7860 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
Used output buffers: 8 of 32 (18 max)
Error status: 0
Free file entries: 10
MCU temperature: min 30.4, current 30.7, max 31.1
Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Driver 8: standstill, SG min/max not available
Driver 9: standstill, SG min/max not available
Expansion motor(s) stall indication: no
Date/time: 2018-04-08 12:01:23
Slowest main loop (seconds): 0.008095; fastest: 0.000070
MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 0, completed moves: 0
Bed compensation in use: none
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.21
WiFi MAC address 60:01:94:0c:4f:6d
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 17192
WiFi IP address 10.0.0.137
WiFi signal strength -43dBm, reconnections 0, sleep mode modem
Socket states: 2 0 0 0 0 0 0 0
=== Expansion ===
DueX I2C errors 0
Not sure what happened? Maybe something in here will help you?
Running DuetWifi IDEX (2 X carraiges) With these specs
Firmware Electronics: Duet WiFi 1.0 or 1.01 + DueX5
Firmware Version: 2.0(RTOS)alpha1 (2018-04-03b2)
Web Interface Version: 1.21-RC4 - WiFi -
I ran a few longer running prints without anymore freeze ups. Some web disconnects but zero issues with printing. The disconnects are new for me but not really an issue.
The firmware is working great so far.
Will there be a revised web interface to try out uploading files while printing? I tried it but the button is locked out in the current version I am running.
@timcurtis67 said in RepRapFirmware 2.0 with RTOS in development:
I've asked chrishamm to look at doing this.
RRF 2.0beta 1 has now been released. Please post further comments and feedback in the thread I have created about that release, https://forum.duet3d.com/topic/4871/reprapfirmware-2-0beta1-available.
