Duet wifi p3steel mounting
Hi there new user to the board so apologies if this is the wrong place. im currently upgrading to a p3steel frame for my 3d printer and have a duet wifi to run it. im just wondering if anyone has done this and if so do you have an stl on how to mount it to the frame ?
On Thingiverse are several duetwifi housings..some to mount it on 2020 extrusions..some stand alone
I have a P3Steel build, but I have enclosed my printer so the board lives in a separate housing outside the printer.
I can share my config if needed
Thanks all, I was hoping to mount to the frame but I guess ill go with the external box for now. Just need to sort out the x idler on the frame then time to wire up my first duet, I think I have the setup done correctly ( with bltouch) but I wouldn't mind a look at your Whosrdaddy if you don't mind ( im using 200x200)
https://www.thingiverse.com/thing:2517479
Maybe something like this?
I'm in the middle of doing the same as you. I have designed a spacer/mount for this Box www.thingiverse.com/thing:2481027.
The mount is here www.thingiverse.com/thing:2847223 it's still a work in progress but it might help.
Thanks ill give them a look, the p3 steel can be a bit of a nightmare as there seems to be a lot of variations with different hole placement, tried loads of power supply mounts before I found one that fitted mine
@fragglerok said in Duet wifi p3steel mounting:
Which one have you got? Mine is the orballo printing one.
that's the same one as I have
